Question about Music
Zoom MRS 1608 will not power on
Power supply works with my Zoom MRS 1266 but not the 1608; the plug seems loose on the 1608. There is absolutely no sign of life.
    Sergeant:
  • 336 Answers
I suggest checking to make sure those 2 units can actually use the same adapter and also check the polarity on both to see if they are the same. Most stompbox stuff usually has negative on the center of the socket, instead of positive like other devices. If I spend a little time I could find the manuals and find out for myself but, this was my logical "top of my mind" kind of advice. Those values (volts,mA, and polarity) must be known in order to help you further. I believe it will be 9v, a few 100 mA's, and negative in the center on both but, not sure.
Posted on Mar 21, 2014
  • Andy Longden
    Andy Longden Mar 21, 2014
    Hi Joe I have checked and both the 1608 and the 1266 use the same voltage, polarity and current. I noticed that the adapter plug seems loose in the 1608 and am hoping that it is the socket that is faulty (maybe a dry joint or worn earth contact) the details are DC12V, 3A centre live
3 Suggested Answers
guitarmanjoe
  • 336 Answers
SOURCE: how can i unlock my mrs zoom recorder 1608 as it wont let me into my tracks i have stored
Here is the manual for that unit, I didn't see anything in there about that except saving and opening files or samples. Hope this helps you.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0CD0QFjAB&url=http%3A%2F%2Fwww.zoom.co.jp%2Fdownload%2FE_MRS1608.pdf&ei=lbE_UZj2G5SK9ATKhoDIBg&usg=AFQjCNEfNb_7T9tO_5VYIriVUkG6PyfgWA
Posted on Mar 12, 2013
  • 1137 Answers
SOURCE: Freezing while booting up - Zoom 1608 - PLEASE HELP!!!
Try the procedure on page 184 of the owners manual. Heres the link:http://www.zoom.co.jp/archive/English_Manual/E_MRS1608.pdf If it won't completely download keep hitting refresh. I had the same problem downloading. the InitFac will restore the system files but will supposedly not affect user created data. In any case read the whole thing carefully. I don;\'t have one but I downloaded the manual to try and help. Let me know how you make out.
Posted on Aug 07, 2009
My Casio ctk 811ex wont power up anyone more.Is there an internal battery that needs replacing ? What could be causing the problem ? 2 weeks ago it was working fine
ALWAYS start with the "easy" things 1st. Is the AC outlet on the wall working properly? Is the "wall-wart" power supply working correctly? If no defect is found, check the DC power jack located on the rear of the keyboard. Does it seem to be loose or does moving the power supply jack up/down cause any change? New wall-wart power supplies can be purchased from Radio Shack and usually at a lower price than the original factory replacements.
Mar 29, 2015 | Casio Music
Zoom G9.2tt Gituar Effects Console
get ahold of these guys about repair to the unit, I checked through the manual and couldnt find anything of interest
http://www.zoom.co.jp/archive/English_Manual/E_G92tt.pdf
that might help you but doubt it.
Samson Technologies Corp.
45 Gilpin Avenue, Hauppauge, NY 11788
P.O.Box 18016, Hauppauge, NY 11788-8816
Tel: (1) 631-784-2200 Fax: (1) 631-784-2201
http://www.samsontech.com
E-mail: zoom@samsontech.com
if that dont work you can contact zoom directly at info@zoom.co.jp
Aug 11, 2008 | Zoom H4 Handy Recorder
Zoom g1x dc supply not working, my zoom g1x is working when battery operated but if i connect it to a adaptor there is no power, i've already checked my adaptor and it was properly working, what can i
Some possibilities:
  • Damaged on the DC-IN socket.
  • Broken solder joints on the center pin of the DC IN socket (see figure: pin 1 on DC208B).
  • Damaged (broken) in D2 or R54
Aug 18, 2014 | Zoom G1x Guitar Multi Effects Pedal with...
H1 won't connect via USB
This page has a download for a driver........ https://www.zoom-na.com/products/field-video-recording/field-recording/zoom-h1-handy-recorder
Also try a different cable....... Good Luck!
Mar 25, 2017 | Zoom H4 Handy Recorder
How can i unlock my mrs zoom recorder 1608 as it wont let me into my tracks i have stored
Mar 12, 2013 | Music
My Zoom R16 wont turn on
Hi , i have the same problem, did you fix the problem already ?
Jan 06, 2013 | Samson Technology Zoom R16 Recorder /...
I HAVE A ZOOM MRS-802 B. IT will not start up. keeps reading HDD eror. Can not scan disc due to this reading pops up after step 1 of BASIC MAintenance Procedure. Does not go to ExtFunc pops back to...
Mine did the same thing. Just by chance we had a universal laptop power supply unit with interchangeable tips made by powertran & my wife said to give it a try. The unit has a display window on it & it reads 16.9 volts when the zoom is running. When I plugged it in I couldn't believe it was going through it's start up menu. On the package it says 15 - 20 volts DC 90 watts & I reckoned it shocked the zoom into working again...well anyway, it worked & the zoom is running again. The power box package cost $89AU that I got at an electronics store.
Jan 30, 2011 | Zoom Music
Hi my zoom g1x fx is having some sound issues,it creates unpleasant noises and the sound kinda fades. I noticed the fading of the sound when i'm picking the thinner strings but it sounds so loud on the...
Hello. I am assuming that you are using the manufacturer supplied mains power supply and not running it from battery (otherwise replace the battery before doing anything else). I have noticed a similar problem occasionally with my Zoom G1XN too - mostly when I have been using it with headphones plugged directly into the pedal. Sometimes gently wiggling the output jack plug seems to have solved the problem - however I have had it occur when using the pedal with an amp too. Next step would be to try using different jack leads (or swapping the ends round) to make sure it is not a problem with poor contacts in the sockets. If this seems to solve the problem a little squirt of switch cleaner in the sockets wouldn't go amiss - but leave it 24 hours to dry out before using again. Do you find it only happens on some patches or on all of them? I have one patch that is absolutely clean (straight through with every effect set at flat/zero). Try that with one patch and see if it still does it and to give you a quick comparison. However, I think there may also be a bit of a problem with the effects processor itself (either in the design or the circuitry) - let's face it the GX1 is a modestly priced unit and they probably keep the price down by using cheap components. My usual solution has been to switch it off and remove all the plugs and start again. This has worked but is kind of annoying if it happens in the middle of a gig or half way through recording a song. Lastly I would try re-calibrating the expression pedal. as follows
  1. Turn the unit off
  2. Hold down the PEDAL ASSIGN button whilst turning on the power/ inserting input jack-plug.
  3. Raise the expression fully and press the STORE key (display should read "UP")
  4. Push the pedal down as far as it will go, until it hits the stop, and then release it (it will return slightly at this point)
  5. Press the STORE button again.
  6. If the display reads "Er" repeat the process from step 3 above.
Jan 30, 2011 | Zoom G1x Guitar Multi Effects Pedal with...
I have a Zoom 9000 Guitar effects processor, and although I have its original adapter, and although its red light flashes and power is on after plugging in everything, I could not get any sound from my...
I'm a Zoom 9000 owner (since '93, I think) Did you try batteries only? Are you plugging the guitar into the "in / power" jack and not mistakenly using another jack? When you plug in the guitar, in to the Zoom 9000 does the window come on with the settings shown? Sorry, I know some of these are obvious but always the chance of us being human. If all that seems fine, then I would read though a manual to see if maybe it is a setting problem, i.e., sound somehow got inadvertently turned off. If you don't have one, an internet search will lead you to one. Sorry, wish I knew more.
Oct 14, 2010 | Zoom A2 Acoustic Effects Pedal
I have a Zoom G2, It has excessive noise. It has the correct power supply and I tried powering it with batteries, but it still produces the loud distorted noise. It worked fine the last time I used it. ...
Check if it might be an intermittent input or output jack by wiggling these. Jackks are notorious for problems. Often the soldering of the jack to the circuit board seperates causing noise.
Sep 27, 2010 | Zoom G2 MultiEffects Guitar Pedal
Music Logo
170 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
