Question about Yamaha Np31 Piaggero 76-key Keyboard Digital Piano W/ Survival Kit D2
Yamaha np31 key does not always work
Key sometimes dose not work
I acquired a used, but well kept, good condition Yam CVP-5 clav. Some keys work sometimes, sometimes no keys work. I tried the programming and instrument buttons. Jody Bailey Newcastle Australia
I expect, assuming you did the re-boot routine, that the problem is your key contacts. Contact Yamaha for your nearest service center. Here's the link-
May 18, 2016 | Music
UBNX08514
The NP30 is no longer made. The new equivalent is the NP31. Price in the UK is listed at £ 274 most shop retail at £ 254.00 .
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=10559
Jun 06, 2014 | Yamaha NP 30 76 Key Lightweight Digital...
I have a Yamaha P70 digital piano and one F and F# stopped working. Then the adjacent G,A,B,C ansd the sharps inbetween would only work sometimes - ususally after the piano had been on for awhile. The...
I just experienced my p85 with a key problem on the F# below middle C. You will need to disassemble the keyboard and usually the keys are groups of 6 - 8 keys. If you remove the group that has the problem you might be able to find the problem visually. Mine just involved removing and reinserting the F# key back into the assembly. Then reinstalling the group of keys. If you can't get the key to work properly, you will probably need to buy the group assembly from Yamaha.
Jun 11, 2012 | Yamaha P85 88Key Portable Digital Piano
Sustain pedal does not work
Yamaha FC4 and FC5 sustain pedals are normally closed, sorry Fred. Roland is opposite. I suspect the P120 just needs to be reinitialized. Hold down top white key (C) while turning on power. Wait 3 seconds and then release white key. Should now be reset to factory spec. Always plug the pedal in before you turn it on. If it still doesn't work check it with a meter.
Mar 17, 2012 | Yamaha CP300 Stage Digital Piano...
My Yamaha YDP-121 digital piano has a key that is slow to pop up once pressed...the key will still produce a sound but the key becomes "sticky" and stays pressed, sometimes requiring manually lifting the...
Check if it might be dragging on the edge of the case. The restoring force for some of these comes from a silicone rubber dome that is oart of the contact. SOMETIMES the dome fails.
Nov 29, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
How to change speaker yamaha keybord
Simply put, the speakers can't be changed on Yamaha keyboards. If you have blown the speakers then put the sound through an amplifier or HIFI speaker system - but you must be able to have an AUX cable and AUX on the HIFI for this to work. Sometimes it can also work by use of composite cabling too, depends really on what audio equipment you have.
Apr 02, 2009 | Yamaha YPT400 61 Key Portable Keyboard...
Open Questions:
Yamaha Np31 Piaggero 76-key Keyboard Digital Piano W/ Survival Kit D2 Logo
24 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
