Question about Gateway Nv57h77u Laptop/notebook
Wont start. flashes blue led 5 times - Gateway Nv57h77u Laptop/notebook
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 174 Answers
The motherboard will need to be serviced first
Posted on Mar 25, 2014
Gateway laptop i push power button it wont boot up but leds in front flash 4 times
Try holding down the power button instead of just pushing it. I had this problem with my HP dv7 and holding the power button down for around 5 seconds worked for me. Also make sure that its plugged in to a power source.
Oct 23, 2012 | Gateway Computers & Internet
My Mitsubishi wd-65731 only displays a blue screen. It has been working fine for 5 years now.
Check video source first. Check other inputs. . Then hold down first and 3rd button from the right on tv for 5 seconds until green led flashes. count the flashes. It will flash several times pause then flash several more times. This is a code 2 digits. Let me know what code is.
Aug 30, 2011 | Mitsubishi WD-65731 65" HDTV
I just purchased a Voyager Pro. When trying to pair it with my Blackberry, I turned the device on and held the button down waiting for the LED to flash red/blue. The device turn on blue, then flashed red...
You will need to turn off your headset and then press and hold the power button until the LED starts to flash red/blue, red/blue, it will stay in this state for a few minutes.
Good luck from Headsets Direct - 800-914-7996.
Aug 08, 2011 | Plantronics Voyager PRO Bluetooth Headset
I have a golden companion scooter and it wont move it flashes a green light but i haave no info on where to obtain the trouble codes
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
Aug 17, 2010 | Golden Technologies Golden CompanioN II -...
Flashing alarm light after battery change. Car wont start,
System operation
System arms 5 seconds after switching ignition OFF. Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. If LED flashes rapidly at regular intervals for approximately 1 minute, then flashes at irregular intervals: Key code not recognised. Remove key and try again.
Programming
When
System malfunction: LED illuminates for 1 minute, then flashes at irregular intervals. Key(s) added or replaced.
NOTE: Replacement keys MUST have blue mark. Keys with red mark are NOT compatible with this system.
How
NOTE: Programming method using vehicle keys can be deactivated using diagnostic equipment.
Obtain 2 programmed keys (A and B). Insert key A into ignition switch. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key A. Insert key B into ignition switch within 5 seconds. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key B. Within 10 seconds: Insert key to be programmed into ignition switch. Turn ignition switch to position II. Wait 4 seconds. Switch ignition OFF. Wait 5 seconds. Start engine. If engine does not start and clock LED flashes: Switch ignition ON. Wait at least 20 seconds. Switch ignition OFF. Repeat programming procedure. Repeat above procedure to program remaining keys. Keys can also be programmed using diagnostic equipment
Mar 08, 2010 | 2000 Ford Focus
Dead Creative Zen M
Usually this problem is due to the firmware. When the firmware is updated to version 1.62.02, this problem usually will be corrected. The older firmwares have problems in recognizing the battery and allowing the battery to power the unit.
You will need a wall/AC charger for the operation. Plug in the wall charger and USB cable at the same time. Your Zen should power on when connected to direct AC power via the wall charger. Once it is powered on, connect the USB cable to your computer. Then begin the firmware download.
If your Zen does not power on when connected to the wall charger, your unit is dead and its time to replace it or get the motherboard replaced via one of the Repair services offered on this website.
If the upgrade button on the firmware window is not available, it is also time to replace your motherboard due to corruption of a chip on the board.
Mar 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Help with kogi F9AH screen
Intermittently displays bright red/green/blue raster then shuts down with led flashing 2, 4 or 5 times
Amazingly this was due to the CRT being faulty !
Blank raster
Replace defective TDA6111Q for Red, Blue and green
Red or Green or Blue screen
Check and replace on crt module : D702, D703, D704 (all 1N4148) replace with type 1N4948T
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Nov 23, 2007 | GVision F9AH-TG Television
Bad picture color. red LED blinks 5 times. Replace picture tube?
Definitely bad picture tube==not worth fixing......T.
Oct 11, 2007 | Sony KV-36FS16 36" TV
Gateway Nv57h77u Laptop/notebook Logo
47 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
