Question about Fellowes Office Equipment & Supplies
Fellowes 60c shredder is jammed, can't get little bit of paper out and it won't work in reverse or forward
We use this shredder in the office, and I was shredding paper and it gets overheated. Normally I can pull the paper out, but this time, it is only a little bit, so it gets stuck under the lip of the gap, between the blades and the opening. Is there any way the silver part can be taken off, or what is it better to do?
    Top Expert:
  • Fellowes Master
  • 36,408 Answers
Some office shredders have a removable mechanism; others require removal of the bin followed by turning the unit upside down to get access to the mechanism. In any event, with power disconnected the next procedure is to remove the shreds of paper jammed in the mechanism. This is a long, tedious process requiring perhaps tweezers, needle nose pliers and infinite patience. Eventually, the shredder will work again (unless the motor has burned out).
Posted on Mar 21, 2014
  • 48 Answers
SOURCE: Infoguard shredder jam
When you set it to reverse, it Should propel the paper back out the top, where it's jammed. If it does not, remove power to the unit, and get ready for the long laborious process of removing the jam with a pair of tweezers. A hazard of paper shredders, maintenance can be a bit on the silly side.
Posted on Jun 04, 2007
directcurent
  • 59 Answers
SOURCE: Fellowes DS-1 Clicking Sound
it means that one of the gears is most likly missing or damaged teath
Posted on Nov 29, 2008
sparkysbox
  • 61 Answers
SOURCE: Motor on / Blades don't move.
Sounds like the internal gears or drive shafts are either broken, or out of alignment. Not exactly something that can be easily fixed usually. Hopefully, it's still under warranty?
Posted on Mar 13, 2009
SOURCE: Fellowes P600C-2 Motor runs in reverse, but not forward
Take it apart and clean the switch with compressed air.
Be careful when you put it back together that you don't allow the wires to touch the fan.
You also have to make certain that the small plastic teeth that seperate when you feed paper are aligned properly.
Good Luck
Posted on Apr 04, 2009
  • 215 Answers
SOURCE: Fellowes PS60C-2 shredder doesn't shred
there are two switches under the cutter area. 1 for sensing when your basket is full, (sometimes these bin-full flaps get stuck in the up position, energizing the switch) and the other is a switch that detects if your basket is installed. fellowes has modified these shredders so many times, that there are alot of different configurations. look for something that resembles a flap under the head and make sure its in the down position. as for the basket sensor, some baskets had 2 projections on the left and right top of basket. one may be broke. if so, you can "cheat" the switch with a screwdriver to see if thats the problem.
hth,
razors
Posted on Apr 15, 2009
Paper shredder jams
There may be one more small piece blocking the sheet detector.
Jan 05, 2015 | Fellowes Office Equipment & Supplies
Yellow light comes on
Look at the manual in the link below. If you do not find the answer, call Fellowes.
Fellowes Shredder Manuals
Sep 18, 2014 | Fellowes FEL-3011001 DS-1 Light-Duty...
HOW DO I UNJAM SB 99C SHEDDER
Try spraying some WD40 into the cutting blades then turn it on to forward it may unjam itself.
Aug 25, 2014 | Fellowes SB-99Ci Shredder
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Shredder will go on reverse but not forward
I have one like the one pictured. UNPLUG THE UNIT, USE GLOVES THE WHEELS ARE SHARP. Take another look at the underside see if the old paper is compacted if so, use an ice pick to pry the paper loose but be careful. Another item you will see 7 holes those are screws. Use a phillips and remove the screws to expose the working parts. Look for paper jams etc. move the wheels by hand, add a little WE40 or lite oil. Hope this helps.
Apr 09, 2014 | Fellowes P400C-2 Shredder
Fellowes P35C works in reverse but not forwards
In forward operation, a detector senses the presence of material in the feeder and turns it on. Reverse operation is selected by switch position; no sensor is involved. I would bet that if you remove power and turn the shredder upside down you will find bits of shredded paper clogging your shredder, particularly in the center area where the detector is located. After thorough removal of debris, you should be back to normal operation
Feb 03, 2013 | Fellowes P35C Black Cross Cut Shredder...
My fellows jbo1 jamed and then stopped running is there a reset buton?
Chances are it's over heated.
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
From fellow's website: http://www.fellowes.com/fellowes/site/support/support_troubleshooting.aspx#jammed
Dec 15, 2010 | Fellowes Office Equipment & Supplies
My fellowes paper shredder is not operating. we have lifted the shredder head and fitted it back on the basket but nothing happened
Instructions
Step 1 Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
Step 2 Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
Step 3 Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
Step 4 Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
Step 5 Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
Good Luck!
Jun 19, 2010 | Fellowes P48C Cross Cut Shredder with...
MY FELLOWS GD1200 SHREDDER IS REALLY JAMMED WITH PAPER.WENT TH SHRED ENVELOPES AND TOO MUCH PAPER WAS INSIDE.hOW DO I UNJAM THIS? iVE TRIED REVERSE SLOWLY THEN FORWARD,ETC.IT IS STUCK BADLY.I SAW AN ANSWER...
First, UNPLUG IT!
2 - Then remove the top. shredding part and flip it over.
3 - Carefully, with your fingers, not a pliers, remove all the paper bits and pieces from the underside of the shredder.
4 - Turn it back to right side up, and place it on the basket as it should be positioned, then plug it in and turn it on in REVERSE first.
5 - Once it starts, let it run until it stops; it should only be a couple of seconds.
6 - Turn the direction back to normal, and see if it will run that way.
Good luck,
-a.
Apr 21, 2010 | Fellowes OD1200 Shredder
Fellowes Paper Shredder P70CM paper jam
Clean the upper and lower sensors with a cotton swab moistened with rubbing alcohol.
Jun 21, 2009 | Fellowes P70CM Shredder
102 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
