Question about Ford Vehicle Parts & Accessories
Engine code p1036
99 ford ranger 4.0 check engine light truck skips when cold codes p1036, p1131, p1151, p0171,p0174 can you help
  • morrispd_75
    morrispd_75 Apr 22, 2014
    Hi millie , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
5 Suggested Answers
  • 116 Answers
SOURCE: 98 E-250 Rough Idle; codes p0156,p1131,p1151,p0301,p0171,p0174+
po301 thru po306 all misfire codes cylinder 1-6 remove plugs and replace them..... set the plug gap first
i suggest u replace the wires also if they never been replaced all these misfire codes can set the others and one is for the oxygen sensor ( 02s or HO2S) CIRCUT MALFUNCTION do u know how to check wireing systems
do the tune up plugs (set gap) .052-.056 change the fuel filter also. clear the codes hows it run
this info is for 98 E-250 4.2Litre
what engine do u have 4.2L or 4.6L i know it is a v-6 by the codes
Posted on Dec 15, 2008
  • 30 Answers
SOURCE: poor idle dtc P1151, P1131,P0174, P0171. runs ok
Change plugs, and Mass Air Flow sensor. This should do the trick
Posted on Nov 30, 2009
traceylewis1
  • 363 Answers
SOURCE: how do you access engine codes on a 96 ford
Run to auto zone they will do a free check on it for you
Posted on Dec 11, 2010
  • 4 Answers
SOURCE: P0174 only code I have on my ford f150 5.4L
Hello, have you checked the PCV Tube's rubber elbow (where it connects to the intake manifold) it might be torn open and causing a major vacuum leak.
By reading this page you will have a better understanding on whats going on. Troubleshooting P0171 and P0174 Ford 4 6L 5 4L Now I know most don't have an obd computer but there is very vital information on this page, Such as page 3 Most common causes for a p0174
If you require further assistance, Please don't hesitate to ask. We are here to help!
Posted on Mar 17, 2014
Chevy Silverado error p1151
P1151 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2
p1131 p1151 p0171 p0174 p1131 p1151 p0171 p0174
All of these p1131 p1151 p0171 p0174 codes indicate a problem with a lean condition. This engine is known for vacuum leaks, so before you start throwing oxygen sensors at the problem, it pays to perform some diagnostics.
Start by cleaning the MAF sensor. Spray the sensor with CRC MAF sensor cleaner. Next, check the plastic vacuum lines, especially where they meet with rubber boots. If they are cracked or the rubber is swollen, replace the line. Then check the rubber elbow that holds the PCV valve. That elbow is a know failure point. In fact, the entire PCV tubing is a trouble spot on these engines. (thanks Ford).
After you've checked for vacuum leaks, check the operation of the oxygen sensors. The easiest way to do that is to disconnect the sensor from the harness. Connect one lead of your digital voltmeter to the black wire on the sensor and the other lead to battery negative. Then start the engine and add fuel (either propane, starting fluid, or carb cleaner) into the throttle body to force the mixture to rich. You should see a corresponding increase in voltage as you add fuel (from 0 volts to slightly less than 1 volt). Start and stop the fuel enrichment and watch the meter to see if the volts drop as you stop adding fuel. If you see no change, the sensor is dead. Replace it.
You can also use the fuel enrichment procedure to locate intake gasket leaks.
P1131 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1
P1151P1151 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2
P0174 system lean bank 2
P0171 system lean bank 1
This is the only info that didn't come back directly to FORD (yet still mentions it) instead of GM. Not to sure you got the correct code.
Jul 08, 2014 | 1999 Chevrolet Silverado 1500
2003 Ranger 3.0 codes P0174, P1130,P1150, P0171 and P1151
with that collection of codes I would usually check the mass air flow meter for contamination with oil or some debris if not it may be faulty
Oct 18, 2012 | 2003 Ford Ranger Regular Cab
Ford windstar trouble codes p0171-p0174- p1131-p1151-p0305
All these are fuel trim codes and fuel control O2 sensor related codes, you have something that is causing this as all the sensors seldom fail. My advice here is to see a Ford dealer for the diagnostics before any parts are replaced.
Jun 27, 2012 | 2001 Ford Windstar
2000 Lincoln Navigator - few days ago started idling very rough when truck is at a stop or in park. Service Engine Light came right around time I noticed that it was idling rough when stopped. Following...
P1131 Lack of HO2S-11 Switch ,Sensor Lean
P1151-Lack of HO2S-21 Switch ,Sensor Lean
PO171- System to Lean (Bank 1)
PO174-Systen to Lean (Bank 2)
Fuel Filter -Plugged
Low Fuel Pressure
Evap System -Leaks
Leaks - in ducting,air filter to throttle
PCV -Leaks
Exhaust System -Leaks
O2 Sensors-worn out
Apr 06, 2011 | 2003 Lincoln Navigator
Service engine soon light on - codes P0171, P0174, P1131 and P1151 on a 2002 4.6L V8 Does this combination of codes focus on a particular emission component?
Hi, 1151 is an 02 sensor code, 1131 is also 02 sensor code,
0174 lean condition bank 2, and 0171 is lean bank 1. Either this is in need of a whosale of repairs or you have computer issues, From looking at the codes i would first do a complete tune up, Including wires, And inspect for a vacume leak before replacing any 02 sensors..
Take care
Aug 07, 2010 | 2002 Ford Explorer
Poor idle dtc P1151, P1131,P0174, P0171. runs ok
Nov 29, 2009 | 2003 Ford Taurus
P0401,p0402,p1405,p0171,p0174,p1131,p1151
I have a 1996 ford f150 4.9 liter.The truck runs great but bad gas mileage.the only problem is i am getting codes p0401and p0402 what should i do.
Oct 14, 2009 | 2000 Ford Windstar
I got the codes from auto zone 4 codes came up p1151,p0171,p0174,p1131 all of the codes listed several possibilties and the MAF was listed on them all does the mass air flow censor cause this
it could but most likely not check for a vacuum leak check the hoses to the throttlebody the rubber fittings have a tendancy to get soft and collapse
May 17, 2009 | 2003 Lincoln Navigator
Dec 15, 2008 | 2003 Ford E250
Vehicle Parts & Accessories Logo
26 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
