Question about Tablets & eReaders
How do I turn the sound down on this device. I have only had this a short while.
Not able to find the way of doing it.
  • 36 Answers
You need to tell us what make & model your device is in order for anyone to help you.
Posted on Mar 22, 2014
Dell venue 3730 lockscreen bypass
Hardware Key Reset
If your device is not working because it is frozen then you wouldn't be able to reset it with the software. So the next option would be the hardware method.
1. Press and hold down the Power button + Volume down button + Camera button all at the same time until the device vibrates, now let go of the Power buttonwhile continuing to hold down the Volume down button and theCamera button.
2. Shortly you should see the message displaying "Are you sure you want to format?", you can now release the Volume down button + Camera button.
3. In the format screen you have the option to either Format or Cancel. Tap on Windows key Format if you are confident to go ahead.
4. Press on the Windows key again to confirm your choice.
Your device should now begin to format the device and shortly should startup with the Start-up Wizard. Ensure you device have the battery power while doing this
Sep 16, 2016 | Dell Tablets & eReaders
CANT POWER DOWN OR DO A FACTORY RESET
How to Factory Reset Your Android Phone or Tablet When It ...
www.howtogeek.com/.../how-to-factory-reset-your-android-phone-or-ta...
Dec 6, 2012 - You can even perform a factory reset when your Android phone or tablet ... If You Can't Boot ... If your device isn't on this list and none of the above methods work, do a Google search for the name of your device and "recovery ... If your device freezes at any point, hold down the Power button until it restarts.
What to Do When Your Android Phone or Tablet Won't Turn ...
www.howtogeek.com/.../what-to-do-when-your-android-phone-or-tablet...
May 16, 2015 - You can't just plug it in and try to turn it on immediately - you'll need to give ... How to Factory Reset Your Android Phone or Tablet When It Won't Boot ... To do this, you'll first need to power down your phone or tablet and then ...
Dec 28, 2015 | Tablets & eReaders
Shows 99% won't open and can't shut down
You can first try doing what's called doing a Soft Reset. It's the first and preferred method to try as you don't lose any files or settings. Hold the power button until the Nook turns itself off. In most cases that will be twenty seconds or more. Then turn the power back on by holding the power button down for about two seconds. Hopefully this will allow you to complete a normal boot process. The second and more dramatic way to get a working Nook back is what's called doing a Hard Reset. This process will put your Nook back to "Just Out of the Box" mode. You will lose any files and settings stored internally inside the Nook itself. The good part in all this is it won't touch anything stored externally on your external SD Cards. To do a Hard Reset Turn the NOOK off completely. Hold the Power button and Home (n) buttons. The device will turn on. Continue to hold both buttons until the device shuts off once again (~15-20 seconds). Turn the device on normally. It will prompt for a factory reset. Press the Home button twice to confirm. ------- The important part in the above is to be sure you start the Nook via holding down both the power button and the Home (n) buttons at the very same time and keep them both pressed down until the Nook turns itself off.
Mar 07, 2015 | Nook HD+
I view-776 tablet freezes constantly it sounds like something is loose inside when I shake it sometimes it unfreezes or screen goes wide how can I check it
Sounds like either something broke off (solder, metal, or anything conductive), or a screw came loose. I'd fin out what that rattling noise is, and to do that you'll have to disassemble the device. There's many sites online that offer detailed tear down of many devices. I would look for a tear down guide for your device, and if you feel qualified or confident enough to, tear it down yourself. If not, many computer and/or smartphone repair shops will work on tablets for an additional fee.
Nov 26, 2014 | Tablets & eReaders
Forgot password on icraig jelly bean how do i reset it
First, Turn your device off.
Now, press and hold the down volume button, while holding down the button, press the power button until the display turned on. then go to recovery by navigating up and down through the volume buttons.
Then quickly press the power button to confirm. And there, your device will start resetting to factory default.
Jun 09, 2014 | Craig CMP741d Tablet
Hi My zte F102 is on ftm mode what should i do
Try removing the battery to turn the device off. Replace the battery and then turn the phone back on and you should be out of FTM.
FTM, is usually entered by holding a button combination down when turning the phone on. Sounds like you accidentally figured out that combo when you turned it on. It could be as simple as holding the power button while turning on.
Apr 09, 2014 | ZTE V9 Smartpad Android Internet Tablet
Hey I have a Vi30W onda tablet but when I try to turn it on it stuck with the android logo and I dont know how to actually turn it on.
it sounds like you're at the emergency recovery screen, volume down to see the first menu, select option 1 reboot device, do not select anything else.
Dec 27, 2013 | Onda Vi30W 8 Inch Capacitive Screen...
Mid tablet wont shut down
So you need to be In the main menu interface then press the power button for about 5 seconds to shut it down. Below is the power section out of the manual.
1.2 POWER
startup: Long Press and hold the power button, the system will enter the main interface
shutdown: In the main menu interface, Press the power button about 5 second to shutdown, The system can hint "power off" option, Clike"ok". you can safely shut down.
Lock screen: Short press Power button to lock screen or unlock screen.
Remark 1.When power is empty,system will shut down automatically.
2.Illegal turn off the device,restart will scan and restore the disk,it may take longer time to enter into system
Jan 30, 2013 | mid Archos M729B Android Tablet
IPad HD gets too hot for me to hold!
Hi Yoav,
Thank you for using FixYa. Here are a couple ways I have utilized that have cooled down the iPad by a few degrees and made it much more comfortable to use:
  • Turn down your screen brightness. This is the best way for you to avoid heating issues. Your new iPad probably came out of the box with brightness turned all the way up. If you turn that down you will notice a decrease in heat immediately.
  • Use Wi-Fi instead of 4G LTE whenever possible. Now obviously you can't do this everywhere, but whenever possible you should access the internet via Wi-Fi and avoid riding your 4G LTE chip. That baby is power hungry and will heat up quick.
  • Give your A5X chip a break. In less technical terms, try not to play graphics heavy games (like Infinity Blade) for an extended period of time. Like you said in your question, that's when you experience the most heat discomfort. If it is at all possible for you to take even a short break (like 10 minutes every hour) from gaming, it should do a lot to keep the heat down.
I hope that helps you out!
Mar 27, 2012 | Apple iPad HD
Tablets & eReaders Logo
13 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
