Question about Peavey Ecoustic 110 Acoustic Amp
How do i plug headphones into my e110 amp
Can I plug headphones into it?
Have a Suzuki Hp-110 digital d electric piano after plugging in headphone into jac external speaker nolonger works
IKf you are meaning the speakers don't work when the headphones are pkuged it, that's the way it's supposed to work. If you are meaning the after you plug in the headphones and then unplug them the speakers still don't work, that means you either have a dirty headphone jack or the jack itself is broken.
Jan 03, 2017 | Electric Music
Voxmini 3 got sound with headphones plug in but no sound when unplugged
headphones plug in but no sound when unplugged means your output ic is working ,so check the headphone socket it may have loose solder or your socket itself may be defected. give it a try it always helped me.
Mar 06, 2014 | Yamaha Portable Keyboard
Micron problem!
When you plug in the headphones it cuts the sound to the speakers. Unplug headphones (they are probably broken if you can't hear them). Make sure you are using stereo plugs.
Jan 23, 2013 | Alesis MICRON Analog Modeling Synthesizer
I have a yamaha dd65 kit and I'm having problems with it spontaneously turning off when in use. However when I have headphones plugged in or it's plugged in to an amp, it works find and contin
Since plugging something into the Headphone/output port seems to temporarily fix the problem, I would suspect that it might be the power plug of the adapter. Maybe what is happening is that plugging something into the headphone port is somehow putting some pressure and helping the power adapter plug to stay in place and provide power. Odd problem you have there.
Mar 10, 2012 | Yamaha DD65 Portable Digital Drums
Yamaha CP 300 broken headphone jack
Some keyboards use the amp output sockets for headphone use.
You might need some adapters for your headphones.
If it fell in, you would see an empty hole. This would be unlikely because it is held on by two screws. If all fails, buy an amp with a headphone jack input. Plug the keyboard into the amp and use the amps jack.
Dec 15, 2011 | Yamaha CP300 Stage Digital Piano...
Do I need to buy a seperate headphone jack adapter in order to put my headphones in? The headphone jack seems too small. If so what should I buy?
What type of headphone connector do you have? The Yamaha keyboard headphone jack is a 3.5 mm stereo jack (like on a computer headphone jack). So if the headphones have a 1/4" plug, you need a 1/4" to 3.5 mm adapter.
I hope this helps.
Dec 26, 2010 | Yamaha YPT220 PAK 61 Key Keyboard wAC...
Marshall MG50 DFX amp line out/headphones not working
Contrary to what's posted above, the Marshall MG series does not pass the speaker power output through the headphone jack, and inserting the headphones into the jack does not disable the speaker. The headphone amp is a separate circuit and it's input is taken before the master volume. So Jan's post is exactly right. Turn off the master volume and turn up all the other gain/volumes as high as they will go. The other issue is that the headphone jack's output does not drive low efficiency headphones well, so you need some headphones similar to Sony's MDR-V700s to hear it well. Earbuds just don't cut it.
Mar 07, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
I have a casio wk-200 piano. I bought headphones
The keyboard has a mic jack that is the same size as the headphones. You probably put the headphone plug into the wrong jack is all.
Jan 10, 2010 | Casio Music
I have a casio keyboard and if i plug headphones into the audio hole they dont work it just plays out loud. help.
It is important that your headphones are STEREO tyoe as a monaural 1/4 inch plug will short out one side of the output audio.
Make sure the plug is fully seated as it has a switch in the unit that disconnects the speakers typically when headphones are plugged in.
If your speakers do not get cut off when you plug in the headphones, it is POSSIBLLE that the switches on the jack have been broken. This would require servicing.
Dec 28, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Headphones don't work right.
It might be that the contacts for the headphone jack is very dirty. Try using a cotton swab with a wd-40 on it to clean the inside contacts on the jack.
Jan 03, 2009 | Music
Peavey Ecoustic 110 Acoustic Amp Logo
13 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
