Question about Viper Vehicle Parts & Accessories
Door locks unlocks
I just purchased a used miata which come with a Viper 488v alarm. When i press "lock", it won't lock. When i press "unlock", it lock. Remote Start working when i press "lock" & "unlock". "*" is working too.. And it doesn't have any sound at all. Just wondering what's happen how to lock my vehicle? By the way, i replaced the battery on the remote.
  • Cyrus Mo
    Cyrus Mo Mar 21, 2014
    Sorry. I typed wrong. Press "lock", won't lock ; Press "unlock", it's unlock!!!
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 159 Answers
May be the remote was opened ad the pads inter changed
Posted on May 11, 2014
3 Suggested Answers
  • 13 Answers
SOURCE: driver's door won't unlock with remote
This may be a problem with wiring. I will need to know what the make and model is of the car. Also keyless entry system stock OEM or was that an option you have added? Lastly, did you install this system or was this installed by a cetified DEI corperation?
Thank you,
Luis
Posted on Dec 04, 2008
slick42371
  • 42 Answers
SOURCE: Does Viper 5701 VIPER 5701 2-WAY ALARM w/REMOTE
No this alarm does not do that. You can set it up for passive arming where 60 seconds after the last door is closed the alarm will turn itself on.
Posted on Feb 04, 2011
Testimonial: "Thank you"
The viper 350 system locks and unlock no chirping sound and the car does not start
when this happens it is because it has a valet function. this function is used to turn off the alarm but the lock and unlock will still work. to reactivate the alarm open the door, turn the key on, then off and then press valet switch once and this will reset the alarm.
May 29, 2014 | Viper Vehicle Parts & Accessories
Viper remote won't open door lcks
Does the remote diarm the alarm? Do you hear the " chirp chirp" when you press the unlock button on the remote? If not, then the remote is defective or needs to be reprogrammed to the alarm. If you do hear the " chirp chirp" but, the doors do not unlock, then the issue is with either the wiring from the alarm or the vehicles power locks. Did it work before? Do you have power door locks?
Jul 21, 2012 | Remote Start System
I think I messed up the remote programing.. When I press to lock the doors they do lock but the horn doesn't honk anymore.. The blue light on the dash does not light up either.. I can still remote...
If the led is solid blue when the key is out of the ignition that means your in valet mode. Which would disable the alarm, but not the starter.
Simply turn key to IGN position then back to OFF.Push the valet button which is on the antenna next to the led and the led should turn off.Close door on vehicle and lock vehicle.Siren should now chirp.
Cheers!!
Sep 16, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My viper 5002 alarm i don't know witch wire's to use off the viper alarm's for the power lock's
The door lock wires for the Viper alarm are green (-)lock and blue (-) unlock. The Viper system only provides a negative lock/unlock pulse for the door locks. So, if you are working on a vehicle that has positive door locks you will have to install relays to change the polarity.
Nov 08, 2010 | 5002 2 Way Car Alarm with Keyless Entry...
I purchased a avital 4103 remote start kit.i also have a viper 300 esp alarm system installed. my question is can i use the avital remote control to activate the viper alarm and start the car along with...
Avital and viper remotes even though they look the same, they operate at different freqs. Im a retired alarm installer i could never get them to interchange.
Apr 09, 2017 | Remote Start System
I have a Viper 470v alarm and the keypad does everything it supposed to do as far as starting the truck locking and unlocking BUT it doesn't beep anymore and the screen doesn't reflect my status. It stays...
Is the red or blue light (LED)on the dash lit up solid? If it is then the alarm is in valet mode. 2 ways to take it out of valet. 1) open a door and press lock, unlock then lock again on your Viper remote. 2) turn the ignition on then off and press your valet/override button. The LED should go out and the beeps and status should come back. BTW you can also put the Viper into valet mode using the 2 methods above.
Feb 23, 2010 | Directed Electronics 479V Remote Gen 2...
Disable viper alarm
Yes the best way is disarm the alarm and put in a Valet Mode
To activate the Valet Mode do the following:
There is a push button or toggle switch to disable the alarm (to engage the valet mode). Without knowing where this
switch is you won't be able to disconnect the alarm.
1. Put the key in the ignition and turn it to the "on" position.
2. Flip the toggle or hold the push button for at least 5 seconds.
3. The LED. light will stay solid on.
4. Turn the ignition off
5. Release the push button. If you have a toggle leave it alone in step 2
Jan 07, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
The alarm doesn't chirp and no flash of my headlights anymore. Also the blue light stays on the little receiver/antenna on the windshield wheather it is locked or not. What is the problem?
sounds like the alarm went into valet mode. that's usually what a solid blue light means on most viper alarms. check your owners manual on how to take the alarm out of valet mode. with the 5701 alarm its usually done with the remote. hope this helps
Aug 04, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Vehicle Parts & Accessories Logo
137 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
