Question about Comtrend Computers & Internet
Ct 5365 Xmit Power, i will maximum
  • Luis Tarragona
    Luis Tarragona Mar 21, 2014
    maximum power emission limits of router comtrend ct 5365
  • 1,162 Answers
No real need to run full power, why give your neighbors access to get in if possible.
Posted on Mar 24, 2014
How to cheack millage
Hi, Anonymous fill up the gas tank and reset the odometer to "0" or record the current mileage the next time you refuel record the mileage divide the kilometers driven by the liters of fuel it took to refill and you have KPL or mileage, I am sorry you can't find the first and best tool you ever bought for your Bajaj but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.DOWNLOAD BAJAJ CT 100 SERVICE MANUAL
http://www.marutibajaj.com/pdf/ct100.pdf
Bajaj Auto Ct 100 2015 User Manual
Double Your Gas Mileage 2X
10 best tips to get maximum mileage for bikes VIDEO
May 13, 2014 | 2005 Bajaj CT 100
After Flash Update (v0227) will not xmit proerly
I would flash it back to the older version. Double check you have the correct firmware. This almost sounds like the incorrect version for your radio.
Apr 12, 2014 | Yaesu FT-450D Transceiver
Enter password access denied. power amp new.
Try 6505. if that does not work then Contact customer service 601-483-5365
Sep 22, 2013 | Peavey Ipr-dsp-1600 Power Amplifier - Used
Low pwr on xmit,weak rec,swr alert lite on xmit swr 1:4-1 on ch 20
you have no power because your radio is not tuned to your antenna.You get a new radio and put junky coax and a decent antenna and you expect it to work right. Get 75 ft of rg-213 and you will see a change.
Jan 08, 2013 | Galaxy Radios DX-2547 40-Channels Base CB...
Xmit error message
Error in Xmit meaning one of the next options:
• The TI-84 Plus was unable to transmit an item. Check
to see that the cable is firmly connected to both units
and that the receiving unit is in receive mode
• You pressed ON to break during transmission
• You attempted to perform a backup from a TI-82 to a
TI-84 Plus
• You attempted to transfer data (other than L1 through
L6) from a TI-84 Plus to a TI-82
• You attempted to transfer L1 through L6 from a TI-84
Plus to a TI-82 without using 5:Lists to TI-82 on the
LINK SEND menu
Aug 02, 2012 | Texas Instruments TI-84 Plus Silver...
President HR-2510 will not transmit or recieve
Hi Darrel,
Since you didn't say if you have ever used this radio successfully before, I have to assume it is "new to you" and that you have never seen it work or used one like it before. Start with a few basic settings below:
Turn Squelch to minimum.
Set RF Gain (if present) to maximum
Set Mode to AM or FM
Set volume to 1/3 up
Connect to 50 ohm dummy load.
Turn power on. Hopefully you hear static. If not, try SSB or FM. Still nothing? Try connecting to an external speaker.
Chnage back to AM or FM mode. Key mic check & for transmit indicator. If none, change mic or manually short the PTT contacts in the mic or at the radio to see if it can be made to xmit.
If no xmit - insert SWR meter between xmitter and dummy load. Try to xmit on AM or FM again while watching SWR forward power, if none indicated, xmitter is probably defective.
Replacing parts in a xmitter is not recommended. You'll need an FCC license and a fair amount of expensive test equipment to test repairs, set power levels and deviation and perform an alignment to be sure you aren't causing interference on other frequencies and bands.
You'd be better off bringing it to a radio repair shop for repairs and an alignment.
Sep 29, 2009 | Uniden Radio Communications
None of the remote controls work
Check the batteries. Cant XMIT without power. Wireless still need power ;-)
Mar 26, 2009 | Sony Playstation 3 (PS3) Console
Heater does not come back on
I found that if I unplug the heater from the power outlet for about 3 to 5 minutes, it goes back to normal. Ive had my heater about 1 year, and have successfully done this twice. Hope this helps~!
Dec 17, 2008 | Lasko 5365 Ceramic Compact Heater
Xmit error
You must hit the "receive" button on the receiving calculator BEFORE you hit the "send" button on the sending calculator.
Oct 05, 2007 | Texas Instruments TI-83 Plus Calculator
Lasko 5365 Ceramic Compact Heater Troubleshooting Forum.
Try taking a can of compressed air and spray in the vents in the front and the back of the heater. The heater has a sensor that gets dusty and causes it to shutoff to prevent overheating.
The heater should function properly once the dust is blown off the sensor.
Dec 02, 2006 | Lasko 5365 Ceramic Compact Heater
Computers & Internet Logo
18 people viewed this question
Top Comtrend Computers & Internet Experts
Julie Endres
mathur_1
Advaith Ganesan
Are you a Comtrend Computer and Internet Expert? Answer questions, earn points and help others
