Question about Zebra Eltron P330i Card Printer
Cannot find firmware for zebra p330i aka polaroid 75i
I cannot get my printer to print from my pc for the life of me. i have gotten it to print a good test print directly from the printer menu settings itself, but when i try to print anything from the computer, it sees it just fine, but it says error and does nothing printer-wise. i think i might be missing firmware seeing as how i think i set up drivers correctly (or are these one in the same? id be the idiot asking a stupid question like that wouldnt i?) and i cant find the firmware anyware, any link i have been able to stumble across has been broken and elusive in the first place... ughhh.
    Top Expert:
  • Zebra Master
  • 74,106 Answers
5 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: Zebra TLP 2844-Z Test page print within Win XP
This printer requires special software to print labels with. It uses a unique PCL language to work with. Thats why when you use these printers with Fedex or UPS software, it typically downloads forms first before working.
Zebra used to see a label designer program to work with it. You might want to check with them to see if they still carry it.
Posted on Jul 29, 2008
  • 4 Answers
SOURCE: Zebra LP 2844 printer will not print anything but the test page
possibly not a real LP2844 but an LP2543, a printer mass produced for and used by UPS. refurbishers change the label and sell as LP2844 because they are almost identical.
if it has an AC-AC adapter, it is an LP2543. LP2844 uses a AC-DC adapter, and all LP2844's have USB ports.
Posted on Apr 10, 2009
  • 53 Answers
SOURCE: Zebra LP2824 not printing
Sounds like you put your printer into line mode. Line mode prints code so you can see what is sent to the printer to look for possible mistakes in the code.
To switch from line mode back to page mode.
  1. Turn printer off.
  2. Press and hold the feed button down. And switch printer on.
  3. Release the feed button when the LED flashes red.
  4. When the LED flashes green, press down the feed button.
  5. When the LED flashes amber release the feed button.
  6. Try printing now that the printer is back in page mode which is used for print your labels; line mode prints the labels code.
  7. Do this fast or else it wont work if you are slow.
Posted on May 12, 2009
SOURCE: Zebra LP2824 Not Printing
I had the same problem and could not fix it but called Zebra headquarters and they gave me this solution and it works! It sounds crazy but it works. Turn off the printer on the switch on the side. press and hold the button on the front of the machine while you turn it on. The light will turn red then release the button the light around the button will then turn a solid greed then blink green. While it is blinking green press and hold the button again until it the light turns orange and then release the button. This apparently puts your printer into line mode or something but anyway it works!
Posted on Aug 05, 2009
My zebra p330i keeping on showing downloading data.It doesn't print from PC
Install the driver again.
go to the driver and send the command "R"
and "!SA"
if not working, flash the firmware. (www.zebra.com) have to be the especific firmware
http://www.zebra.com/id/zebra/na/en/index/drivers_downloads/firmware/results.html?productType=6
Nov 04, 2010 | Zebra Eltron P330i Card Printer
Hello I'm getting an error # 11102 on a p330i
Please flash the firmware, Go to www.Zebra.com, (drivers and downloads, click on the correct printer.
Sep 15, 2010 | Zebra P330i Thermal Card Printer
Command error on Zebra p330i
some commands don't work on some printers, depend the firmware and the printer P110 or p330, what commands you sending?
Sep 03, 2010 | Zebra P330i Thermal Card Printer
This is an old post but i still need help!! What does a Polaroid p85igc card printer use for a full color ribbon? Zebra p330i ymcko ribbon won't work
Right, zebra/eltron made the P310 printer before they started using smart ribbon. They also made the same printer as the J310 for Javelin and the P75 for Polaroid. These all ran on the same ribbon. Then there were the first "i" series machines the Zebra P310i, the Javelin J310i and the Polaroid P75i. These all ran on their own respective i series ymcko ribbons. Now here is my theory.... The new Zebra P330i runs on the same ymcko ribbons as the P310i and the Javelin J330i runs on the same ribbon sas the J310i. Don't know where the model number came from but the Polaroid P85igc is the same as the 330i printers. It therefore stands to reason that it will run on the same ribbons as the older P75i printer.
The YMCKO ribbons for the Zebra are coded 800015-440 for 200 print rolls, 800015-540 for 350 print rolls. I have seen a picture of a ribbon with 800015-540POL on it advertised for the Polaroid but cannot find anyone to sell it. I can find however a few US references to a ribbon for the P75i One is linked below. It may be worth a go if you get desperate. //www.identisource.net/pd_3151.cfm
The other alternative, as the machines are essentially the same, is to change the motherboard so the printer thinks it is a Zebra or Javelin and then buy much more readily available ribbons. We can swap the board for you but as a spare they are just over £400 incl VAT. YMCKO ribbons would only be around £30 for 200 image rolls, thats the genuine stuff not the knocked of rubbish that's around. www.pci-solutions.co.uk I shall investigate to make sure we can't "rebrand" the printer by changing its firmware, but I doubt if it will be that easy.
Aug 29, 2010 | Office Equipment & Supplies
Zebra P330i Printer not counting the YMCKO ribbon correctly
!RIBLEN - - - - Get number of remaining panels on ribbon
Send the command !CSA_0
Send the command !CSA_1
Jul 16, 2009 | Zebra P330i Thermal Card Printer
What does a Polaroid p85igc card printer use for a full color ribbon? Zebra p330i ymcko ribbon won't work.
The "i"suffix was introduced in around 2005 to try to stop patent infringements on the printer ribbons. They introduced a chip on the spool that feeds back to the printer. The chip has to be the correct coding for the badge of the printer. Zebra P330i printers are essentially the same as Javelin J330i and Polaroid p85igc but have three different part numbers for their YMCKO ribbon. You can run any monochrome ribbon on them because the mono ribbons have no chip.....not much profit for the brand owners. YMCKO however is not interchangeable. Find a Polaroid dealer for the full colour ribbon.
Jul 08, 2009 | Zebra Eltron P310 Thermal Printer
ZEBRA PRINTER p4301
Try downloading the newest firmware/drivers (uninstall the old driver first - with the printer off).
and see if that helps.
Nov 11, 2008 | Zebra P330i Thermal Card Printer
OVERLAPING OF COLOURS.
go to zebra and download the latest firmware and drivers (free).
update the firmware first
turn printer off
then uninstall (from uninstall programs) the zebra drivers.
then install latest zebra driver.
turn printer on
Double click on printer icon, click on properties.
Click on the device options tag, then click on the properties next to tools
Enter "CALB" and click execute - this will re-calibrate your ribbon
First try the CALB, if your current firmware does not recognize it, then you will
need to upgrade the firmware as above.
Oct 30, 2008 | Zebra P330i Thermal Card Printer
Zebra Eltron P330i Card Printer Logo
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
