Question about Epson 9880 stylus pro Printer
How to fix printer blurr
Please help my Epson 9880 stylus pro Printer prints blurry after i take the head to clean.
  • Ed Whitcomb
    Ed Whitcomb May 27, 2015
    Printer blurring is usually caused by the characters not lining up properly. Go into your printhead maintenance menu and perform the automatic printhead alignment.
    New Friend:
Most likely you're wiper for the capping station is covered in ink. I recommend having the printer cleaned by someone who does maintenance on Epson printers.
Posted on Mar 21, 2014
    New Friend:
Maybe your printhead is clogged.You'd better clean it by a manual. EPSON Stylus Pro 7880 9880 Plotter English On Site Service Manual Here are sth maybe you need.
Posted on Mar 24, 2014
sharksupport
  • 14 Answers
SOURCE: Epson stylus photo 810 won't print
Is it just not printing on the paper and feeding it thru, or will it just not do anything? I need more info?
Posted on Dec 05, 2007
  • 33 Answers
SOURCE: epson stylus pro 4800 print head problem
Are you getting a nozzle check at least?
Posted on May 14, 2008
yooperbud
  • 8637 Answers
SOURCE: Epson Stylus Pro 9880 Does Not Print
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 24, 2009
SOURCE: epson stylus photo 950 printer flashing lights
I had the same Problem and checked the solution:
This is a Printer Maintenance request.
Ink Overflow -
you sould change the waste ink pads under the printer mechanic.
Solution:
Posted on Feb 16, 2009
eric1121
  • 265 Answers
SOURCE: Epson Stylus Photo RX500. I was cleaning print
Press all these buttons:
Power+Load/Eject+Stop+B&W+Color
When printer turns ON, "Init eeprom" appears
Release and Press the Color button.
Posted on Jan 16, 2010
Epson 9880 prints half a job, then stops
i aint too sure if its the same but i had an epson printer with the same problem last year it would print half a page spit out and then print the same half a page again and just stuck in a loop even on printing disks it did the same i found out after by speaking to a printer specialist it was the printers eeprom which is the printers memory bank that was failing and nothing can be done with it
Feb 11, 2014 | Epson 9880 stylus pro Printer
Epson stylus pro 9880 blocked nozzles won't clear
I have a 9800 - you can remove the print head, and try cleaning the nozzles manually and see if there's something on them. I'm sure any warranties would be void if you do such a thing, but - you're up for replacement of the print head anyway. So do with caution and at your own risk.
It takes about 30 mins and requires a reasonable level of skill. Search around and get the service manual - they are out there pretty easy to find. They give step-by-step procedures to get it apart safely.
Then clean the print head with either rubbing alcohol or hot water (alcohol is probably better). If your print head got stuck on tape, you might have the glue from the tape on the print head. So some kind of solvent to remove the glue - again - be careful and watch that you don't create further problems.
I've done similar with my printer and it still works fine and haven't had to change the print head for the past few years.
Feb 05, 2014 | Epson 9880 stylus pro Printer
Epson9880 no ink sent to print head
no ink sent to print head at all?problem with printer mainboard, usually caused by short circuit in head, then "burn" the fuse in mainboard.
Jan 14, 2013 | Epson 9880 stylus pro Printer
How to remove and clean epson stylus pro 7000 printer head its cloged
Welcome to FixYa!
If you have not used your printer for a long time, the print head nozzles may be clogged. Perform a nozzle check and clean the print heads.
Use the Epson Printer Utilities to do a nozzle check and to clean the printer head.
Reference Manual of Epson Stylus Pro 7500 InkJet Printer:
http://files.support.epson.com/htmldocs/pro75_/pro75_u1/INDEX.HTM
Comments and rates are appreaciated.
Thanks for using FixYa.
Jas
Feb 23, 2011 | Epson Stylus Pro 7500 InkJet Printer
Does not print
First of all please check the ink level. If it is not finished try followings:
First try to run a cleaning cycle. To do that:
- Load paper in the paper tray. - Access printer utilities. (Right click your printer icon, select printing preferences and click the utility tab to access printer utilities) - Click the nozzle check icon. - Print to check it.
Then click the clean button to clean the print head. - Try it a few times.
İf it doesn't help you can try to run power cleaning cycle. But it uses much ink. There must be enough ink in the cartridge.
Hope this helps.
Apr 24, 2010 | Epson Stylus Pro 4800 InkJet Printer
9880 not print nozzle ink discharge check in self test
Go to Menu and off Auto Nozzle check ...............
I hope it may solved your porblem
Oct 26, 2009 | Epson 9880 stylus pro Printer
Printing every few lines blurry, but not every line.
Printer head is clogged, be sure to clean it until you get the solid lines
Jul 11, 2009 | Epson Stylus R380 InkJet Photo Printer
Jan 08, 2009 | Epson Stylus Pro 9800 InkJet Printer
Epson rx 500 print problem
Please confirm that the head cleanings were done using the most effective method listed below.
1. Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. Right click your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then right click the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. Right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the print head. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s), your printer will require service.
We know that having a printer serviced/fixed costs more than buying a new one, check out this link http://www.epson.com/loyalty .
Jan 07, 2008 | Epson Stylus RX500 All-In-One InkJet...
Epson 9880 stylus pro Printer Logo
190 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
