Question about Shark SV1100 Navigator Freestyle Cordless Vacuum
Charged but will not turn on
I used it and it was working great but the charge light started to cycle through and it would come on and off so I put it in the charger during the day. Now it will not come on
Put a new switch on it
Posted on Mar 21, 2014
New Roomba Battery Not Holding Charge - charged once then died
It is possible for the charging system inside the roomba to call it quits. What I did to remedy this, since my roomba was out of warranty and I did not want to scrap it, was to buy a charging base on ebay. This charging base accepts different types of roomba batteries and even the scooba battery. The inconvenience is if you have a newer model roomba that has the battery inside, then you will need to remove the screws on the bottom plate to remove the battery. Hope this helps.
new-roomba-battery-not-holding-charge#solution-section-qgwpio3es2ee0iuiltq5rfxr-1-0.jpg
Jan 23, 2014 | Roomba Robotic Floor Bagless Vacuum
Scooba beeps 4 times
  • Lift Roomba off the floor and place it in the center of the room and restart the clean cycle.
  • If Roomba did not resume cleaning, lift Roomba and turn it over.* Inspect the Side Wheels for dirt or obstructions.
  • Test the Side Wheels by pushing them in and out and making sure they rotate freely. Place Roomba in the center of the room and restart the clean cycle..
  • Dec 22, 2012 | iRobot 5800 Scooba Vacuum
    Roomba 4106 new battery charged but wont start
    see the diodes, resistor, capacitor inside for test.
    since the battery is new, the power charger is faulty, power regulator IC is bad.
    God bless you
    May 16, 2012 | Roomba 3005 Pro Robotic Vacuum
    I need the instructions for Black and Decker Start It How do I recharge it?
    This unit is recharged using any household 120v outlet. Remove the rubber cap from the recharge port on the top of the unit. Plug the barrel end of the adapter cord into this port and then the put the adapter into the wall outlet. Make sure the power switch is in the off position. To check the charge level push the button to the left of the 3 indicator lights. When the green LED lights up, the unit is fully charged, (yellow is moderate charge and red is minimum charge).
    Try to charge the unit from the minimum (red) charge level to maintain the maximum battery life and use of the product.
    If you have misplaced the manual I am providing a link to it from Black and Decker's site.
    http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90550872,VEC010BD.pdf
    Have a great day.
    Jim
    Dec 30, 2010 | Vacuums
    The light on my Roomba flashes amber very quickly when plugged in directly with the adapter. what does this mean? it usually flashes slower when docked.
    If Roomba senses that its battery has been significantly discharged, Roomba will enter a special 16-hour refresh charge cycle. When the 16-hour refresh charge is initiated, the CLEAN light will quickly pulse red/amber. Do not interrupt the cycle once it has begun. The 16-hour refresh charge cycle is initiated by the robot and cannot be started manually.
    For long-term storage, always remove the battery from Roomba and store in a cool, dry place. Blue or black batteries should be stored after Roomba has been used. Yellow batteries should be stored after being fully charged.
    Battery capacity reduces overtime and usually the battery will need to be replaced each year.
    May 14, 2010 | Roomba Robotic Floor Bagless Vacuum
    The green light is on as though the battery is fully charged, however, when I start a cleaning cycle, it beeps and goes to red immediately without moving.
    Remove the battery, hold down the POWER button for ten seconds, then put the battery back in and charge overnight. If it still tells you it's out of power as soon as you start it, it's time for a new battery. http://store.irobot.com
    Aug 23, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
    Scooba battery light turns red as soon as irobot starts
    Do you leave the battery on charge long enough? Try 4-hours up to overnight. If so, then the battery is probably at the end of it's useful life. Getting a new battery depends on cost versus life expectancy of the robot and whether it does the job you want it to do.
    Jul 19, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
    Scooba won't turn on
    It sounds like you've got a finicky power button. Not a lot that can be done about that, but you may want to try getting your hands on the old-style Roomba remote, the black one. The power button from that will power on a Scooba, though you can't start a cleaning cycle that way. This might allow you to bypass the Scooba's power button altogether.
    May 08, 2009 | iRobot 5800 Scooba Vacuum
    Roomba Schedular
    Let it charge for a full 24, or even 48 hours, regardless of the green light. If it still dies you probably need a new battery.. or worse.
    Aug 31, 2008 | Roomba Robotic Floor Bagless Vacuum
    Shark SV1100 Navigator Freestyle Cordless Vacuum Logo
    263 people viewed this question
    Top Shark Vacuums Experts
    Thomas Perkins
    Thomas Perkins
    Ruth summersides
    Are you a Shark Vacuum Expert? Answer questions, earn points and help others
