Question about Vehicle Parts & Accessories
Warning lights brake pads is not going out after changing
Brake pads warning light
  • 336 Answers
Year and model of car would be helpfull?
Posted on Apr 30, 2014
ABS light on with warning sound and brakes heavy. Brake pads are new
It sounds like the master cylinder may have failed, check for brake fluid leaks at wheels also vacuum line to the brake booster
Apr 27, 2014 | Mitsubishi Montero Cars & Trucks
Brake warning light on 2006 rabbit
What kind of "dinging" noise? Do you hear it whenever the car is moving, or only when you apply the brakes? When you changed brake pads, did you bleed the brake system? If it wasn't bled properly, that could activate the brake warning light.
Feb 09, 2018 | 2006 Volkswagen Rabbit
Disk brake warning light stays on even though the disk brakes have been changed, any ideas on how to get the light to go out?
There is a brake pad sensor that should be replaced whenever you replace the brake pads. It’s located inside a whole in the brake caliper of the left front wheel. When this sensor fails, the warning light will come up in your dashboard.
Hope this helps :)
Oct 25, 2009 | 2002 BMW 5 Series
Brake pad warning light on golf gti 1.8t 1999 t reg
Brake wear indicator and low brake fluid warning indication are two different circuits.
They are not related.
Easy route to check brake pads is the measure the gab between the rotor and the metal portion of the brake pad.
If it's low then replace it.
The right way is to pull the tires and measure the thickness of the remaining brake pad.
Most shop give free brake inspection with oil change,
Check it out before the pad cuts into the rotor and it will DOUBLE the cost of your brake job.
Jul 17, 2009 | 1999 Volkswagen GTI
I replaced the front pads on a VW JETTA 2.5 and the check pads light is on. How can I reset the check pads light?
As the brake pads wear, the brake pad wear sensor contained in the brake pad contacts the brake rotor. This causes the sensor to fail. When a pad wear sensor fails it opens the ground circuit of the pad wear warning light system causing the pad wear warning light to illuminate. Perform normal brake service to correct this condition and be sure to replace the brake pads with pads containing wear sensors. Once the brake pads and wear sensors are replaced, reset the brake pad warning system by turning the ignition switch to the "on" position. As long as continuity to ground exists through all the brake pad wear sensors the system should reset and the pad warning light in the dash will go out. If the pad warning light does not go out, a check of the pad warning circuit for an open circuit condition or poor ground must be performed.
Mar 03, 2009 | 2005 Volkswagen Jetta
Hand brake light wont go out
this sounds like the brake pads may have worn down and the sensors have lit the warning light on the dash, check the brake pads and if the thickness of the pad is at about 3mm then a new set of pads and sensor will be required
Jan 22, 2009 | 1989 BMW 3 Series
BRAKE WARNING LIGHT
I dunno if this will work on your BMW, but on my BMW Z3 and M3, it was....
Turn the ignition key to position 2, but do NOT start the car. Wait for about 45 seconds and the brake warning message will be reset.
If it doesn't reset, then the brake sensor was damage. You will need to replace the brake sensor. It sounds like you replace the brake right after you saw the warning, so the brake sensor should be okay.
Dec 19, 2008 | 2003 BMW 325
BRAKE WARNING LIGHT
Its not an electrical problem . . .. . When you change brakes you have to change the brake sensor as well. . . . . It just looks like a piece of wire with a sensor that clips onto the pad . . . . .Normally it is the outerpad. . . I cant tell you on witch sides its on cause it may differ from model to model.
Its not going to be a hazardous to the car the brake light will just keep burning.
If you replace the sensor and t he light does not stop burning it may be that your front brakes are also worn but remember just as at the back there is a sensor at the front.
Jun 24, 2008 | 1999 BMW 318 ti
Vehicle Parts & Accessories Logo
20 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
