Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
My machine is cotinually filling
My machine has an error 40 what does that mean and how do i fix it
Report onlin
Posted on Mar 21, 2014
Will not fill with water & reads error code ddr! What does that mean? why won't it fill with water?
DDR means the door latch is loose or bad. There is a switch inside that needs to be checked or replaced.
Oct 16, 2015 | Washing Machines
My fisher & pykel is showing error 40 does any one know how to fix this ,,,Thanks
Error 40 means it is a clutch problem. If you can take the inner bowl out and see inside for a forign object preventing engaging the clutch. If water over flowing check the pressure tube. It probably disonnected or damaged. Pressure transducer inside the control board also can be faulty. If you are mechanically competent this problem can be easily fixed.
Mar 21, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Showing F01 error code on readout? what does that mean?
Hi.
It depends on the model. On Whirlpool built machines F01 is EEPROM error, pump drive error, or main relays error.
With Hotpoint F01 means defective triac or defective motor.
Aug 18, 2011 | Washing Machines
An IE code comes on my washing machine and when this happens it does not go through the final rinse cycle
Error code of "IE" signifies a water inlet error.
This means that your machine is not filling to the proper water level, and may be fixed by ensuring that machine's water supply is properly connected and turned on. Also, this means that the washer has not filled with water in 8 minutes.
Hope helps.
Jun 14, 2011 | Washing Machines
Have a load of washing in my front loader and now my LG wasing machine says 'UE'. What does this mean and how do I fix it?
is this an Lg washer ie error code is an water inlet error machine notices low water pressure , you either have kinked fill hoses , plugged screens in fill hoses coming to you watervalves or watervalve is damaged from foreing debris coming into watervalve .........
Jan 24, 2011 | LG Washing Machines
Code LF on Kenmore Oasis washing machine.
Hi
Error code LF means long fill. This means that analog water level pressure sensor signal is out of range or the water pressure is very low. The analog pressure sensor is a component on the machine control board. The normal water pressure is 100-200 PSI, when the pressure below 40 PSI then this error occurs. Verify the pressure at all other water sources in the house and check if its low at all places, if its low then contact the water company. Also check the inlet water hoses if they are kinked. Inspect the inlet water valve as well.
If you find no problems with the air hose or water pressure and its connections, then the machine control board would need to be replaced.
Please post back for any further assistance.
Daniel
Jul 26, 2010 | Whirlpool WTW6700TW Top Load Stacked...
Getting error code E03-40. What does this mean?
E03-40 - faulty toner density sensor try the following press function the original size then 3..... your screen should display f1 service mode then press 8 then start now you should see f8 ..... now press start and scroll down to option 09 and press start now you wait till machine runs the process... after that you need to switch the machine off wait 1 minute and switch it back on
Jun 04, 2010 | Panasonic Workio DP-3520 Copier
Wf860
may be the pressure switch, or the rubber tube up to the pressure switch blocked
Oct 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
