Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Eco intuitive error 40
Macine is continually filling and over flowing
  • Fisher and P... Expert
  • 554 Answers
Your machine cannot detect correct water level
The clear pressure tube has come off or got a hole in it somewhere.
Posted on May 18, 2014
  • 250 Answers
SOURCE: Fisher Paykel Intuitive Eco Washer is squealing
You need to pull out the washer, TURN OFF THE WATER, then take the water hoses off the back of the washer. Check the screens inside the water inlets for debris. If that doesn't fix the problem you may need to ask fisher paykel if it's safe to put a chemical like limeaway in those holes to remove hard water deposits that have built up inside the valves.
Posted on Sep 20, 2009
SOURCE: F&P Intuitive washer IW812 very noisy water
Traced the problem back to the tap. Seems the washer in the tap was faulty and producing a screaming graunching noise. Replaced the washer and all OK
GK
Posted on Nov 15, 2009
  • 713 Answers
SOURCE: i have an Intuitive eco and it wont drain error 37
Hi just found your posting.Do you still require help?This problem should be simple to rectify.The fault is called PUMP BLOCK ERROR.Please reply and I can guide you throe the repair of the machine.Sorry for taking along time to answer.
Posted on Jul 15, 2010
SOURCE: Intuitive Eco 701 ... error code 50.
Yes. Whichever is filling slow. Hot or cold. It is a code for the fill valve. Just replaced the cold fill valve on my unit which seems to be the one that most commonly goes out. Easy repair. 2 screws and 1 Plug...If you unscrew the top by taking out two phillips screws in the back, you will find some paperwork about trouble codes, repairs etc...Right next to the fill valves.
Posted on Jan 04, 2011
Jahn27
  • 1554 Answers
SOURCE: Intuitive ECO Model IW811 display
The fault codes 130 and 240 are pertaining to a Rotor Position Sensor problem. It is the part located wedged into the motor stator and it's sole function is the detection of motor functions particularly the rotor as the name suggests. The problem can be a simple loose wire harness or a damaged Rotor Position Sensor.
Unplug the machine. Tape the lid closed then lay the machine's front on a padded floor. Remove the single bolt holding the "plate-like" rotor to the shaft to access the Rotor Position Sensor. Once the rotor is off, check the contacts on the Rotor Position Sensor end of the wire harness to see if any have been damaged. Each set of contacts in the socket has two wipers. If the distance between these wipers varies between different contacts, replace the Rotor Position Sensor harness. Consider replacing the Rotor Position Sensor if no issue is found with the harness and the connectors.
Posted on Jul 18, 2011
My fisher & pykel is showing error 40 does any one know how to fix this ,,,Thanks
Error 40 means it is a clutch problem. If you can take the inner bowl out and see inside for a forign object preventing engaging the clutch. If water over flowing check the pressure tube. It probably disonnected or damaged. Pressure transducer inside the control board also can be faulty. If you are mechanically competent this problem can be easily fixed.
Mar 21, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Code 40 on my eco intuitive what does it mean
40. (00101000) Bowl Dis-engage Fault
While carrying out a bowl check, the Motor Control Module has found that the bowl is not engaged even though the pressure sensor indicates that the bowl is empty.
The Motor Control Module continues to check for 2 minutes,
after which time it displays this fault.
The first two areas to check are the clutch and the pressure tube.
If these two appear correct, then the fault could be in the pressure sensor in the Motor Control Module.
Primary Source: Mechanical.
Action: 1) Check that there are no clothes or other foreign objects preventing the clutch from re-engaging.
Excessive suds can stop the bowl rotating.
2) If the machine is empty of water, carry out a clutch disassembly
procedure and check the spline drive.
3) Next check that the pressure tube has not come off and that it is
not kinked.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
Intuitive Eco 701 ... error code 50. I'm sure it's to do with the fill solenoids. It is filling very slowly.
Jan 24, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
GK
Nov 12, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Intuitive Eco switching itself off during cycle.
Could be a bad drain pump or controller or rotor position sensor. You will need a Tech to take a look. Unfortunately with these machines there can be many reasons for a failure. Call F/P to get a certified technician out there.
Jun 14, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Error codes
We have an instruction manual but there are no codes.
Apr 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Error code 131
Call the guy who replaced the motor/ module. Error 131 is serious. Not for home repair.
Sep 06, 2006 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
71 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
