Question about Tascam Cd-rw900sl Cd Recorder/player
After i record and play the cd on another player i have turn volume up
Volume is not loud on another player
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 134 Answers
You probably need to adjust your recording volume on the recorder and not just copy the source as it is...
Posted on Aug 13, 2014
How do I fix a volume / sound problem on my kustom 2x12 amp
You have a bad potentiometer which is a variable resistor. Might be the switch you are turning.
May 08, 2017 | The Audio Players & Recorders
How do I increase the volume on my record and cd player
Feed the sound into a really loud p.a. system. You can use a high quality Mic to get the best sound.
Jan 11, 2015 | Audio Players & Recorders
Loud HUM from 1963 Wurlitzer 2710 when plugged in
If you observed a vacuum tube with the symptoms you describe, it requires replacement but there may be other failed components as well.
Dec 27, 2013 | Audio Players & Recorders
Rega planner 3
If the amp does not have a dedicated sockets for a turntable - often marked "phono". Then plugging it into an aux socket won't work. You will need to get a Magnetic Cartridge Pre-amp. The turntable plugs into this and that plugs into your aux socket. If at the present you turn up the volume really loud you might just hear the record playing. That will tell you that the cartridge is OK.
Jul 14, 2013 | Audio Players & Recorders
The record plays but it is really quiet, how do i turn up the volume?
You should check that it is plugged into a socket in your amp that is designed for record decks. If the amp does not have a dedicated socket, then you need to get a magnetic cartridge pre-amp. The record deck plugs into that and that goes into your amp. That will make the deck as loud as the other sources, such as CD players etc.
Jun 24, 2013 | JVC AL A158BK Turntable
How can I record a music cassette to a music disc on my Magnavox DVD recorder/ VHS --Model # ZV427MG9
You can't burn a CD-A with the ZV427MG9. The unit will not burn to a CD to play in a CD player.
You may be able to record the audio to a DVD with no video source. Connect your cassette player to the Line In audio ports (L/R) at either the back or front of the unit. Depending on your cassette player, you may need a 3.5 mm M to RCA F/F adapter to connect the RCA audio cable to the cassette player's headphone jack. Do not connect a cable to the video input of the composite input unless you have a video on a camera or something to play back. This means that the recorded video may say "No Signal" or will be black or static. (Note: this may not work with this signal issue.)
Set the unit to record to DVD on L1 or L2, as needed, by pressing Source on your remote. Advance the cassette to where you want to record. Press Rec on the DVD unit and then press Play on your cassette player. If you want to identify tracks, Stop the recording and play back and then press Rec and Play again. You are at risk of having issues with the volume during the recording. Clipping of overly-loud sounds and distortion is possible.
When done, finalize the disc, if desired, to play the disc on other DVD players.
If you want to make an audio CD, you would be better off using a computer and connecting the cassette player to the Line In jack of the computer. You do have to make some adjustments to avoid recording the default Microphone input. Use a program like Audacity or any other audio editing program. Record the signal and divide it into tracks, if needed. Now you can filter out any distortion as well. Then save as a WAV file. Use a different program to burn the WAV files to a CD-A. (This must be burned as a mastered disc; my attempts that worked on an older CD player failed if there were gaps between the tracks. Lots of programs will do this; Roxio Creator is one option.)
The manual for the ZV427MG9 is available here: http://download.p4c.philips.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf .
I hope this helps.
Dec 31, 2012 | Magnavox Televison & Video
We can't get the volume loud enough to hear when we record to a CD
This unit is a pro unit that makes use of XLR type inputs. These are typically at +4 dBm signal level not that of the -10 from RCA type mixing boards. So what you need to do is take the RCA outputs from your source and hook them to a IHF or unbalanced to Balanced converter and they are available from MCM Electronics. This device here should take care of the problem.
http://www.mcmelectronics.com/product/555-8485
Oct 06, 2012 | Tascam Cd-rw900sl Cd Recorder/player
Ilo DVDR05 Vibration and loud humming noise
i experienced that problem before.one cause is the cd itself.there cd's that are too thick so the motor has hard time rotating that makes vibrating sound.the other ,don't put something over your unit.the cover is touching the holder of the cd and makes a sound.just do the necessary things to be done like don't put something on top your unit.if not, then a manual analysis of the tech is the last option.
May 17, 2009 | iLO DVDR05 DVD Recorder
Rotel RA01 amp - volume control
Make sure you connected your record player in the right inputs. Better try it to a line level auxilliary input that is sure to pass the volume control. hope this helps..
Sep 18, 2008 | Rotel Audio Players & Recorders
Cd rewritable player recorder tascam cdrw4u
I never had that problems. I have been using it over five years. Does it play commercially made CDs (the ones you bought at the store)? Panel shows track numbers and sound volume? Can you hear it by using a head set (phone volume control turned up? If so, now recording part, do you have input select correct (analog or digital)? Input cable(s) into right connector(s)? When you press "record" button, does it put into "pause" mode? Can you watch the incoming sound levels when it is on "pause" mode? Can you start the recording with remote's fader button or play/pause button on the machine? Good luck.
Jun 09, 2008 | Tascam CD-RW4U CD Recorder
Tascam Cd-rw900sl Cd Recorder/player Logo
101 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
