How to Remove Replace and Install Your Toshiba Qosmio X505 Laptop Keyboard
1. View the back of your Toshiba X505 Keyboard. If the laptop keyboard has screw holes, then you now you need to remove screws from the bottom base of your plastic bezel. If the keyboard does not have any screw holes, then screws are usually not required to be removed from the bottom of the laptop.
2. Now that you have determined if screws are required to be removed from your Toshiba X505 laptop keyboard, we will now pry the keyboard out using a thin object. The first step is to view the top of the keyboard area, also known as the keyboard plastic bezel. If your keyboard has a plastic bezel above your keyboard, you will need to pry it out. If you don't have a plastic bezel above your keyboard, then you can take a think object. Place the thin object between your Toshiba X505 laptop keyboard and the plastic bezel, and pry out the keyboard.
3. Now that your Toshiba X505 keyboard has been removed your will need to disconnect the Toshiba X505 keyboard cable ribbon from the motherboard. There is usually pins connected to the Toshiba X505 motherboard that need to be pushed up/down. Once the keyboard connector cable has been removed from the Toshiba X505 laptop keyboard, remove the keyboard.
4. We will now install your new Toshiba X505 laptop keyboard.
5. Reconnect the Toshiba X505 keyboard to the motherboard. Insert the Toshiba X505 Keyboard back into the motherboard. Secure the pins and push the pins in. Once your keyboard is secured, you can now aligned the keyboard with the grooves. Push the keyboard down and in place. If there is a Toshiba X505 plastic keyboard bezel, place it back in place. Secure all your Toshiba X505 laptop screws back in place.
6. That's all, you just installed your replacement notebook keyboard!
? 5:19 www.youtube.com/watch?v=F62RbnA06Fo Mar 6, 2012 - Uploaded by Jennies Garage
How to remove and install a keyboard on a Toshiba Satellitelaptop computer. ... This video should help If I ever think ofreplacing the keyboard.
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. [email protected] for any additional questions.
Bad keyboard. This series have a higher frequency of keyboard problems because ... well .. the keyboard cable got folded by design. Just replace it. The A40's uses the same keyboard as a A10, A15, A55, A60, A64, 1400, 1405, 1410, 1415, 2400, 2405, 2410, 2415 ... and many others. A new replacement keyboard should run about $20 on eBay.
Replacing the KB is easy: lift up the power button board above the keyboard, remove the three screws holding the keyboard down, then remove the keyboard connector cover panel, and you'll be able to disconnect the keyboard.
