Question about RCA VR615HF VHS VCR
Vcr plus problem
Tring to find out to use the two-digit vcr plus+ channel numbers for local tv
(local listing with the 29164 zip code) in the usa
How do I the automatic power off timer off
Posted on Dec 25, 2007
Uet-606 universal remote control code for comet tv
Just do a code search method. It will be best rather than try to get the code list to this remote control. If your remote control have pre-programmed codes for your device, this method will help you to synchronize it, and you can retrieve the code too. Procedingns are given.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
IDENTIFYING CODES FOUND USING THE SEARCH PROCEDURE
  1. Press and hold the SETUP until the LED indicator lights steadily. Release Setup button.
  2. Press the mode button that matches the equipment you want to identify. The LED blinks once.
  3. Press and release SETUP. The LED blinks once.
  4. To find the first digit, press each number button from 0 to 9 until the LED blinks. The number you pressed is the first digit of the code.
  5. Press each number button from 0 to 9 again as above to find the second digit.
  6. Press each number button from 0 to 9 again as above to find the third digit.
  7. Press each number button in turn to find the fourth digit. When the fourth digit has been found, the LED goes out.
Jun 23, 2012 | Televison & Video
Tip
Digitial channel tune in and set up
if you have a problem getting digital channels (uk) find local channel number digital uk can help enter tuning menu go to manuial tune on tv or digi box. it will ask for channel number start with highest number pess ok or search repeat for each channel number normal 4or 5 depends on aera if still not getting all channels put aerial lead which come for aerial into tv bypassing any equipment such as vcr/dvd recorder then start again if still not all channels may need aerial upgrade .if yo get all channels connect vcr/dvd if some channnels disappear need to reset RF out on vcr/dvd remove aerial .connect vcr/dvd via scart reset RF out on vcr/dvd this can be found in vcr/dvd set up menu reconnect all leads should now work ok
Note do not set RF out to any digi channel numer
on Aug 17, 2010 | Televison & Video
I got a used Toshiba CZ32T31without a user manual. When I hook up the cable all I get is snow. I also can't get local broadcast when I move the channel to the station number.
If you are in the USA, all free broadcast channels are digital, so you won't get anything without a digital converter box. In Canada, some channels are still available without the box till August 2011.
The tuner may be defective. Use a VCR or cable converter with audio/video outputs and connect them to the appropriate inputs on the TV, use the VCR or converter to change the channels.
Jan 04, 2011 | Toshiba CZ32T31 TV
Free list of codes for a magnavox mru3300
I'm not positive but these codes should work, if not try the CODE SEARCH function. I'll post the Code Search instructions first, then I'll post the Brand Codes (list is a bit long so it might take a couple of posts). Let me know if any of this helps you and I'll continue to search for a pdf type of code list for the mru3300 for you.
*CODE SEARCH
If your product does not respond after you have tried all
the codes for your brand, or if your brand is not listed,
try searching for your code by following these steps.
controlled.
2. Press and hold the CODE SEARCH button until the
red indicator stays on, then release the CODE
SEARCH button.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
channel. The red indicator blinks off with each
button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button
to backtrack through the library until the device
changes channel. Pressing CHANNEL UP changes
direction to forward again.
Most users will store VCR codes under the VCR button,
Cable codes under CABLE, etc. If (for example) you
want to store a VCR code under CABLE, first follow the
procedure for Direct Code Entry (previous page) and
press CABLE in step 2 of Direct Code Entry, then enter
follow the steps above for Code Search (or Brand
Search, below). Note: If the device does not have a
CHANNEL UP button, use PLAY (VCR only) or
POWER instead. Code Search starts from the currently
stored 4 digit number under that mode.
Dec 13, 2009 | Philips Televison & Video
HDTV CHANNEL NUMBERS
Channel numbers depend on the station, not your TV. Check the channel listings in your local paper for channel assignments.
You can also go to www.antennaweb.org and click on the "choose an antenna" button. This brings up a page that asks for your address. It wants this information to pinpoint your location, but all you need to give is your zip code. Continue through the next couple of screens and you will get a list of all the stations in your area and their distances. The channel number information is there as well.
Please take a moment to rate this solution a fixya, and thanks for asking here!
Mar 21, 2009 | Vizio L32 32 in. LCD HDTV
Hello
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
May 09, 2008 | Philips Universal PH301S Remote Control
RCA 32' colortrak plus connectiuns
If you are connecting the cable to the VCR, and using a cable TV type wire (CATV wire) from the VCR to the TV, this is not the same as an A/V connection.
The VCR should have a built in modulator. In some areas the VCR uses channel 3 or 4. In other areas they are using channel 5 or 6. You will have to refer to the user manual for the VCR to know the channel that is being used for the VCR. On some, it is written at the CATV output connector.
Turn on the VCR, and set the TV to the proper channel for the VCR. Select in the VCR's options to put its output to the CATV, or its channel output. Refer to the book on the VCR for details.
Jerry G.
Apr 20, 2008 | Televison & Video
Guide listings are incomplete
1. Manually scan all channels on your TV with your TV remote and write down the channels and network shown:
(sample: 119.2 C-SPAN2 digital channel).
2. Go to Edit Channels and find the icon for C-SPAN2 (about icon 261 in my zip code). Manually change the channel from Off to On, Insert the frequency, and optionally insert the number you want the channel to show in your channel listing ( or move it manually later).
I have about 10 to add each time I reset my recorder.
Feb 15, 2008 | Sony DHG-HDD250 200-Hours Video Recorder
RCA TV won't change channels
Your set uses the 195 series chassis and you have something set wrong in your guide plus. Go into the TV's menu and do a complete set-up. Take the remote and press MENU, then "8" to enter setup, then press "1" for "begin setup now" and then press "1" for English, and so on. You must enter "set up guide plus+", then press OK on the remote to choose "setup", select "USA", enter your zip code, and then if you choose "yes" for "do you have cable?" you MUST then choose "no" for "do you have a cable box" If you choose "yes" for that choice, your tuner will lock on one channel no matter what channel you try entering. After choosing "no" for "do you have a cable box", choose "no" for "do you have a VCR?", exit the guide plus menu and then skip the rest of the steps by pressing "2", and then exit the main menu by pressing "0". Your channels will then work normally.
Aug 29, 2007 | RCA P52937 52" Rear Projection Television
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
