Only lint filter on one side of LG washing machine is working (top loader)
The internal lint filters on each side of the drum aren't working properly. One filter seems fine and fills up, but the other one is completely empty.
  • 641 Answers
SOURCE: Drum filling with water
An obstruction in the water-inlet valve may mean that it's no longer able to shut off You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Good luck !
Posted on Sep 09, 2007
futureloginn
  • 734 Answers
SOURCE: Kitchenaid Top Loader leaks
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
TechBrian
  • 15 Answers
SOURCE: Blocked filter in Fisher & Paykel washing machine top loader
Fisher & Paykel washers do not have lint filters inside the tubs as they are designed to drain away any debris from the wash during the drain cycle.
Posted on Mar 10, 2009
  • 17 Answers
SOURCE: How do i clean out the filter for my GW711
It doesnt have one, try the following- use high quality detergent- like tide. Do a full wash with nothing in it every now and then, separate lights and darks and towels/fluffy stuff from synthetics, use a less rigorous wash- like wool or permanent press. If none of that works, ring up the manufacturer and complain
Posted on Apr 19, 2009
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Posted on Jun 19, 2010
I HAVE A WHIRLPOOL TOP LOADER MODEL 3LSR6253E01 MY WASHING COMES OUT COVERED IN LINT. I CANT FIND A FILTER ON THE MACHINE IS THERE ONE? PLEASE HELP THANKS KATE
All washing machine have lint filters to protect the pump, but they generally have quite large holes and although called 'lint' filters, they are to stop baby socks and coins getting into the pump. They are always at the bottom of the machine behind the front kick panel on a front loader or under the agitator on a top loader.
If your washing comes out covered in lint, you need to find the item that is shedding it. May also be paper tissues left in pockets. We only have one item that sheds lint and that is a bathmat. We wash it separately.
Take a look at this video.
Washer Filter Plug Kit part 285868 How To Replace
May 26, 2016 | Whirlpool Washing Machines
All cycles work but clothes come out wet, top loader model# AAV7000AWW is there a lint trap that needs cleaning?
Lint traps are in dryers, not washers If clothes still come out wet then perhaps the water pump is not working properly and/or the drum is not spinning fast enough to allow centrifugal force to remove water from clothes.
Feb 07, 2016 | Washing Machines
Where is the lint filter on a Simpson Eziset 950 top loader washer?
lint filters for simpons top loader is at the bottom of the center lift out piece in the agitator
just pull the lot up and the lint filter is a small pocket at the end of it
Dec 10, 2015 | Simpson Washing Machines
Is there a lint filter? where?
if it is a top loader the lint filter is between the basket and outter drum on the bottom of basket
Mar 08, 2010 | Kenmore Washing Machines
Black lint on white clothes after wash. have cleaned filter. is a front loader.
Check both the apron, located in front of the drum for lint residue, as well as the drum itself for sharp points (gouges) which may have snagged clothes and collected the lint to the inner side of the drum. Also try running a full cycle with no load to clear any lint which may remain in the outer (non visible) drum.
Mar 05, 2010 | Washing Machines
LG FRont Load Washer Dryer WD-1256RD filling up with lint
If you have not done it already, replace the lint filter. Follow instructions on manual. The lint filter access should be on front side of machine.
Other users had same problem on this model, I quote:
"I've only had it 2 weeks so far. It seems to be collecting lint/fluff all around the rubber door lining"
Source here.
Sometimes there may be too much lint if you use excessive softener and detergent.
Feb 08, 2009 | LG WD-12124RD Front Load Washer
Jan 13, 2009 | LG WFT1071TP Top Load Washer
Washing machine
The filter on your pump is probably clogged with lint and other stuff. Lift washer up a bit. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. Drain off excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water or a wet vac. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Nov 27, 2007 | Whirlpool GHW9150 Front Load Washer
My dryer is giving off a strong odor. Smells a little like rubber or metal on metal. It still works great. Is still getting hot and drying clothes. Can you help? Lg washung machine/dryer combo(front...
Sounds like drive belt or drum supports, if the drier is gas I would check it out, could cause a fire, if it is electric still check to make sure it is not rubbing on the electric heat element, or it could be full of lint which is catching fire during normal operation and melting or burning the belt or drum supports.
Nov 04, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
