Question about Vizio VW32L 32 in. LCD HDTV
Vizio 32lcd turns itself off on certain station
Every time i tune my tv to a certain station(39.1 CW-Houston) it turns itself off. ican watch all other channels fine but everytime i tune to that one channel it turns off.
Do a full channel scan again. It should solve that problem.
Posted on Jul 03, 2009
My Vizio VX37L HDTV won't turn on. Was watching it one day & it turned off by itself. Replaced power supply with new one with no luck. Orange light comes on but will not turn white.
reset the tv with the tv off, but plugged in hold down the soarce botton on the tv for 5 seconds it should click on and work. if not then there may be curcuit board issues. i found the same tv on the side of the road as somewone was throwing it out, it was leaning aganst their trash can. i brought it home. plugged it in and it went on and inediatly went to the orange vizio light. i rest it and it's been perfect ever since is my comoute monitor now...good luck i hope that fixes it for you..
Nov 25, 2012 | Vizio L37 Television
How do i remove the panel to get into my 47" Vizio HDTV?
The child lock on a TV can be a wonderful thing. A parent sometimes cannot be present for the duration of a kids' show, so the child lock ensures they can't watch programs that are off limits. The lock can, however, cause unwanted trouble--if it gets accidentally turned on and you don't know the code, you can find yourself unable to fully enjoy the full range of available television stations. Follow a few easy steps you'll be back to watching regular TV in no time. Instructions Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it. Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000." Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
Aug 31, 2012 | Vizio SV Televison & Video
MY VIZIO 37 INCH TV
I think you may have the same thing going on that we had happen several times, I think its stuck in RGB mode. Go to the TV itself, and turn it on manually. As SOON as you turn it on, hold the input button on the side of the TV for 30 seconds. This should get it back to the normal TV mode. We got this fix from Vizio ppl.
Jul 12, 2012 | Vizio VX37L Television
I might of hit the wrong button when i was trying to switch inputs... The screen asked for 4 number password but i never had set one. So i just turn the tv off and on but now my tv shows vizio on the...
Dear Sir:
Follow this step:
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
  • 2 Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
  • God bless you
    May 14, 2012 | Televison & Video
    I have a Vizio 55" m550nv with Lip sync issues.
    Hello
    Just do this first and determine the fault. Connect your Vozio to an external antenna, to its antenna socket, and set it to autotune. You can refer to its user manual to how to do this. Let the TV tune all transmitting stations at that time, and memmorize it. After auto tuning is complete. select the channels one by one and check if they are perfect in every respec or not. Itf they are perfect, your cable TV operator is lying. As I know, Vizio is a perfect set. Do the above and determine. If the transmitting stations are also bad, surely your TVs tuner has damaged, and should be replaced with same type and number.
    OK.
    Feb 23, 2011 | Vizio M550NV 55 in LCD HDTV
    My Visio turns itself off and on when I change to one channel
    I had the same problem. Tech support told me to turn the tv off, then unplug it. Then hold the power button (on the tv - on the bottom of left side) in for 30 seconds and try again. This did solve my problem.
    Jun 14, 2009 | Vizio VW32L 32 in. LCD HDTV
    Tuning a VCR into a digital tv set
    Switch to using the A/V (Audio, Video) connections to watch your vcr
    Dec 18, 2007 | Televison & Video
    Vizio VW32L 32 in. LCD HDTV Logo
    317 people viewed this question
    Top Vizio Televison & Video Experts
    pzarnold
    Level 1 Expert
    Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
