Question about Hilti TE 7-C 120V Rotary Hammer Drill
Hammer not working on hilti te2
Hammer not working
  • 123 Answers
SOURCE: hilti te-72 hammer failure
Do not put it in hammer mode and try to unscrew the chuck! This will break the housing internally. To remove the chuck you will have to put a chisel in the chuck. Lock that chisel in a big vice. You will then have to put a pipe wrench on the chuck to unscrew it. It is regular threads but there will be loctite on it. Once that is off your will have a spring and two roller bearings to remove before you can slide the bell off. You will then have 8 5MM screws to remove. This will remove the chuck. You will then have a snap ring to remove. After that you can remove the whole cylinder assy. More then likely your connecting rod is broken.
Posted on Oct 09, 2009
ftw1952
  • 10319 Answers
SOURCE: Hilti TE 12. It will not hammer.
the rotory cam has been broken inside if not producing the hammer effect
Posted on Mar 11, 2010
FixYaSteve
  • 57 Answers
SOURCE: how to remove sda cuck from hilti te2 110v drill
Manual for Hilti Te2 is here.
Per Page 11, "Pull the chuck release ring towards the front and remove
the chuck completely. When fitting the chuck, pull the
release ring towards the front and hold it in this position.
Push the chuck onto the guide tube as far as it will
go and release the ring. Rotate the chuck until it engages
and the ring snaps back into its original position |3|. The
TE-C interchangeable chuck or quick-release interchangeable
chuck may be tited to the TE 2-M with chuck
interface |2|."
If this helps, please vote. Thanks!
Posted on Jun 14, 2010
  • 123 Answers
SOURCE: te70 hilti hammer drill
The TE-70 is permantly lubricated. You would only add lubricant if you took the tool apart. You can add a small amount of grease to the end of your bit occasionally before putting in the chuck. This keeps the chuck parts lubed.
Posted on Jul 23, 2010
  • 123 Answers
SOURCE: Hilty TE 12 Hammer Drill Wont Hammer, but will
Parts are no longer available for the TE12. Be carefull if you try to take it apart yourself. Some of the older models had a lead based grease in them
Posted on Oct 26, 2011
Hammer drill hilti TE 10 . Hammering parts broken. Replacement require.
Check the attached links, Contact Hilti and order parts.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Innovative Solutions for Construction Professionals Hilti Canada
Results for My preferred Hilti Centers
HILTI AUTHORIZED DISTRIBUTOR AND RENTAL LOCATIONS
Hilti Tool Repair Hilti Canada
Mar 10, 2016 | Hilti Drills
Need a cooling fan for hilti hammer drill te22
Claudette,
From my experience with Hilti tools, you have to send the tool back to them for repair. I have not had much luck in getting any parts from them. Sorry!
May 07, 2015 | Hilti Drills
What hilti hammer drills use TE-C bits? I want to buy one
TE2, TE4, TE6, TE7, TE30, TE40. The 30 and 40 are only corded, (not cordless).
TE-C bits come TE-C (standard head) and TE-C3X which is a high performance bit. SDS is the industry term for this connection.
Dec 09, 2012 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
A part of my te2s side handle broke where can I find a new one
Try any tool retailer, parts for the TE10 haven't been made for a while. You should find that one of the side handles for current machines will fit.
Jun 22, 2012 | Hilti Drills
Reset service light on hilti te 706
I have one Hilti Mechie , TE 706 Avr, Now Red Light Only Blinking ,Mechine Not Working
Jun 12, 2012 | Hilti TE 70 Hammer Drill Performance...
Need locations in europe and asia for spares outlet and price for armature assy for hilti TE 2s drill - ( due to short in windings and comutator) purchased on 1981 from saudi arabia -
Go to Hilti's website and choose your country. You can find locations and parts. The TE2s was not introduced until the early 2000's. In 1981 a drill that size would have been a TE12s. If that is your model parts are no longer available through Hilti.
Dec 25, 2010 | Hilti 284228 UH 650 Universal 1/2" Hammer...
Hilti TE 17. Hammer doesnt work. Rotary does.
Most likely the O-rings are worn - tool has no compression to move the hammers inside.
Less likely: the connecting rod for the piston is broken so piston isn't moving - or 2nd hammer is broken into pieces.
I would open it up & check the orings first
Jul 31, 2010 | Hilti Drills
Hilti te2-a both battery's won't charge i haven't used it for a while but it is under 2 years old
IF you live in the US you can send it into Hilti tool repair and let them evaluate your batteries. Or you can take it to any Hilti Center to be checked out. You can call1-800-879-8000 to locate the nearest Hilti Center to you or arrange to send into tool repair.
Jul 15, 2010 | Hilti Drills
How to remove sda cuck from hilti te2 110v drill
interface |2|."
Jun 14, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
Mar 11, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti TE 7-C 120V Rotary Hammer Drill Logo
89 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
