Question about Ski-Doo 2005 Summit Fan 550
Not getting gas to fuel pump
Ice or water in gas, maybe clogged screen
  • Jeff Evon
    Jeff Evon Mar 21, 2014
    How do I change or replace the screen/filter inside the gas tank?
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 220 Answers
Make sure your hose inside the tank is not broke or cracked.
Posted on Oct 02, 2014
1995 Ford Explorer fuel pump working fuel getting to the fuel filter no gas on rail will start with starting fluid
If fuel filter is clogged no gas will reach your injectors. Or maybe the fuel pressure is not high enough due to a weak pump.
Oct 26, 2016 | 1995 Ford Explorer
I have 98 merc sable been running fine than my wife fueled up than it stop running I checked fuel pump its working what else could be the problem?
really bad fuel (lots of water), clogged fuel filter, ignition system failure
eliminate one at a time - change filter then test, check ignition components & wiring, drain fuel tank -- last resort due to danger
Go back to where she filled it up and verify what gas pump was used to fill the car --- maybe got diesel?
Feb 17, 2015 | Cars & Trucks
Fuel injector not working ford e350
Are they getting gas?... if so bad injectors maybe clogged
If no pressure to fuel rail then clogged fuel filter or bad fuel pump
Sep 02, 2014 | Ford E350 Cars & Trucks
Runs idle but stalls when give gas
Yes. Sometimes the internal screen deteriorates and clogs the fuel pump. You might want to replace the fuel filter and blow through it to see if it was clogged too.
Feb 27, 2014 | Ford Crown Victoria Cars & Trucks
Cas gerks like it is running out of gas
fuel filter or air filter
coil going bad
tune up plugs and wires
ignition module
plugged cat. converter
fuel pump clogged or dying
bad gas, maybe water mixed in
Nov 11, 2013 | 1992 Ford Crown Victoria
I recently had water and debris in my gas on my Toyota Camry 1996 2.2 4 cylander.I drained the gas tank,replaced the fuel filter,replaced spark plugs and had the injecters cleaned and it still has idel and...
Yes, sounds like some debris is getting collected at the strainer and probably clogging the fuel filter. I would change the filter first and then go from there. Maybe that would save you from dropping the fuel tank again.
Jun 11, 2011 | 1996 Toyota Camry
My car all the sudden died like it had ran out of gas. Hasn't started since. It's not the fuel pump. It's getting plenty of fuel. Not the battery. Not the starter. All of that has been ruled out. What else...
I have the same problem, Bad Fuel pump relay? Bad gas cap? defective fuel pressure regulator, water in gas- (Try Heet for the water prob)? clogged fuel filter? Crimped gas lines? Bad ignition coil?
Jan 15, 2011 | 1987 Chevrolet Celebrity
When giving gas, seems like the car is not getting gas. I am guessing either gas filter or gas line may be clogged? Maybe computer chip, not sure?
add a can of SEAFOAM(parts store) to tank of Premium fuel, and change fuel filter. EGS(ethanol gas syndrome) is affecting a lot of vehiles. It will clog lines,injectors, and filters. It also dumps water in lines, and can harm fuel pump. Try this, and add a can of SF every 3-5000 miles and it will cleans valves, fuel parts. emission and much more. best stuff invented for the corn gas we have to buy now. It sounds simple, but in the 20+ years of business, I've never seen anything like it. Good luck.
Sep 03, 2009 | 2000 Lexus Gs 300
Water leaks from the freezer area to the fridge
Check your drip pan and the nozzle of the line and see if it is dry. If it is dry you got a clog like I did.
I solved my own is the line from freezer to the drip pan was clogged with ice. Just remove the two back screws in the freezer section and melt the ice using hot water from the tap and maybe use a light pump could be a small foot pump nothing to powerful to put in the hole and pump until you see the water come through.
Aug 04, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Car wont start after bad weather freezeing water pump.
do you get a spark first then go to the next steep, follow the spark from the coil to the plugs then check to see if you are getting gas. Take off the fuel line  and turn the key,maybe  the  gas froze too then check to see if the water pump cracked  or it there are any cracks in the engine
Dec 20, 2008 | 1991 Pontiac Sunbird
Ski-Doo 2005 Summit Fan 550 Logo
398 people viewed this question
Top Ski-Doo Winter Sports Experts
Todd Arndt
Todd Arndt
ptpumpman
David Harrelson
David Harrelson
Are you a Ski-Doo Winter Sport Expert? Answer questions, earn points and help others
