Question about Dishwashers
Iag ardigo No code display on panel and washer won't start
I require a manual for a Wharfedale TV LCD1510A, I bought it 2nd hand and the manual was missing and I cant tune it in. HELP
Wharfedale stopped making TVs in 2008 after they were acquired by an international company IAG. It is unlikely you will find the manual easily except to contact IAG and ask for advise.
http://www.wharfedalepro.com/Contact/tabid/63/Default.aspx
Apr 27, 2014 | Televison & Video
Frigidaire washer won't finish cycle
Hello Ellen Greer - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly, faulty pump or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Nov 14, 2012 | Frigidaire ATF6000ES Front Load Washer
My Kenmore front load washer will not fill--it sounds like it is draining instead. The last load washed did not spin correctly and the clothes were very wet when cycle completed.
Washer Not Filling:
  • Door Not Closed and Locked
    • Front load washers won't fill if the door is not closed and locked. Listen for the door locking when starting a cycle, then pull on the door to make sure the door is closed and locked.
  • Delayed Start Feature
    • Some washers have a delay prior to filling, where the electronic control is checking the dispenser function. This is Normal.
  • Flashing Lights or Error Code on Display
    • When there is a filling issue, the washer may shut off and display one of the following codes: LF, LE, nF, IE, FH, E10 or F20.
    • If the washer is displaying one of the above error codes, then do the hard reset procedure listed below.
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
  1. Unplug or turn the circuit breaker off for 30 seconds.
  2. Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  3. Press the Pause / Cancel / Stop button twice to clear the display.
  4. Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Oct 15, 2012 | Kenmore Washing Machines
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
Sep 28, 2012 | Washing Machines
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Won't spin, code F 02
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Water will go everywhere so be ready. You need a nut driver to remove 3 screws that hold the service panel.
Video how to
Aug 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Modus One Six spare parts
You may want to check ebay, they sometimes have drivers for sale. Additionally, I would contact IAG (International Audio Group). They are the distributor for Wharfedale here in the states and may be able to help you. I also have the modus one-sixes, modus-two's, and modus center and was albe to get replacement parts from IAG, never needed a driver though. How did you blow it anyhow, these speakers can take a beating, are you using a quality amp? Underpowering the speakers and trying to drive them loudly = demise for your speakers.
May 03, 2008 | Wharfedale Modus One-Six Speaker
Dishwashers Logo
Top Dishwashers Experts
