Question about LG WFT1071TP Top Load Washer
I removed pulley and gear on drum and reassembled,now when water is poured in it runs right through drain hose.Will this mean programme is in incorrect mode?
How can drum be removed to get to coins at bottom of tub?
  • 4 Answers
LG WFT1071TP To remove coin from bottom don't open drum just open cover of drain valve coin may be out from drain valve.
Posted on Nov 13, 2015
rickzilla
  • 706 Answers
SOURCE: FUll of Bubbles and won't drain
That is the filter compartment that you accessed. I believe ( and you can verify ) that there is a short hose with a cap next to that filter that you can extend to control the drain off into a container or two. If you haven't cleaned the filter for a long time, there is a good chance that it is blocked up with junk that limits the system from draining properly. I had that problem myself. Also, these front loaders use HE detergent and Ihad been filling the detergent cup up to the mark but you because these use very little water during the wash cycle I was advised to use only a few drops... Yes drops.. and I have been and clothes come out just as clean. maybe even a bit less if you buy X2 or X3 HE detergent. Hope my bad experience with this helps you...
Regards
Posted on Jul 25, 2008
MNTECH
  • 1543 Answers
SOURCE: LG WM-2277HB washer does not drain and make rattling noise.
You will need to replace the drain pump motor. The pump impeller has separated from the motor shaft. You can push it back on, but it will just come off again. I have not tried adding adhesive because I didn't want a call back. That may work if you want to try it. To replace pump motor:
Take the rectangular recess out by using a putty knife on the left or right side, Remove phillips screws mounting pump. Pull machine forward about two feet to allow you to tilt the machine back to lean it against the wall. Reach under to access the pump. It is held in place by a plastic tab you can depress to remove, but if you break the tab, don't worry, as the mounting screws will hold your pump in place just fine when reinstalled. Remove pump by disconnecting hoses and electrical plug. Change out pump motor (three phillips head screws)
Posted on Nov 16, 2008
  • 32 Answers
SOURCE: Water will not drain from tub.
Clean out the trap from the bottom, something is jamming the drain motor
Posted on Dec 23, 2008
MNTECH
  • 1543 Answers
I would guess that the impeller has come off the pump motor shaft. You can disassemble and push it back on, but it will come off again. I don't know if some type of adhesive would work, but I just replace the pump motor.
Drain water from small drain hose (or by removing filter) Remove the screw in the plastic recess by the filter, then use a putty knife on the left or right side to pop out the recess. Remove two more screws holding pump body to front frame of washer. Pull washer about 18 inches away from wall and tilt it back to lean against wall to allow access to the pump through the large rectangular hole in the base of the washer. There is a plastic locking tab holding the pump body to the plastic washer base, but don't worry if you break that, as the screws (removed earlier) will hold the pump back on just fine. Pump motor is held onto pump body with three more screws. Replace pump motor with a new one and reassemble. On a difficulty scale of 1 -10, this one might rate a 4.5 or a 5. Not too bad.
Leaking is rarely, if ever, caused by the drain pump. Small leaks can come from using too much soap, which backs up in the dispenser area and leaks down inside the machine, or larger leaks from a cut in the door gasket.
Posted on Apr 04, 2009
canbruce75
  • 1776 Answers
SOURCE: not draining water!
Some hard object may have damaged the pump impellers. Take the hose off the pump and use a flashlight to look into the suction port on the pump. Look for anything clogging the pump and check the pump impeller for broken/missing blades and make sure that the impeller spins freely. If any blades are missing/broken or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it is just something clogging the pump. Also check the drain line for clogs while it is off the pump. Hope this helped and best wishes.
Posted on Aug 17, 2009
Water not draining away
Hello, and welcome to Fixya.
To rectify your problem do the following.
Remove the lower rear panel of washer.
Locate and remove the large black hose connected to bottom of drum.
Remove and clean plastic filter inside hose.
Reassemble and test for leaks.
Check drain hose for blockage if it still does not drain.
Feb 10, 2011 | Hotpoint WM56 Front Load Washer
My LG Front Load washer starts to wash, then when it tries to drain, it stops and shows error code OE. I checked back drain hose and they are not kinked. I removed front filter in bottome left and water...
Hi dear.OE code meaning on Lg washer's"machine unable to drain in 10minutes". You can make a little test.Please remove the filter & pour some water in side drum ,watch for water coming out of filter.If it's slow, tub to pump hose clogged.(there must be some sort of fluff or coin clogging hose)if it's not slow,waters comes out freely, run machine on drain cycle & check the pump motor is it running smoothly?If not change the pump.I hope that helps.Thanks.
Aug 23, 2010 | LG WM2487H Front Load Washer
It is a Bosch WFF2000. The programme stopped mid
circle at bottom right take it off there is a filter there remove it and look of obstructions.WATER WILL POURE OUT!
Jun 23, 2010 | Washing Machines
Samsung vrt washer will begin cycle but get so far then just stop and wont spin or drain water. You can restart the load to get the washer to start again but will do the same thing again.
You might have an object jammed in the pump housing. First thing you must do is to unplug the machine from the power outlet.You will then need to remove the back panel of the washer to access the pump. Disconnect the wiring from the pump and remove the two hoses by compressing the two clamps. ( Be ready for water to pour out of the hoses) Remove the three mounting bolts that hold the pump to the frame of the washer and remove the pump assembly. It is easier to work on the pump if you remove it from the mounting plate. Remove the three screws that hold the impeller housing to the pump motor. Seperate the two parts being careful not to damage the rubber o-ring that seals the unit. Inspect the impeller housing for any debris. (I found a nickle blocking the outlet port in mine). Remove anything you may find and reassemble in reverse order. The machine should reset itself and run as normal.
Jan 08, 2010 | Samsung WF203ANW Front Load Washer
Drum wont turn water wont drain checked pump suspect frost indrain hose inside washer drain pipe seems crunchy
Your probably on the right track,if you can expose the drain pipe to heat to melt frozen portion would be an idea or you could pour hot water back the drain hose(at its outlet) to melt the water in front of it-thats the most obvious thing first anyway,small socks are a nuisance also getting clogged in drain at exit from drum to drain pump
Jan 08, 2010 | Indesit W 123 Front Load Washer
My washing machine will not spin and drain the water out
if it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Dec 03, 2009 | GE WBSR3140DW Top Load Washer
Bosch WFF1800 - not spinning
HI,
move the kicking plate on the front-bottom of the machine. You will see o circular lid there, turn it on anti-clockvise to open. All of the water blocked will come from there, be careful. Look carefully that there are some objects blocking the water draining. Then turn on the machine on draining programme, the plastic rotor should turn fastly when the machine is on. If it is not running, change the pump motor. If it is running, but machine is not draining again you can understand that there is an objeck stuck on the hose between drum and pump motor. Lay down the machine on its rear facade, you will see a large and black hose between drum and pump motor. When you remove it, you will see that there is something that blocks water running.
thank you for using fixya,rate my answer,
vijay
Oct 04, 2009 | Bosch Exxcel WFO 2465 Front Load Washer
F9/FA Whirlpool 6th sense frontloader washer
F09 is "overflow failure" - check drain pump, pressure switch, blocked drain.
FA is the emergency shutoff switch that detects when water is pooling underneath the machine.
May 22, 2008 | Whirlpool AWM8143 Front Load Washer
Miele Premier Novo Washing Machine: Water coming straight out of the machine
The lower left panel is a filter that should be cleaned out regularly - the filter is also connected to the drain pump which rids the washer of the water. When you clean the filter out - make sure you have a bowl or Tupperware handy that holds about 2 quarts - slowly remove the filter and the water will drain into the bowl. Clean out any debris and reassemble. If the filter is not seating properly in its seat - water will leak from the small hose - the filter is what blocks the water from coming out of the hose.
Apr 05, 2008 | Miele Novotronic Premier 500 Front Load...
Maytag front load washer leaking water from detergent dispenser
The other end of the dispenser to outer drum hose only connects to the outer drum and if you remove the top cover of the machine, you will see it clearly. You can unclamp the hose from the bottom of the dispenser and feel inside the hose for any obstruction. Do not remove the hose from the outer drum. Pour some hot water down the hose and squeeze the hose from top to bottom to remove build up of detergent and softener on the inside walls of the hose.
Oct 28, 2007 | Maytag MAH6500 Neptune Front Loading...
LG WFT1071TP Top Load Washer Logo
60 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
