Question about Pioneer VSX-D710S Receiver
How can I connect an analog turntable to my Pioneer VSX-D710S? Also, do I need a turntable with a built in pre-amp?
Pioneer VSX-D710S and turntable?
    Champion:
    New Friend:
  • 231 Answers
"How can I connect an analog turntable to my Pioneer VSX-D710S?"
Via a turntable pre-amp to one of your LINE-IN jacks.
Also, do I need a turntable with a built in pre-amp?"
Separate or built in ... it doesn't matter. Decent quality does.
Posted on Apr 20, 2014
  • 76 Answers
According to the specs there aren't any phono inputs which would have their own preamp. Everything else is line level so I'm pretty sure you'll need a preamp either between the turntable and one of the line level inputs or built into the turntable.
Posted on Mar 25, 2014
  • Greg Bennett
    Greg Bennett Apr 20, 2014
    Thanks guys! I bought a turntable with built in pre-amp and it works fine now.
dunnbiker
  • 8546 Answers
SOURCE: I want to connect a
It doesn't really have one. The DVR-Out (or any other available Line-Out) COULD provide a mixed-down analog stereo program but it won't be volume controllable from the VSX and it won't be Front-Channel specific. Sorry.
You would then connect the EQ between the chosen Line Out and the amp input. If you had a Pre-Our you would just run speaker assignment, levels, etc and have fun. With a Line Out feed you will have to ride herd on the 901 volume via its dedicated amp controls. Bummer. My older VSX-36TX allows me to have the right setup.
Posted on Mar 31, 2011
  • 30 Answers
SOURCE: Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
Posted on Aug 02, 2009
SOURCE: I have a VSX D710S and it flashes poweroff then
Im having this same problem. It happened after I had the music up really loud for about 3 hours. Also, where it has the volume all i see is -- instead of a number when i try to turn it on
Posted on Jan 07, 2010
SOURCE: pioneer vsx-305 need wiring diagram for this
I have problem with connecting subwoofer to receiver.
Posted on Jan 28, 2010
I just want to know if I can run a turntable through this unit
You can connect some turntables to the VSX-54TX. The turntable needs to have a built-in phono equalizer; then you can connect it to the Line In connection. See page 26 of the manual for the details. The manual is available on the Pioneer product page: http://www.pioneerelectronics.com/PUSA/Home/AV-Receivers/Elite+Receivers/VSX-54TX in the Manuals & Brochures section. The current direct link to the manual is http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/128163968VSX-54TX%20OPERATING%20INSTRUCTIONS.pdf .
I hope this helps. If you post a comment with the model of the turntable, I may be able to help identify if it has the built-in equalizer.
Nov 17, 2015 | Pioneer VSX-54TX Receiver
Pioneer VSX-D810X
Depends on the turntable. Your turntable would need to have a built-in preamp in order to work.
Apr 23, 2013 | Audio Players & Recorders
Hooking up phonograph to Pioneer VSX-D498
You'll need a phono pre amp and then you can connect to aux inputs.
http://www.google.com/search?q=phono+pre+amp&rlz=1C1CHMO_enUS514US515&aq=f&oq=phono+pre+amp&sourceid=chrome&ie=UTF-8#q=phono+pre+amp&hl=en&tbo=u&rlz=1C1CHMO_enUS514US515&source=univ&tbm=shop&sa=X&ei=Kv_2UMatJoOc9QSDr4CoAg&ved=0CGQQsxg&bav=on.2,or.r_gc.r_pw.r_qf.&bvm=bv.41018144,d.eWU&fp=a656d84bcd78ba72&biw=1360&bih=643
Jan 16, 2013 | Pioneer VSX-D498 Receiver
My pioneer pl-200 doesn't play loud enough through my pioneer vsx-521-k receiver
The PL-200 has no pre amp and your VSX-521 has no phono input. You need an RIAA preamp.
Jul 11, 2017 | Pioneer Vsx-521-k 5.1 Channel A/v Home...
How do i connect a pioneer pl-630 turntable to a pioneer vsx-1919ah receiver
Are you meaning it doesn't have a connection for a turntable, just aux connections etc?
Check if it has a magnetic cartridge pre-amp first, if it doesn't you can get one just put the words: magnetic cartridge pre-amp, into Google to find one. Once you get it that will plug into an aux socket and the turntable into that, so you can hear the sound.
Nov 13, 2010 | Pioneer Audio Players & Recorders
Turntable
Hi Harpwailer,
I was unable to locate an owner's manual for VSX-D412 on the Pioneer website. I did find a VSX-D411, which I believe is very similar. Since there are no turntable jacks, I would try any set of open analog (RCA cable, like the ones that come out of your turntable and are probably red and white) jacks. Just plug the red cable into the red input jack, and the white into the white. The only thing to be careful of is to make sure that you use the input jacks, since some components (like tape decks) have input and output jacks, so that you can record to/from them.
This will work fine assuming that the output from your turntable is strong enough. Many turntables are designed to go through a pre-amp circuit; if this is the case with yours, you'll know it since the output volume will be very low, even when turned up very high. If this is the case, you'll need to purchase a pre-amp to put in the circuit between your turntable and the receiver, or else buy another turntable that outputs at a higher level (they can still be had rather inexpensively, surprisingly enough!). Also, you'll probably have a ground wire coming out from your turntable as well. You'll need to hook it to a chassis screw on the amp to prevent an electrical hum from being picked up and output through your speakers.
I hope this helps, and good luck listening to your vinyl. If you deem it appropriate, I would appreciate a rating on the help I have provided. Thanks!
Bob
Aug 26, 2008 | Pioneer VSX-D412 Receiver
Pioneer VSX-D710S Receiver Logo
524 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
