Question about Magimix 3200 Food Processor
Please help, the cutting disc extension spindle is stuck in my machine after grating cheese and zucchini. This has never happened before. How do we release it to remove the spindle/extension from th
There was a slight noise when I started grating but the food processed well.
How do I freeze zucchini
The best way to freeze zucchini is to blanch it first. This allows it to stay firm and green in your freezer bags, while locking in nutrients.
  • Wash your zucchini and remove tops and any bad spots.
  • Cut zucchini into slices or strips.
  • Bring a pot of water to a full boil. Add the zucchini to the water. Leave in for 1 minute only.
  • Quickly remove it, and plunge it into a bowl of ice water. This keeps it from becoming limp and will stop the blanching process.
  • Pat dry until no water remains on zucchini. Excess water causes freezer burn and frost inside your bags.
  • Store in freezer bags according to size you want, making sure that all air is pressed out of the bag before sealing.
  • Mark bags with date, and you are done.
Jul 03, 2014 | KitchenAid KFP760 12 Cups Food Processor
The extension post in my magimix 4200 is stuck on the motor shaft seems like It's welded on can anyone help
How to Change a Magimix Food processor plastic spindle.
This is meant as a guide only BBS ltd takes no responsibility for any damage done. We always advise that this should be done by a Magimix approved service agent.
The spindle is the part that sticks out of the motor this drives the blades, knifes, discs and cones for the food processor, this part may become worn after time or use.
Cover the main body with a cloth so as not to damage the look of the food processing machine.
Place two blocks of wood about 10cms either side of spindle cover. Then place two flat screwdrivers Horizontal either side of Magimix food processor spindle
Push down on handle of screwdrivers apply even pressure (keeping eyes well away from the spindle cover, they can fly off fast sometimes.)
The spindle will rise.
This will leave the metal centre shaft, Replace with a spindle cover bought from
www.magimix-spares.co.uk. Make sure you choose correct model, usually named on front of machine, or phone 01252 727755 for help.
When replacing, make sure that the New Food processor spindle is lined up and slide the spindle onto the centre shaft. Make sure this goes all the way down by gently tapping with a hammer.
All blades and attachments should be checked before placing back onto spindle cover, if the inside is damaged, this could damage the spindle cover again, any blade, dough blade , disc support that is marked should be replaced.
BBS Limited is the approved and dedicated supplier of Magimix parts & accessories for all Magimix products.
Please telephone +44 (0) 1252 727755 or fax +44 (0) 1252 727766 for help or advice. All images and text are Copyright (c) 2008 BBS Limited.
Magimix Spares Parts from BBS Ltd
Apr 03, 2014 | Food Processors
Can I freeze zucchini in large chucks
Just do not blanch first, this makes it sticky when defrosted.
Cut into pieces, place in heavy-duty freezer bag and draw out the air before sealing the bag. To use, wait for defrosting before opening packet.
Nov 07, 2013 | KitchenAid KFP760 12 Cups Food Processor
Haw can i use ?
My food processor is one of my most-used appliances. I just got a new Cuisinart (at Costco - with an extra workbowl!) and use it at least twice a week. I grate cheeses like cheddar or swiss, pulverize parmesan, make bread crumbs, hummus, pesto, salsa... I make pasta dough in it before rolling out in my Kitchenaid pasta attachment. Pie crusts come together in a flash. And it's great during the holidays for chopping nuts and certain cookie doughs. I've chopped my own beef for burgers, etc, etc. I keep it in a cabinet but it's easy to pull out whenever I need it. And there are only 2 of us at home.
By the way, the blades are so sharp in the new machine that I cut my finger trying to clear something from the blade. I'll use a spatula next time!
ford performance chips.
May 25, 2012 | Food Processors
Grating
Any of the disc blades require the use of the detachable stem. The official "Fine Grating Disc" (which doesn't normally come supplied with the food processor) is mainly for grating cheese, but the shredder disc that comes supplied with the food processor will do the job for you.
Here is a link to the manual:
http://www.cuisinart.com/share/man/57_man.pdf
-Tha Mp3 Doctor
Apr 25, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Disc stem stuck...can't pull it off.
Hey I had the same problem. This may sound primitive and stupid but it worked. Give the stem a good whack with a wooden spoon all the way around, it will come off.
Apr 13, 2009 | KitchenAid KFP750 Food Processor
Magimix sytem cuisine
Jul 02, 2008 | Magimix 5100 Cuisine Systeme Food...
Lid of food processor
i am also having the same problem. it happened as soon as i got done putting in some parmesan and grated it. never happened before and i've got a few cups of parmesan cheese just sorta wasting away inside the processor. very tempted to break the damn thing open and just buy a new processor from a different company.
Dec 01, 2007 | KitchenAid KFP670 Ultra Power Food...
Magimix 3200 Food Processor Logo
Top Magimix Food Processors Experts
Ross Keen
richie46
Are you a Magimix Food Processor Expert? Answer questions, earn points and help others
