Ricoh 240w with constant SC 401 ID Sensor error
The ricoh 240w on start up goes into a self cleaning mode then finally stops and shows a SC401 ID sensor error code.I have switched off the sensor in diagnostics but no change.Help. Denis.
2 Suggested Answers
  • 393 Answers
SOURCE: error code sc 460 on
It is a DC seperation corona error, open up the unit (like a ****) and check for paper clip or other such stuff on/around the long wire on the lower part of the printer otherwise call for service, sorry. -Carl
Posted on Nov 15, 2010
Error Code SC 401
1. Check the transfer unit is set correctly.
2. Check the transfer roller is set correctly.
3. Check the high voltage supply board is set correctly.
4. Check the harness of the high voltage supply board.
5. Call a Ricoh Service tech.
Aug 14, 2014 | Ricoh Aficio Mp 3352 B&w Copier
I have a ricoh aficio 2035 and there is error code sc 350, what can i do ?
SC 350 relates to problem of ID or image density sensor, first of all clean it with IP and check if problem persists go to SP mode and check in input check under modes,replace sensor if found defective,if problem resolves but recurs again check for toner flying and developer and drum life, chances of sensor failure are very less.
May 05, 2014 | Ricoh Aficio 2015 Copier
Service code 385
ID sensor adjustment error during process control self-check (this check happens when you switch on). Most likely cause is a dirty ID sensor, but there are other possible reasons. Start by cleaning the ID sensor and see how it goes from there.
Nov 20, 2013 | Ricoh Aficio CL1000N Printer
Ricoh W2400 error SC401
The machine has a dirty ID sensor that must be cleaned. It can be cleaned without removing anything from the machine if you are very careful. Open the clamshell to access the drum area. The sensor is located in the middle of the guide plate on the front side of the drum. If you can get a soft cloth between that guide and the drum, wipe that section very carefully.
Feb 23, 2011 | Ricoh - RW-240 Print Controller - 411737
Error sc385 ricoh 6513
SC385: Vsg Adjustment Error
The LCD displays SC385 when the output from the ID sensor is found to be
outside 1.8 ± 0.05 V during Vsg adjustment.
Turning the power off then on resets this condition. However, SC385 is lit again after the end of each copy job even when this SC condition is reset by turning the power off then on. Toner is still supplied, but using fixed supply mode, until a subsequent Vsg adjustment is successful.
For Starters
· Dirty ID sensor
· Poor connection of connector
· Defective ID sensor
· Poor cleaning
1. Clean the ID sensor.
2. Check if the sensor connector is properly connected.
3. Replace the ID sensor.
4. Check the drum cleaning unit.
Dec 20, 2009 | Ricoh Office Equipment & Supplies
Function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Good luck and please rate me, thanks.
Mar 02, 2009 | Ricoh Aficio AP3800C Laser Printer
Error code sc 387 on my Ricoh Aficio 4006
You'll need a tech to run a diagnostic mode to find the exact cause...could be development problem, Transfer belt, ID sensor, etc
Feb 22, 2009 | Ricoh Aficio 450 Copier
I have a ricoh aficio 450 and there is error code sc 350 - 01 apperes , what can i do ?
First of all never touch the optics section of a 450 will give you SC101
I got three solutions for you.
Take out the Drum Unit, and locate it in the machine its on the top facing the drum.
2. Go to SP Mode. Clear Modes enter 1 0 7 press clear/stop for 4 seconds. enter 1, enter 3001-2 and execute, exit SP Mode.
3. Or Some developer is missing.
Nov 10, 2008 | Ricoh Aficio 450 Copier
Error code sc 101.... sc 350
SC101 Scan Lamp Error
SC350 ID sensor pattern test error
Your scanner should be checked by a technician to determine what is causing the error. There isn't any calibration or troubleshooting that can be done unless you have scanner parts.
Aug 21, 2008 | Office Equipment & Supplies
Ricoh copier aficio 401 error sc 419
hi im jules_09.
sc 401 means transfer roller leak error.a transfer current leaksignal is detected.posible causes is 1.transfer power pack is defective 2.poor connection between the transfer terminal and the trnsfer power pack
sc 419 mean quenching lamperor.1 quenching lamp defective 2.poor conection between power pack and quenching lamp.
check all component but pay attetion to the current leak at the transfer because there both connected at the power pack
Nov 01, 2007 | Office Equipment & Supplies
jasbo
jasbo
