Question about Magimix 3200 Food Processor
Disc Support/extension is stuck in machine
Please help, we are unable to remove the disc support/extension from the machine after processing/grating hard cheese and zucchini. This is the first time this has happened. Have put a couple of drops of oil on the spindle but still no joy.
How do I remove shredding disc from center of plastic bowl. 1st time in 37 yrs it is entirely stuck.
wow didn't know they lasted that long . but get some really good gloves and try turning the opposite direction that they cut and pull outward toward you .
Feb 14, 2015 | Food Processors
The extension post in my magimix 4200 is stuck on the motor shaft seems like It's welded on can anyone help
How to Change a Magimix Food processor plastic spindle.
This is meant as a guide only BBS ltd takes no responsibility for any damage done. We always advise that this should be done by a Magimix approved service agent.
The spindle is the part that sticks out of the motor this drives the blades, knifes, discs and cones for the food processor, this part may become worn after time or use.
Cover the main body with a cloth so as not to damage the look of the food processing machine.
Place two blocks of wood about 10cms either side of spindle cover. Then place two flat screwdrivers Horizontal either side of Magimix food processor spindle
Push down on handle of screwdrivers apply even pressure (keeping eyes well away from the spindle cover, they can fly off fast sometimes.)
The spindle will rise.
This will leave the metal centre shaft, Replace with a spindle cover bought from
www.magimix-spares.co.uk. Make sure you choose correct model, usually named on front of machine, or phone 01252 727755 for help.
When replacing, make sure that the New Food processor spindle is lined up and slide the spindle onto the centre shaft. Make sure this goes all the way down by gently tapping with a hammer.
All blades and attachments should be checked before placing back onto spindle cover, if the inside is damaged, this could damage the spindle cover again, any blade, dough blade , disc support that is marked should be replaced.
BBS Limited is the approved and dedicated supplier of Magimix parts & accessories for all Magimix products.
Please telephone +44 (0) 1252 727755 or fax +44 (0) 1252 727766 for help or advice. All images and text are Copyright (c) 2008 BBS Limited.
Magimix Spares Parts from BBS Ltd
Apr 03, 2014 | Food Processors
Cuisinart DLC-7--blade stuck--cannot remove from bowl.
First off, is it a BLADE that's stuck, or a DISC?
If it's a disc, and the disc is blocking your access to the center post, put a ziploc baggie full of ice on top of the disc (right in the middle) and let it sit for about half an hour. That should shrink the plastic enough to pop it out.
If it's a blade, you can try the ice trick, or you can try Pam (or another food grade cooking spray) to loosen it up, and then just try to take the workbowl off like you usually would (aka, DO NOT grab the blade, or you'll risk cutting yourself--you can just pull up on the bowl, and the blade should pop off.
If you need further help, you can always contact Cuisinart--their phone number (according to their website, www.cuisinart.com ) is 1 800 726 0190
Good luck! :)
Aug 31, 2009 | Food Processors
I need a blade holder disc no. m52ep006wht for a
I have a La Machine that I just broke the Disc Adapter on and found out it is now discontinued, so I can't get a replacement part on. So I will sell you the blade holder if you want.
Aug 05, 2009 | Regal Ware K813BK La Machine Food...
Grating
Any of the disc blades require the use of the detachable stem. The official "Fine Grating Disc" (which doesn't normally come supplied with the food processor) is mainly for grating cheese, but the shredder disc that comes supplied with the food processor will do the job for you.
Here is a link to the manual:
http://www.cuisinart.com/share/man/57_man.pdf
-Tha Mp3 Doctor
Apr 25, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Disc stem stuck...can't pull it off.
Hey I had the same problem. This may sound primitive and stupid but it worked. Give the stem a good whack with a wooden spoon all the way around, it will come off.
Apr 13, 2009 | KitchenAid KFP750 Food Processor
Grater/slicer doesn't spin on my Cuisinart BFP-703 food processor
The gear box spidle operates the regular s-shaped blade as well as the grating/slicing disc. Does the s-shaped chopping/grinding disc still spin? If not, you can get a new gear box. If it does spin, replace the grating/slicing disc - because the plastic may be cracked, as you say. All of these parts are still available from Cuisinart, so I'm not sure why they weren't any help - I've always been able to order from them.
-Tha Mp3 Doctor
Feb 01, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
I am unable to remove the disc stem
There is no mechanism to lock the stem onto the base of the KFP750. It's just held on by gravity, so you're not missing anything simple!
It's possible that the soap dust got in there and glued in on. Take a blow dryer or very hot rag (use tongs!) to the stem to see if you can soften the soap, then pull up the stem.
Dec 26, 2008 | KitchenAid KFP750 Food Processor
Magimix 3200 Food Processor Logo
Top Magimix Food Processors Experts
Oloyede Monsuru
ray gallant
Are you a Magimix Food Processor Expert? Answer questions, earn points and help others
