Question about Sharp FO 77 Roll paper Thermal Fax
When i try to photocopy document using Sharp facsimile machines fo-77, the copied document become full black.
marked
  • 6487 Answers
SOURCE: Sharp Model FO-4700 Facsimile,
If a beep sound is not made when you press the keys, turn off the power switch and then turn it on again after 5 minutes.
Hope that helps.........
Posted on Sep 05, 2008
leroyal
  • 2120 Answers
SOURCE: Sharp Compact Copier Model #Z-77.
L means a Laser Unit problem. Try unplugging the power cord for 10 seconds.
Posted on Nov 07, 2008
  • 48 Answers
SOURCE: sharp fo 4700 display error ( polygon )
You have a bad printhead unit(laser unit) . The polygon mirror is not rotating within a specific amount of time. I recommend you to replace your fax unless your willing to spend between 200 to 500 dollars.
Posted on May 25, 2009
  • 48 Answers
SOURCE: Sharp FO-4650 fax machine
You have a bad printhead unit(laser unit) only if the problem persist. The polygon mirror is not rotating within a specific amount of time.
El Geek
  • 149 Answers
SOURCE: no manual for my Sharp FO 880
http://www.usersmanualguide.com/sharp/faxes/fo-880 Enjoy... I just downloaded it and the link is working. Have fun. -Carlos:
Posted on Jun 13, 2009
Sharp FO-2081 clear memory full
enter simulation mode using # * c * after you are in run test command 66-10
I’m happy to help further over the phone at https://www.6ya.com/expert/ethan_e84416e0b13809d2
Apr 08, 2014 | Sharp FO-2081 Copier
Trying to copy a document, but it only copies 1/4 of page and exits the document. Any suggestions
There is a dirty sensor in the transport of the original document.
The only one solution is to clean the sensors.
Thanks.
Feb 25, 2011 | Sharp FO 1460 Plain Paper Thermal transfer...
Sharp Photocopier 2114 makes all black copies
OPEN top cover make a copy see if copy exposure lamp turns on or not
May 25, 2010 | Sharp AR-5320 Black and White Copier
I am using sharp facsimile model FO-P610 for the past two years.Recently,the machine gives problem of noisy noise from ear piece each time I want to make speaker on dial.I have checked with Telecom...
In 45 years I havenever seen a bad fax modem.....it's a noisy phone line problem.
I would take the fax machine to a different location and try with a different phone number.
Mar 21, 2010 | Sharp Office Equipment & Supplies
I have an epson DX4050. I currently have a full blank ink cartridge but have one empty colour catridge and 2 other colour catridges which are running low. I want to photocopy a peice of document in black...
First, using B & W to copy a photo will cause large black blotches.
B & W are actually made up of shades of Black. To get the best quality for a B & W photo, switch to "Grayscale"
Next, is the black cartridge full? Are you using any type of refilled (absolutely worst possible choice) or a third party cartridge (second worst possible choice).
Feb 27, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Hello, I have a little used 18 mth old Sharp FO P610 fax machine. It receives fine but when sending the recipient receives 'black all over' pages. I have tried disconnecting the unit for an hour and...
Try just making a copy and see if you have the black lines on your copy (most fax machines have a basic copy function if it is you have dirty scan glass and on these small machines it is a real hassle to get too and clean Try Canned Air. If no black line on your copy it may be the recipients machine.
Aug 12, 2008 | Sharp Office Equipment & Supplies
RE: SENDING FAX
The scanner glass is dirty or needs replacement. lift up the scanner door where you put original in. See the glass strip 1/2 inch by about 8 inches. clean with alchohol good. dry. test. Lawrence
Jul 18, 2008 | Sharp FO 77 Roll paper Thermal Fax
Transaction report
if you go here http://www.sharp.ca/manuals/default2.asp you will find the download of the op manual for that Facsimile Machine.
May 27, 2008 | Sharp FO 3150 Plain Paper Laser Fax
Sharp sf2116 (lanier6716) photocopier
You can get a service manual at justmanuals.com
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 03, 2007 | Sharp AL 1215 Black and White Copier
The document feeder keeps trying to feed
You have a bad Document transfer sensor. Sensor is located under the doc. transfer roller.
Nov 15, 2006 | Sharp FO 6600 Plain Paper Laser Fax
Sharp FO 77 Roll paper Thermal Fax Logo
15 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
