Question about Reliable Empressa S330 Digital Steam Press Iron
Reliable empressa iron won't turn on
Reliabl empressa will not start
Leaking and no steam
If you live in a "hard-water" region, that poor mop just might by now be afflicted with plugged steam channels and/or orifices. Someone might want to try running a cup or two of White Vinegar through the thing under presure from the heat - vinegar treatment reliably dissolves scale and opens passages in Steam Irons and Espresso Machines, so why not with this appliance too?
Just sayin'; ymmv. But try it; your mop just might LIKE it! What have you got to lose? And that is all. 0{;-)o[
Aug 15, 2013 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My iron won't get hot
it is possible that the element has burnt out or a fuse in the actual wall plug that has fused and needs replacing.
Sep 15, 2011 | Vacuums
How to clean base of iron only 6 months old
If it has a non-stick sole plate: 1. heat 1 tablespoon each of vinegar and salt to boiling and then let cool - you want the salt to dissolve. 2. Use a nylon scrubbie that won't scratch and remove deposits/scorch areas with the solution. 3. If your iron is non-stick, it is supposed to be self cleaning. Happy Ironing.
Jul 25, 2011 | Vacuums
I have a SIMAC steam iron that isn't performing well at the moment. I think it needs descaling as it is making a large whistling sound when I turn it on and it has heated up. Can someone tell me what...
To clean the reservoir of your iron, pour a solution that is one part vinegar to one part water in. Turn the iron on. Allow it to steam for about four minutes. Drain the iron for an hour, and be sure to repeat the process with clean water before you iron any clothing items.
Jun 20, 2011 | Vacuums
Iron shuts off intermittently during use, therefore it won't steam. Before we go any further does this site charge for this service?
No charge for my answer, but you can contact an Expert on this type of appliances and discuss it further.
Jun 20, 2011 | Rowenta Vacuums
Often when ironing, the iron{tefal aquaspeed 160] will spit dirty water on whatever I'm ironing.are you supposed to use botled water in iron?Aren't tefal irons made for tap water?Also how do you stop iron...
Try using CLR cleaner, if not just buy a new one, and keep the receipt for a return down the road, these iron's are reasonable nowadays.
Apr 25, 2011 | Vacuums
How do I clean my iron?
I am assuming that you have scale or lime build up on your iron. Make a solution of half white vinegar and half distilled water. Pour it in the water container on your iron. Turn your iron on its highest setting and set for steam. Wait about 15 minutes and turn off the iron. When water cools pour off the remaining water/vinegar solution. Fill the iron with distilled water and turn on. Let it heat and then cool then pour off that solution. Do this till the poured off water runs clear. If you have scale on the bottom of the iron you can clean that with an old toothbrush dipped into warm white vinegar. There may be easier ways to do this but this is eco friendly and it works the best of anything I have tried.
Apr 08, 2011 | Vacuums
How to clean sunbeam ultra 60 platinum iron. Can't find instruction booklet!!!!!
Do you mean the Sunbeam Ultura 60 Platinum iron? Wipe the exterior of the iron with a damp soft cloth and then dry the iron. To clean the steam valve, turn the Steam/Dry dial to Clean so that the tip pops up. Gently scrub the tip of the valve with a steel wool pad moistened with warm water. Rinse and dry with a soft cloth. Replace the valve and turn clockwise to lock into place (reset the dial to Dry when storing the iron). Clean the steam holes of any build up, use a cotton wool tip moistened with methylated spirits. The teflon plate should be cleaned with the damp soft cloth, just like the rest of the exterior of the iron. If you have ironed a polyester that melted onto the iron, then iron a damp cotton cloth when the iron is hot.
The manual for several Ultura irons, including the 60, is available here: http://www.sunbeam.com.au/Pages/Browse/ProductDetail.aspx?pid=1485 . The link for the manual is in the center of the page above the Image Gallery.
I hope this helps.
Mar 06, 2011 | Sunbeam Vacuums
I was getting ready to iron a pair of pants that were polyesterrayon and 4% spandex. I thought I had my Rowenta iron turned down low enough but when I placed the iron on the pants they melted. Well...
First, UNPLUG THE IRON. DO THIS PART COLD. Clean the soleplate with scotch brite and WD-40. Next, you will have to remove the WD-40 residue from the soleplate with something like windex. Make sure you get around the steam holes.
Next-Plug it in and fill it with 50-50 mix of water and white vinegar. Set it for steam and let it run through. Refill it with plain water and steam it out again, until there is NO VINEGAR SMELL. This will clean the deposits out of the tank and steam vents.
Jul 04, 2010 | Vacuums
Theres water pouring out of my t fal iron's little holes when I begin to iron my shirt...why!
The iron needs to be cleaned as I have just discovered myself. I have a hinari and the instructions are as follows. Fill the water tank and turn the iron on to medium. When heated press the steam button and hold it over the sink or a container so that the water can run out of it. It will take sediments with it. The cleaning of the iron should be carried out once a month.
I experienced the same trouble and carried out the instructions and all is well again.
Jun 28, 2010 | Vacuums
Reliable Empressa S330 Digital Steam Press Iron Logo
54 people viewed this question
Top Reliable Vacuums Experts
JoeVacs
Are you a Reliable Vacuum Expert? Answer questions, earn points and help others
