Question about Samsung LN-S3241D 32 in.LCD HDTV
Slyvania flat screen tv will not turn on?
My slyvania flat screen screen tv mode numver ld320ss1 will not turn on! whenever i hit the power on button the light will only blink twice then it goess into the standby mode why?
    Top Expert:
  • Samsung Master
  • 75,178 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Posted on Mar 21, 2014
SOURCE: can't turn on tv
Unplug the tv for 30 and plug back in.
Posted on May 31, 2008
SOURCE: Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Posted on Oct 29, 2008
  • 188 Answers
SOURCE: power light keeps blinking and power will not turn
Check back light inverter,if ok then check the 12V and 5V line,if not OK probably the IC in the power supply is defect ( F9222 )
Posted on Jul 20, 2009
  • 7 Answers
SOURCE: 26" Samsung flatscreen LCD doesn't power up
Just to be a little more detailed, since I just fixed this problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Posted on Sep 25, 2009
  • 610 Answers
SOURCE: Television will not power on
It sounds like the power supply board has some blown capacitors on it, very commen problem. Samsung is covering the cost to repair it for certain models. You can call 1-800-samsung to find out if it is covered and if not they will tell you the nearest service center.
Posted on May 21, 2010
My Sony Bravia TV - Model #: kdl-52z5100 no longer powers on. There's a red light that blinks twice whenever I attempt to power it on. Please help
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Jul 30, 2016 | Sony KDL-52Z5100 LCD TV
Hitachi l37v01ua won't turn on from standby mode.....HELP!!!!
when in stand-by mode then red light's blinking. Try to turn it on not from remote but by pushing a button on the set.
Apr 26, 2015 | Televison & Video
I got a used LCD1932 Lloyd's TV/Monitor. The top has a standby button, turns it on, but u hit same button to turn it off, it has red standby light that stays on, does that mean it's always on standby
It's normal; if the set do not show a screen at this time. The red light indicates that the set is in standby mode, and it will off, when you hit the standby button again, and the scree will get live.
Oct 15, 2014 | Televison & Video
My Sylvania tv model number LD320SS1 screen is flashing red, blue, white screen when you turn it on
Fault with the main power supply regulator board.
Check and replace damaged component/s at its main power regulator [SMPS] section circuit.Contact any service technician.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Aug 05, 2014 | Televison & Video
Sony Bravia stuck on Bravia screen
"Bravia Screen". Not sure what you mean. Is it in maintenance mode?
Option 1.. With the tv plugged in and the power OFF (this is called standby mode) take your remote (make sure it has fresh batteries) follow this sequence on the remote. You have to press the buttons within a second of each other in this order:
DISPLAY - 5 - VOLUME + TV POWER.
When the screen comes on hit JUMP right away and it puts you into a little screen for maintenance. Simply turn off the television to exit maintenance mode.
2. If your remote is bad, ie, new batteries don't fix it, might suggest a new one.
3. If you can't get a new remote, power on the television using the power button and then hit the menu button. Use the up and down keys to see if you are stuck in some weird screen or something.
4. If you are connecting something to the television (like a dvd, a playstation, computer, etc) try unplugging everything and test each port individually, using the side buttons as described in part 3 to change the input mode to the port you are using.
Hope this helps
Mar 10, 2013 | Televison & Video
SILVANIA LD320SS1
The light only confirms that power is getting from the wall socket to the TV. The flashing indicates that there is a problem with the internal power supply
Mar 01, 2013 | Philips 37PF7320A 37 in. HD-Ready LCD...
Sony Bravia KLV-40X250A power indicator blinks once but screen is black
um u should turn your tv off for like 10 minutes , i think yourr tv is a internet tv so let it cool sometimes sony internet tvs freeze with black screen so try it out.
good luck :)
Aug 06, 2012 | Televison & Video
What is the remote code for panasonic TC-L32C3 for the time warner control?
turn tv on
on remote
1. hit tv
2. hold down setup till it blinks twice(tv button light)
3.then press 991 wait till it blinks (tv button light)
4.press channel up slowly until tv turns off
5. once it turns off hit setup again
6. press the tv then power button and then see if tv turns on if not then you just missed the code(repeat)
Aug 28, 2011 | Panasonic TCL32C3 TV
Samsung LN-S3241D 32 in.LCD  HDTV Logo
47 people viewed this question
Jerry Greenberg
Jerry Greenberg
