Question about Adobe Computers & Internet
Xlstat key
Site that i should open my mms
You'll need to complete all steps for this to work. Make sure that if you have to enter O2 in the settings you use the letter O and not a zero.
The phone has a four-way directional Navi key and two soft keys on either side of this. The Navi key can also be pressed in to select options.
  1. Press Menu (press Navi key)
  2. Highlight Settings and Select (press Navi key)
  3. Highlight Configuration and Select (press Navi key)
  4. Highlight Personal configuartion settings and Select (press Navi key)
  5. Press Add new(press Navi key)
  6. Highlight Multiedia msg. and Select (press Navi key)
  7. Highlight Account Name and Select(press Navi key), enter giffgaff - MMS then OK (press Navi Key).
  8. Highlight Server address and Select (press Navi key), enter http://mmsc.mediamessaging.co.uk:8002 and OK (press Navi key).
  9. Highlight Use preferred access point and Select (press Navi key), highlight No and Select (press Navi key)
  10. Highlight Access point settings and Select (press Navi key)
  11. Highlight Proxy and Select (press Navi key), highlight Enable and Select (press Navi key)
  12. Highlight Proxy address and Select (press Navi key), enter 193.113.200.195 and OK (press Navi key)
  13. Highlight Proxy port and Select (press Navi key), enter 8080 and OK (press Navi key)
  14. Highlight Bearer settings and Select (press Navi key)
  15. Highlight Packet data access point and Select(press Navi key), enter giffgaff.com and OK (press Navi key)
  16. Skip past Network type this should be set to IPv4
  17. Skip past Authentication type, this should be set as Normal
  18. Highlight Username and Select (press Navi key), enter giffgaff and OK (press Navi key)
  19. Highlight Password and Select (press Navi key), enter password then OK (press Navi key), verify password and again select OK (press Navi key)
  20. Press Back (right soft key) six times
  21. Highlight Messaging and Select (press Navi key)
  22. Highlight More and Select (press Navi key)
  23. Highlight Message settings and Select (press Navi key)
  24. Highlight Multimedia msgs. and Select (press Navi key)
  25. Highlight Configuration and Select (press Navi key)
  26. Highlight Configuration and Select (press Navi key), highlight Personal config. and Select (press Navi key)
  27. Highlight Account and Select (press Navi key)
  28. Highlight giffgaff - MMS and Select (press Navi key)
  29. Press the right soft key five times to get back to the standby screen
Please switch your handset off and back on again before using these settings.
The settings are now complete.
hope that helps
May 29, 2013 | Nokia C1 Cell Phone
Tip
DIY Replacement Ignition KeySubject: DIY Replacement Ignition Key Title: What to...
Title: What to do if you need a replacement ignition key
Overview:
There are times where you may need a replacement key. This can be the cause of a lost key, a key going bad, upgrading from the non all-in-one key to the all-in-one key.
Please keep in mind that if all keys are lost, there is NO WAY to program a new key to you car and a replacement TWICE module will have to be found with a key, either new (costly) or used and be married to the car via the dealer.
Symptoms:
Need a key, key is giving intermittent "bad key" messages and will not start the car, etc.
Experience Level:
Easy
Tools Needed:
Probably none, or a small tool to take the door off of a key via the hole in the side for the all-in-one key.
Time Needed:
Not much.
Parts Needed:
Key Blank from Dealer about $40 This is cut to your car.
Key Top from Dealer about $40 This is the "key guts"
all-in-one guts from Dealer about $90
all-in-one guts from ebay about $30-$60
key door from dealer for all-in-one key about $15
Procedure:
There are a few cases that can be covered
Case 1: Non All-in-one key replaced by non All-In-One key.
Subcase A: Have a non all-in-one key that is going bad
Solution: The dealer will have a replacement top for the key. Get the top, replace the top of the key and have it reprogrammed for the car. Total cost about $40 + $30.
Subcase B: Replace with all-in-one key because they are neato and / or the other key is lost.
Solution: Order the "Key Blank" from dealer and obtain the guts for the all in one key from ebay or the dealer. Have keys programmed by dealer. Total cost about $35 + $30 + guts cost.
Case 2: All-in-one key replaced by All-In-One key.
Subcase A: Have key but is not working.
Solution: Get guts and have it programmed. Cost about $30 + guts cost.
Subcase B: Lost key, need a new key
Solution: Get Key Blank and guts and have it programmed. Cost about
Outcome:
Very nice. Replacing the non all-in-one with the all-in-one dramatically increased the range of the remote. over the banana style remote.
Notes:
- Replace the battery in the guts if you get them off of ebay.
- You have to have all keys and remotes to dealer for programming.
- The guts for the non all-in-one key do not have the remote guts
- The guts for the all-in-one key have the security and remote in one
- The key shaft from the ebay all-in-one key can be discarded
on Jan 17, 2010 | Saab 9 5 Cars & Trucks
Inspiron N7010 touchpad is disabled, how to enable?
Inspiron N7010
Key to the right of the F12 key
Press the Touchpad Disable/Enable key,
(the key is located to the right of the <F12> key). Inspiron N7010
Inspiron N7010 Key to the right of the F12 key
Press the Touchpad Disable/Enable key,(the key is located to the right of the <F12> key).
Sep 23, 2011 | Dell Inspiron 1545 Notebook
How do i connect my nokia 6230 to gprs
Hiiiiiiiiiii....................
Nokia 6230 GPRS and WAP Internet Settings
The phone has a 4 way directional 'Navi' key and 2 soft keys either side of this.
To insert the required symbol (e.g. : / . @) into your settings, simply press the * key, highlight the appropriate symbol and press the Use key to select.
1. Press Menu button (Navi key).
2. Scroll to 'Settings' and press 'Select' (Navi key).
3. Highlight 'Configuration' and press 'Select' (Navi key).
4. Highlight 'Personal Configuration Settings' and press 'Select' (Navi key).
5. Press 'Add' [If there are profiles in the hand set already Press 'Options' then select 'Add new']
6. Highlight 'Web' and press 'Select' (Navi key).
7. Highlight 'Account name' and press 'Select' (Navi key).
8. Enter 'giffgaff GPRS WAP' and then press 'OK' (Navi key).
9. Highlight 'Homepage' and press 'Select' (Navi key).
10. Enter 'http://giffgaff.com/mobile' then press 'OK' (Navi key).
11. Ignore 'User name': Leave blank.
12. Ignore 'Password': Leave blank.
13. Highlight 'Use preferred access point' press 'Select' (Navi key).
14. Highlight 'No' and press 'Select' (Navi key).
15. If asked to 'Define access point settings' then press 'OK' (Navi key).
16. Highlight 'Access point settings' and press 'Select' (Navi key).
17. Highlight 'Proxy' and press 'Select' (Navi key).
18. Highlight 'Enable' and press 'Select' (Navi key).
19. Highlight 'Proxy address' and press 'Select' (Navi key).
20. Enter '193.113.200.195' and press OK' (Navi key).
21. Highlight 'Proxy port' and press 'Select' (Navi key).
22. Enter '8080' and press 'OK' (Navi key).
23. Highlight 'Data bearer' and press 'Select' (Navi key).
24. Highlight 'GPRS' and press 'Select' (Navi key).
25. Highlight 'Bearer settings' and press 'Select' (Navi key).
26. Highlight 'GPRS access point' and press 'Select' (Navi key).
27. Enter 'giffgaff.com' and press 'OK' (Navi key).
28. Highlight 'Authentication type' and press 'Select' (Navi key).
29. Highlight 'Normal' and press 'Select' (Navi key).
30. Highlight 'User name' and press 'Select' (Navi key).
31. Enter 'giffgaff' and press 'OK' (Navi key).
32. Highlight 'Password' and press 'Select' (Navi key).
33. Enter 'password' and press 'OK' (Navi key)
34. When asked to 'Verify new password' enter 'password' and press 'OK' (Navi key).
35. Press 'Back' (right soft key) 3 times.
36. Highlight 'giffgaff GPRS WAP' and press 'Options' (left soft key).
37. Highlight 'Activate' and press 'Select' (Navi key).
38. Press 'Back' (right soft key) 4 times to return back to the standby screen.
Switch your handset off and then back on to complete your settings.
The GPRS WAP settings are now complete.
Nokia 6230 MMS Settings
4. Highlight 'Personal configuration settings' and press 'Select' (Navi key).
5. Press 'Add ' [If there are profiles in the hand set already Press 'Options' then select 'Add new']
6. Highlight 'Multimedia msg.' and press 'Select' (Navi key).
8. Enter 'giffgaff MMS' and then press 'OK' (Navi key).
9. Highlight 'Server Address' and press 'Select' (Navi key).
10. Enter 'http://mmsc.mediamessaging.co.uk:8002' and then press 'OK' (Navi key).
11. Highlight 'Use preferred access point' and press 'Select' (Navi key).
12. Highlight 'No' and press 'Select' (Navi key).
13. If asked to 'Define access point settings' then press 'OK' (Navi key).
14. Highlight 'Access point settings' and press 'Select' (Navi key).
15. Highlight 'Proxy' and press 'Select' (Navi key).
16. Highlight 'Enable' and press 'Select' (Navi key).
17. Highlight 'Proxy address' and press 'Select' (Navi key).
18. Enter '193.113.200.195' and press OK' (Navi key).
19. Highlight 'Proxy port' and press 'Select' (Navi key).
20. Enter '8080' and press 'OK' (Navi key).
21. Highlight 'Bearer settings' and press 'Select' (Navi key).
22. Highlight 'GPRS access point' and press 'Select' (Navi key).
23. Enter 'giffgaff.com' and press 'OK' (Navi key).
24. Highlight 'Authentication type' and press 'Select' (Navi key).
25. Highlight 'Normal' and press 'Select' (Navi key).
26. Highlight 'User name' and press 'Select' (Navi key).
27. Enter 'giffgaff' and press 'OK' (Navi key).
28. Highlight 'Password' and press 'Select' (Navi key).
29. Enter 'password' and press 'OK' (Navi key).
30. When asked to 'Verify new password' enter 'password' and press 'OK' (Navi key).
31. Press 'Back' (right soft key) 3 times.
32. Highlight 'giffgaff MMS' and press 'Options' (left soft key).
33. Highlight 'Activate' and press 'Select' (Navi key).
34 Press 'Back' (right soft key) 4 times to return to the standby screen.
35. Press Menu button (Navi key).
36. Scroll to 'Messages' and press 'Select' (Navi key).
37. Highlight 'Message Settings' and press 'Select' (Navi key).
38. Highlight 'Multimedia Msgs.' and press 'Select' (Navi key).
39. Highlight 'Configuration Settings' and press 'Select' (Navi key).
40. Highlight 'Configuration' and press 'Select' (Navi key).
41. Highlight 'Personal Config' and press 'Select' (Navi key).
42. Highlight 'Account' and press 'Select' (Navi key).
43. Highlight 'giffgaff MMS' and press 'Select' (Navi key).
44. Press 'Back' (right soft key) 5 times to return to the standby screen.
The MMS settings are now complete.
Enjoy............
Sep 21, 2011 | Computers & Internet
Does not internet
Hi jobmasai,
you may wanna try this:
Nokia 2330 GPRS and WAP / Internet Settings
1.Press Menu (press Navi key)
2.Highlight Settings and Select (press Navi key)
3.Highlight Configuration and Select (press Navi key)
4.Highlight Personal configuartion settings and Select (press Navi key)
5.Press Add new (Navi key)
6.Highlight Web and Select (press Navi key)
7.Highlight Account Name and Select (press Navi key), enter giffgaff WAP GPRS then OK (press Navi Key).
8.Highlight Homepage and Select (press Navi key), enter http://giffgaff.com/mobile then OK (press Navi Key)
9.Highlight User name and Select (press Navi key), enter giffgaff then OK (press Navi key)
10.Highlight Password and Select (press Navi key), enter password then OK (press Navi key), verify password and again select OK (press Navi key)
11.Highlight Use preferred access point and Select (press Navi key), highlight No and Select (press Navi key)
12.Highlight Access point settings and Select (press Navi key)
13.Highlight Proxy and Select (press Navi key), highlight Enable and Select (press Navi key)
14.Highlight Proxy address and Select (press Navi key), enter 193.113.200.195 and OK (press Navi key)
15.Highlight Proxy port and Select (press Navi key), enter 8080 and OK (press Navi key)
16.Highlight Bearer settings and Select (press Navi key)
17.Highlight Packet data access point and Select (press Navi key), enter giffgaff.com and OK (press Navi key)
18.Skip past Network type this should be set to IPv4
19.Skip past Authentication type, this should be set as Normal
20.Highlight User name and Select (press Navi key), enter giffgaff and OK (press Navi key)
21.Highlight Password and Select (press Navi key), enter password then OK (press Navi key), verify password and again select OK (press Navi key)
22.Press Back three times (right soft key)
23.Highlight giffgaff WAP GPRS and press Options (left soft key)
24.Highlight Activate and Select (press Navi Key)
25.Press Back (right soft key) four times.
Apr 14, 2011 | Nokia Classic 2330 Cell Phone
Where can i find a printable page to print all the controls and functions on lock on moder air combat please help
Scroll Lock Key nearest air target Alt + Scroll Lock Key center-of-view air target Shift + Insert Key next air target Shift + Home Key previous air target Shift + Scroll Lock Key nearest ground target Ctrl + Num Lock Key center-of-view surface target Shift + End Key next surface target Shift + Delete Key previous surface target
MISSION EDITOR Ctrl + N Key create a new mission Ctrl + O Key open an existing mission Ctrl + S Key save the active mission to disk Ctrl + Shift + S Key save the mission under another name Esc Key delete the current selection on the map Delete Key delete the current selection on the map Ctrl + Shift + C Key assign the active mission to a class and protect it with a password Ctrl + Shift + D Key declassify the active mission Ctrl + H Key hide or show specific objects on the map Ctrl + 1 Key return the map to the default magnification level around the crimean peninsula Ctrl + + Key magnify the map by a factor of 2 Ctrl + - Key scale the map down by a factor of 2 Ctrl + O Key take the view down to a very close level Ctrl + V Key magnify the map to a regional view centered on the selected object Ctrl + B Key view and edit the mission briefing Ctrl + D Key view a debriefing when a saved mission is loaded Ctrl + F Key start the current mission Ctrl + N Key begin a network multiplayer session Ctrl + M Key chat with other players during a multiplayer session Ctrl + R Key start the mission and record a video sequence Ctrl + P Key play back the last recorded video sequence Ctrl + V Key start the video sequence and enable its editing Ctrl + Shift + F Key specify failures that may happen to your aircraft Ctrl + Shift + W Key specify meteorological conditions Ctrl + Shift + E Key open encyclopedia Ctrl + Shift + O Key open options screen F1 Key help F2 Key keyboard command list
Feb 27, 2011 | Video Game Consoles & Games
Multimedia keyboard on function keys. Functions work with a key "Function" How to change "Multimedia keys first" on "Function keys first" ???
You can change the settings by going to BIOS. To go to BIOS, restart the system and as soon as you restart, start tapping the <F2> key located on the keyboard. This will take you to BIOS.
You can use the Function Key Behavior setting in the System Setup (BIOS) utility to configure the media control keys. The options in the Function Key Behaviour setting are:
Multimedia Key First - This is the default option. Press any multimedia key directly. For function key, press <Fn> + the required function key.
Function Key First - Press any function key directly. For multimedia key, press <Fn> + the required multimedia key.
Nov 01, 2009 | Dell Inspiron 1545 Notebook
Codes for my eurovox
LATEST KEYS ALL AREAS
EX C&W KEYS -- KEYROLL 04/12/2008
PROVIDER CODE: 5C 01
KEY 00 = D4 A3 5D EB 7B F3 69 59
KEY 01 = 27 77 A1 FC 8F 9D 34 76
TELEWEST KEYS -- KEYROLL 04/12/2008
PROVIDER CODE: 5A 01
KEY 00 = C0 F6 61 87 91 F9 67 57
KEY 01 = F0 83 35 E5 28 40 49 B2
PURE NTL KEYS (UK) -- KEYROLL 04/12/2008
PROVIDER CODE: 54 01
KEY 00 = 3F B8 36 62 72 E5 E2 76
KEY 01 = 35 5E D6 40 6E AA 99 41
IRELAND CHORUS KEYS -- KEYROLL 29/06/2008
PROVIDER CODE: 5E 01
KEY 00 = 51 0F 32 A7 D9 34 BE 3E
KEY 01 = 8D A3 88 1B 4E 32 C5 8F
IRELAND NTL KEYS -- KEYROLL 18/06/2008
KEY 00 = 75 92 B1 CC 6F 23 20 F1
KEY 01 = F2 46 B1 59 04 61 77 71
KEYS BROUGHT TO YOU BY
DE-CRYPT.NET AND THE CHATTERBOX.CC TOOLBAR
Dec 07, 2008 | Televison & Video
Need codes for 'the box' yorkshire area
Dec 04, 2008 | StarTech.com StarView SV211K 2-port KVM...
EUROVOX CODES
Nov 27, 2008 | StarTech.com StarView SV211K 2-port KVM...
Computers & Internet Logo
51 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
