Lost electrical power at 2 outlets. No TV power
I have 2 electrical outlets in my living room that worked last night. This morning neither outlet had power. The circuit breaker does not look like it has tripped. All other outlets/lights appear to be fine. What could be the problem?
    Problem Solver:
  • 13 Answers
Wires could be crossed or burnt out
Posted on Jun 14, 2009
RCA D52W20 HDTV TRIES TO TURN ON 3 TIMES BUT WONT POWER UP
remove all the electrical wire connections from the back of the tv .remove the power plug from the electrical outlet and wait for two minutes and replug the wire and then ckeck.it should work.
reply.
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
How to wire in an on-off switch for ceiling light from power source going to living room.
Pretty easy if you can get the wires from the existing wall outlet. Just run a wire from existing outlet to the where you want the new light. Install inside an approved ceiling electrical outlet box and then run another wire to where you want the switch or switches. If you go to home depot or the library you can look at the books with diagrams on how to wire it. You can skip the wall switch if you use a light with a pull chain.
Sep 20, 2014 | Electric Electrical Supplies
My set is plugged into a cable box. the tv will not turn on either manually or with the remote.
Plug the power cord directly into a wall power outlet, and make sure that the standby light is lit (turn it on/off manually to see if anything changes). If there isn't any light, then it's most likely broken.
If the TV works again, being plugged into the power outlet in the wall, then the problem is with the cable box (i bet you figured that out too).
Jul 06, 2014 | Envision L32W761 32 in. LCD TV
My Sharp Aquos LC-26D44E-GY in the spare room has stopped working. It worked ok about 2 weeks ago, went to switch it on last night & its dead. We had a thunder/lightening storm last week? Ive changed...
First check your power outlet, try connecting the TV to a different power outlet. Then see whether the LED light on the TV is on or blinking. Anyhow, this might need attention by a qualified service technician.
Jul 15, 2012 | Televison & Video
My tv will not power on after just working fine last night
Check for power at the electrical outlet. If it is live,
Check your TV for busted fuse inside the case.
Send your E-mail and let me know.
Sep 23, 2009 | Televison & Video
When we turned off the tv last night it was fine this morning it would not turn on it is as if it has no power . nothilng happens.
Plug something else into the outlet where the tv is plugged in to be sure that you still have power at that outlet. I like to use a hair blow dryer or a radio. If there is no power there check your electrical panel for the breaker or the fuse. Reset the breaker, or change the fuse.
Aug 07, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
No Power to my TV after power outage
A lot of times its simply a fuse that goes out. Either way someone is going to have to open it up and inspect the fuses first. It 's a fairly inexpensive service call.
Hopefully the fuse took the hit from the storm.
Jun 04, 2008 | Televison & Video
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
