Question about Olympus Stylus 790SW Digital Camera
Camera display is dark - Olympus Stylus 790SW Digital Camera
Picture is dark
please note, when you have the camera on, you might also need a light in front of you or behind you or both. if your in the dark the light from the monitor will not be enough light.
Sep 15, 2012 | CyberLink YouCam
I switch my camera on, but the display window remains dark (off). What am I doing wrong?
if the camera have not a specific button to dark the display. is probably that the camera alre faulty. in this case you must prove to make pics, without display. make any pics and look on the meedia card if the camera have registred the pics. if the camera registred the pics. the problem is only into the display. if the camer dont register the pics, the problem is into the lens and ccd.
if the problem is only in to the display. you can look with your exact model to buy the display. on ebay international seller. but you must have a minimum knowledge in eletronic. to change it alone.
the cost of the display its from 20 to 35 euro for this camera. the repairing cost is higher. so you must look if you have convenience to repair the camera. why now you can fiind 12 megapixel camera with 120 euro new. so make your. count. if you want prove to make this job alone please write me and i prove to help you from italy.
ciao paolo
Jun 01, 2010 | Olympus FE-340 Digital Camera
Dark stain on display screen
it should be a stain spot on the camera lens..try taking it to an authorised service point and have it cleaned
Dec 06, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Lines
hi peter,
Video will not be able to display the dark lines becoz its samling rate is low and so it cannot display detailed image.
With your 6 MP camera , the reason for the images having dark lines is that,
The SENSOR present inside your digital camera may have been covered by dirt or it may have some lines over it. so it is obvious for the images to reflect that.
So i suggest you to check the sensor with your service center.
Else you can refer to this website for more support www.samsungcamera.com/customer/faq/cus_faq_list.asp
Hope this works...
Thanx peter.
Sep 20, 2008 | Samsung Digimax S600 Digital Camera
Kodak easyshare camera
check your manual to see if you may have made the change yourself accidentally.
Jun 02, 2008 | Kodak EasyShare Z740 Digital Camera
Dark screen
Need the name and number of the camera to help you.
Mar 27, 2008 | Cameras
White Screen
  1. Upon startup lens emerges but when screen appears it is white whereas it normally displays whatever the lens sees. When the shutter button is pressed the camera will focus and take a white picture which can be deleted. The camera does not flash although flash is set to automatic and photo taken in a dark room. Camera flashes (weakly) with flash set to manual on. Lens is unobstructed and appears to be perfectly normal. Camera was not dropped. Batteries have been changed.
Jan 19, 2008 | Pentax Optio E10 Digital Camera
Display screen is dark
had you messed with the buttons the brightness has gone down 50%.do check it
Dec 19, 2007 | Canon PowerShot A630 Digital Camera
The display image unseen and the screen is dark
display shows ,saf, memory card ,charge symbols but not the capturing image on the display screen.After some time the camera is switches off.
It is sony cyber shot DSC- T33 .
Dec 10, 2007 | Sony Cyber-Shot DSC-T33 Digital Camera
Camera screen dark
It sounds like you broke the backlight on the display. I would contact Casio to find a repair center.
Feb 13, 2007 | Casio Exilim EX-S500 Digital Camera
Olympus Stylus 790SW Digital Camera Logo
51 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
