Question about AEG MCD2664EM 60cm Built In Microwave & Grill For Tall Housing
AEG MCD2664E-m - plate not turning
I have brand new MCD2664E-m microwave. When I power and start it, the plate does not start to turning on. I tryed with glas of water - water become hot, but plate does not start to turning on, I checked position and couplingn of all plate accessories - everything seems to be OK. I tryed without plate, but even in this case the axis does not turning. What can be the reason for this? Is there have separate fuse or connector for plate turning machanism?
    Master:
  • AEG Master
  • 480 Answers
There is no separate fuse only for turntable motor. Usually there is two fuse, one in High Voltage section (instead fuse could be HV protect diode) and another one for 220 V (light, turntable motor, fun motor, display....). If light work normally then is turtable motor faulty.
Dado
Posted on Sep 24, 2015
Have a problem with AEG KB9810 EM microvwave, - it does not Works. How I can solve this problem.
You need a new microwave. The cost of fixing it, would probably be the same as buying a new one.
Feb 17, 2015 | AEG Microwave Ovens
Aeg micromat 153e
You rather have a bad turntable motor or a stripped turntable coupling.
Jun 22, 2014 | AEG Microwave Ovens
Hi, My AEG built in micro wave has stopped working I was warming plates and it just cut out leaving an / and * on the display, I switch it off for 15mins then switched it back onit flashed 12.00 twice and...
Your microwave is not intended for use as a plate warmer. The plates may not even be microwave compatible. You may have caused the internal fuse to open or smoked the magnetron. The control board may have been affected as well.
Jan 01, 2014 | AEG MCC663 Microwave Oven
Hi I Have a AEG KB9810E microwave/oven combo. Its 6 years old. While the microwave was in operation, the circuit tripped and my partner heard a popping sound. Now its not clear of the AEG tripped the...
Normally when no power coming on from the microwave the fuse has blown in the microwave due to a short hi voltage diode con bad located by the capacitor or micro switches located by the door clips. If you have no electrical experience do not temp to fix it yourself due to high voltage stored in the capacitor.
Oct 07, 2013 | AEG KB9810EM Compact Multifunction Oven...
Hello, I have an AEG microwave, 6 years old. When I turn the button to chose the cookingtime and the WATT , the display shows what I choosed so thats OK. When i then press the start button the microwave...
This can be due to wrong choice or fault in the power supply ,main board or the magnetron.
You should try with a preset selection and if the microwave works then the fault relates to correcting the power to time settings.
Check out with microwave cooking tips.
Feb 01, 2013 | AEG MC143EUX 750 Watts Microwave Oven
Brand new microwave lights up plate turns around everything works except nothing heats up! Please advise!
If everything works, but no heat sounds like the magnetron circuit has failed. Since it is brand new, just take it back to the store and complaint that it does not work, and ask for a refund or replacement oven.
Jun 03, 2011 | Daewoo KOR6N9RR Microwave Oven
My built in AEG electrolux microwave has started arcing (only 3 years old) and the flexible plate covering the stirrer appears to hve a tear in it - what can I do? I live in Northumberland, UK.
The plate should be an insulator and NOT causing the arcing.
Arcing is caused by EITHER not having enough food load with moisture content, OR using containers that have METAL in them INCLUDING bowls with metallic decorations or silvery/gold painting.
Sep 09, 2009 | AEG Microwave Ovens
My AEG Micromat_Combi microwave has started coming up with an E14 error message, have you any ideas please.
The motor opening some air valve is probably stuck. See "AEG “micromat_combi 635” halts with error E14. What to do?" at http://appliancewiz.com/questions/47/aeg-micromatcombi-635-halts-with-error-e14-what-to-do for some images and instructions.
Oct 31, 2008 | AEG Microwave Ovens
AEG Micrmat Microwave oven - MC1751E / MC1761E
That's interesting. We have the same microwave and it just stopped heating food after 13 months. Would have expected more for the money. As above - any suggestions on how to fix it appreciated.
Apr 26, 2008 | Microwave Ovens
AEG MCD2664EM 60cm Built In Microwave & Grill For Tall Housing Logo
69 people viewed this question
Top AEG Microwave Ovens Experts
William Miller
William Miller
Kazim ERGUNEY
Kazim ERGUNEY
Raj Patel
Are you an AEG Microwave Oven Expert? Answer questions, earn points and help others
