Question about Necvox RE-8169D 8 All-In-One Motorized System Car Video Player
What are Axis (ir-h60) headphones used for
We have them but not sure what they are for
WILL TWO SONY HEADSETS RECEIVE THE SAME SIGNAL
go on use IR transmitter...
http://www.amazon.com/Sound-Storm-Laboratories-SHP-IR-Transmitter/dp/B0015C1RKE
THANK U...
Nov 23, 2012 | Sony MDR-RF970RK Headphones
I am unable to find drivers of Panasonic SDR- H60 for win7. Pl. help me to find the same. Thanks in advance.
You can download the driver for your Panasonic SDR - H60 HDD Camcorder from the following link.(http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Camcorders/Hard-Disk-Drive/SD-Camcorders/Drivers-Downloads/model.SDR-H60.D ).Your valuable feedback would be appreciated if you are satisfied with my solution.Don't forget to leave me a reply if you need further assistance.Thanks.
Jun 09, 2011 | Panasonic SDR-H60 HDD Camcorder
Hello Could you tell me how to get the infrared
Hello... I am sorry to hear you are having problems. I am unsure if you bought this as a package deal with the headphones or purchased the headphones separately. If you purchased them separately, they may not be compatable. Headphones come in different frequencies. The reason for this is if you had 2 different dvd players and 1 kid was watching Spongebob and the other kid was watching Hannah Montana, they would not interfere with each other as far as sound. Some dvd players will allow you to change the output frequency of the IR (infrared) transmitter built into the dvd player. This feature would be in the menu section of your dvd player. Make sure the headphones are on properly, because if they are backwards, they may not read, because IR frequencies are "line of sight" meaning the receiver (headphones) has to see the transmitter (dvd player). You will see a tinted window that has 3 or 4 bulbs. That will be your transmitter. Make sure you have good batteries in the headphones and that you have them turned on. If you have power and have checked the IR frequency, and they were purchased aftermarket, then you may need a different set that receives the correct frequency. If this is a package deal and you have checked the batteries and they power up properly, you may have a bad IR transmitter inside the dvd player. With the info you provided I can only speculate at this point, but this gets you on a start. Let me know if I can help more! Good luck with your venture!!
20 year car audio/video installer
Bay manager
Mar 16, 2011 | NextBase Click 7 Duo Car Video Player
Every first copy jamed
where does the jam occurs? please send the more detailed description!
First, clean the feed rollers, starting with the vertcal roller axis... open the left cover, and lower door of the paper cassette ( beneath left door ), beneath the drum you will be able to see the two rollers on axis-clean them with alcohol/water and dry it.
Nov 13, 2010 | Canon iR 2016i Black and White Copier
Trouble w ir headphones
check the batteries in the headphones
Jan 22, 2010 | Audiovox Car Audio & Video
I am looking for a place to buy the cord that goes from the sdr-H60 HDD to the tv. Do you know where to purchase one.
Panasonic say you should only use their cable
K2KZ9CB00002 AV CABLE
If you go to this page and enter your model number you will get all the accessories for your camera the Cable id about £17
http://www.pstc.panasonic.com/EpartR/PartslistChoice.asp
Jan 22, 2010 | Panasonic SDR-H60 HDD Camcorder
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
Dec 28, 2008 | Car Audio & Video
Ir static
You can use other headphones..try movind the Ir emiitter around to a different location
Dec 06, 2007 | Pyle (PLVWR1542) 15 in. Car Monitor
Wireless Headphone not working with my portable DVD player
Firstly, make sure your DVD have built-in IR wireless module so that your headphone can receive the audio signal from your DVD player.
Second, it should be clear which frequency transmitted from your DVD player. Generally speaking, there are two frequency of IR transmitter.One is 2.3MHz/2.8MHz. another is 3.2MHz/3.87MHz. Only emission frequency same as receiver can receive the audio signal.
Jul 02, 2007 | XO Vision Wireless Infrared Stereo...
Necvox RE-8169D 8 All-In-One Motorized System Car Video Player Logo
44 people viewed this question
Top Necvox Car Audio & Video Experts
xxxxxx xxx
Are you a Necvox Car Audio and Video Expert? Answer questions, earn points and help others
