Question about LG Computers & Internet
How to repair lg flatron monitor tco fail problem & no signal
Lcd monitor
  • LG Master
  • 783 Answers
Have you tried plugging in your monitor to a different system unit? If by doing this solves yourproblem, then i would assume a graphicscardproblem, or maybe a contactproblemof it to the main board. Then, you can trycleaningthe graphiccardcontact. If this didn't work, you probably have a faultycard. Or you may try plugging in a known good monitor to your system unit? If after doing so resolves theproblem, then theproblemis on the monitor. Signal cables of monitors are the common cause of it, you may try movingthe cablewhile connected to your pc. Replacethe cableif possible.
Hope It's resolve all Your Computer Problem,
Or
Still having Problem Then follow Us For Computer Support
Posted on Mar 21, 2014
  • 173 Answers
SOURCE: How can I restore factory settings on our LG Flatron LCD Monitor?
press menu button it is in middele of lcd.
Ten go to setigns and u can fine reset buton press ok.
Posted on Jun 13, 2009
Fix-4U
  • 293 Answers
SOURCE: how to disassemble a LG LCD monitor
Hi...there,
There are 2 ways to opened it... 1: from the back, removed 4 screws and get a good grip on both open edges and pulled. Need to give it some force to it. 2: The other, it from the front bezel. First laid it face up and placed a piece of cloth or micro-fiber cloth over the screen to prevent smudges or damaged from the 4 knuckles . Then use both 8 fingers to grasp onto to edges of a bezel and lift it up with some force to it. Do the same on other side Good luck!
Posted on Dec 06, 2008
SOURCE: LG Flatron Monitor-adjust height and color
https://support.dell.com/support/edocs/monitors/1908FP/en/ug/stand.htm#Using%20the%20Tilt,%20Swivel,%20and%20Vertical%20Extension
4:29:29 If locked in the down position, 1. Push the monitor down, 2. Press the Lock down / release button on the bottom rear of stand to unlock the monitor. 3. Lift the monitor up and extend the stand to the desired height.
Posted on Apr 12, 2009
wagyp
  • 86 Answers
SOURCE: lg flatron won't turn on
have u checked the internal fuse take the back off and look for a glass fuse
Posted on Jul 26, 2009
  • 460 Answers
SOURCE: i want to know ls flatron monitor shape settings
there is usually a default setting in the os menu.
Posted on Nov 12, 2009
Does the Dell 1503FP 15" LCD Monitor have VGA
Cable Connections On Back of Dell 1503FP 15" LCD Monitor and Computer connect.gif D-sub(Blue colour) is the VGA cable , hence Dell 1503FP 15" LCD Monitor have VGA capability.
Feb 18, 2011 | Dell 1503FP 15" LCD Monitor
I cannot adjust the brightness on my Acer 5420-5687 laptop. The laptop had frozen so I unplugged it and took out the battery which reset the brightness. I tried using Fn key and holding the either sun...
I'm sorry my friend but seems your LCD monitor having problem. There are three options with your LCD monitor. Option 1: repair your LCD monitor *commonly problems are the LCD inverter*. Option 2: Replace LCD monitor with a new LCD monitor. Option 3: Instead using your dim LCD monitor plug CRT or LCD monitor external serve as your monitor. Have a nice day.
Jan 26, 2011 | Acer Extensa 5420-5687 Notebook
Need new drivers for Hyundai Monitor Drivers IT
Try connecting the LCD monitor to a notebook computer.
Set the notebook's video to 800-by-600 and 60 Hz,
to see if the LCD monitor will accept these settings.
Set the notebook's video to 1024-by-768 and 60 Hz,
Set the notebook's video to 1280-by-1024 and 60 Hz,
Restart your desktop computer in "Safe Mode",
after reconnecting the LCD monitor, and use the settings that work
when the LCD was connected to the notebook.
Nov 09, 2009 | Hyundai Electronics ImageQuest N91S 19"...
ISH819 LCD MONITER WITH TFT?
This link, is to the User Manual for the Envision H 819 TFT LCD monitor,
http://www.technostation.com/user-guide-owners-manual/Envision/Envision++H819+LCD+Monitor
Under the User Manual heading, you will see ->
2009-04-08 12:20:36
To the right of that is -> cache <- in blue. Click on -> cache
The Envision user manual, plainly states that the Envision H 819 monitor, is a TFT monitor.
[18.5" (47.0cm) TFT Color LCD Monitor]
May 17, 2009 | Envision 19" Widescreen Flat Panel TFT LCD...
My lcd monitor lights in green but does not display
That is definitely not normal. Try a different monitor on the computer and if you get video on the new monitor then you know your original monitor is bad for sure.
Sounds to me like its a problem with the lcd or the inverter. You might want to try and take apart the monitor and reseat both ends of the LCD cable. If that doesn't help then the monitor is faulty and you'll have to get another one.
May 12, 2009 | BenQ FP71G 17" LCD Monitor
Monitor goes black after power on.
May i know, is it a crt monitor or lcd monitor? If it is a crt monitor, then you can try to check the dry joint on te pcb board especially primary and secondary power supply. After that check the FBT with blue ring tester & cap meter to check their HV cap value.
If it is a LCD Monitor, please check on inverter board and the ccfl lamp too. Please check all the electrolytic cap on lcd monitor pcb board for low esr ohm with blue esr meter. Below is some usefull link for repair lcd monitor and crt monitor:
1) www.FastRepairGuide.com
2) www.fastrepairguide.com/recommend/lcd-monitor-repair/
Hope this help.
To your success,
Kent
Nov 19, 2008 | AOpen F2705 17" LCD Monitor
Envision LCD EN-7100e Monitor "Input not supported
Either your display card is not supporting the LCD resolution.
Apr 23, 2008 | Envision EN-7100e 17" Flat Panel LCD...
OSD Locked
What is the make and model number of this LCD?
Sep 16, 2007 | LG Flatron L1750S 17" LCD Monitor
LCD monitor and electronic viewfinder
If you turn on the back LCD, the electronic viewfinder will remain on while in a shooting mode. There is no setting on the camera to use only the back LCD monitor while shooting. If you playback images in the Play mode, only the LCD monitor will turn on. However, if you press the Monitor button while in the Play mode, than the back LCD monitor will turn off. The image will display only in the viewfinder LCD.
Sep 04, 2005 | Olympus Camedia C-725 Digital Camera
Computers & Internet Logo
1,705 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
