Question about Samsung 46 LN46D550 LCD TV
Vertical bars on screen for certain colors
I just got this tv and notice on certain colors i see these vertical bars, ive reset the picture, etc still get it heres a picture to show example anyone have an idea? http://s47.photobucket.com/user/drunkenpaco/media/t%20v/IMAG0003.jpg.html
    Top Expert:
  • Samsung Master
  • 74,630 Answers
Sounds like a panel fault. Contact the authorized service centre for Samsung, to confirm. Gopakumar Gopalan Google
Posted on Mar 21, 2014
Coldcut
  • 1554 Answers
SOURCE: Static lines one screen
as the top is ok and the bottom has this issue.
It looks like the circuit board has a bad connection to your screen.
it is not repairable by you and not an adjustment.
you need to have it repaired.
don't you miss the old wack on the side fix?
Posted on Feb 17, 2008
lukster
  • 217 Answers
SOURCE: vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Posted on Aug 03, 2008
  • 6 Answers
SOURCE: nec plasma tv 42MP4
these plasma vertical black lines are notorious. there's a video of a fix on this plasma tv repair site. good luck!
Posted on Jan 23, 2009
SOURCE: When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Posted on Mar 03, 2009
  • 1779 Answers
SOURCE: Faint Vertical lines on Samsung LCD TV
Your correct, LCD's don't burn. This sounds like a defective main control module. I would take it in as soon as possible to have it looked at.
Posted on May 03, 2009
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
Vertical black and white bars on lcd screen
I'm not too familiar with the LG brand, but if the onscreen stuff looks fine (Volume, menus, etc.) then the panel is OK. Try a picture source other than the one you are using now (Tuner, HDMI, VGA, etc.)
1) If it's the same across all of them, then you will need to replace the main board in the TV.
2a) If it only affects one input, it could either be your video source that is bad (which means TV is OK), or
2b) that certain input port on TV is bad, which would mean you either don't use that input any more, or you replace the main board in the TV.
Sep 15, 2012 | LG M208WA 20 in. LCD TV
I have a Sony KDLW3000, the picture has colored vertical lines on the whole screen,
The Tcon board is usually at fault with that symptom. You can get a replacement Tcon from www.tvrepairworld.com
Apr 01, 2012 | Sony KDL Televison & Video
My LG led has had several problems, it started out with the left half of the screen flipping as if viewed from a mirror with the right part of the screen normal. After that, it displayed vertical colored...
This problems are a very tipical of the coded pixels on the LCD screen panel passes through the board that call the T-CON decoder board to causing this problems.Vertical colors lines display on the LCD screen panel happen by itself.Yes.The T-CON decodering board it is dying and shorting out.This T-CON decodering board sit in the middle at the botton of the LCD screen panel.Replacing this T-CON decodering board will solved this problems,if does not the LCD screen panel itself it is shorting out,than the tv it is not worth fixing,because changing the whole LCD screen panel itself it is not practical and the cost will be the same as a new tv itself.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.
May 31, 2011 | LG 32LE5300 Widescreen 32 in. HDTV
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Very faint vertical bar moving across plasma screen.
OK... Left to Right is weird. I'd say one of two things.
Refresh Rate might be to low or to high, but i doubt this to be the cause. I'll put my money on external interferences. Something like another PC screen? TV? anything magnetic and I've even in some cases noticed PC side panels too close to a screen can cause this.
Dec 29, 2008 | Computers & Internet
Vertical color lines
I had the same thing happen to me this morning. I turned on the TV and it had colored vertical lines through the whole screen. I called Sony and they had me unplug the TV for about 15 minutes. This solved the problem. They said the boards just needed to be reset. It fixed the problem and I am happy with my Sony once again.
May 22, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Samsung 46 LN46D550 LCD TV Logo
112 people viewed this question
Henry  Thomas
Henry Thomas
