Washing machine does not start
It does not start
My washing machine will not lock to wash i have replaced the locking mechanism assembly and the lock lid light just blinks and click near the computer board what els should i try please jelp
How to fix a washing machine door lock in a Hotpoint ...
? 4:21
https://www.youtube.com/watch?v=p14EEa4AYGM
Jun 4, 2010 - Uploaded by eSpares
For all your washing machine spare parts go to http://bit.ly/1828iPF In this video, ... How to fix a washing machine door lock in a Hotpoint washing machine ... How to open a washing machine door that won't open normally.
Door makes clicking noise and won't lock or start - Kenmore ...
https://www.ifixit.com/.../Door+makes+clicking+noise+and+won't+l...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock the lockand switch assembly might be defective. This is a very ... The Kenmore Elite HE3 is awashing machine by Kenmore. ... Preview my answer. Post my ...
washing machine wont work. the door will not lock to start ...
www.shopyourway.com > Manage My Life > Questions
Manage My Life. washing machine wont work. the door will not lock to start the cycle. all the lights still ... Kenmore HE3T front load washing machine will not start.
How to Fix Washer That Won't Start ' Washing Machine Repair
www.partselect.com/Repair/Washer/Will-Not-Start/
Read on to learn how easy it is to fix the washing machine yourself... ... found on front load washing machine is the door switch and the door lock and strike.
Jan 23, 2016 | Washing Machines
My Bosch 1244E will not go on I plug it and no power?
Washing Machine Won't Start - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 21, 2013 - If wall socket & fuse are OK but washing machine won't start ... didn't work - so I tried plugging my Hoover washing machine into another plug and all systems are go! ... I have a bosch washing machine which is 16 months old.
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine will not start, no power. ... So begin at the plugand make sure that there is power to the socket and that the fuse is okay ... I have aBosch washing machine which is leaking from underneath and the water is coming out the front at the bottom. .... It washes but won't go into rinse or spin.
Washing Machine Will Not Start - What To Check - How To Fix
removeandreplace.com/.../washing-machine-will-not-start-what-to-check...
Apr 10, 2015 - Be sure the washer is plugged into the electrical outlet in the wall. ... If the lid switch is faulty, then the washing machine will not start. ... If the lid switch is being pressed but no power is being supplied to the washers motor, ..... October 28, 2014; Bosch Washing Machine Error Fault Codes October 28, 2014 ...
Dishwasher Will Not Turn On - How To Fix ...
Jan 19, 2016 | Bosch Washing Machines
My washing machine wont start,its opening and turning on, all the lights are on but it wont run. Can you help me please
A broken washer means disaster in most homes which is why we've created this repair guide to help you fix a washer that won't start. While a washing machine ...
What to do when your washer won't fill, start or run - YouTube
? 2:00
https://www.youtube.com/watch?v=Atd5YHbRh7M
Jun 20, 2012 - Uploaded by searspartsdirect
What to do when your washer won't fill, start or run ... Front Load Washer Won't Drain or Spin Video: Washing Machine Tips from Sears ...
Troubleshooting a Washing Machine That Won't Start ...
www.doityourself.com/.../troubleshooting-a-washing-machine-that-wont...
If your washing machine won't start, begin by looking at the power source. ... mywashing has filled with water,now it wont agitate,it's like it is dead,could this be ...
Jan 14, 2016 | Washing Machines
Why won't it start?
Bosch WAS32461GB Washing Machine that will not start
www.how-to-repair.com/.../bosch-was32461gb-washing-machine-that-w...
Mar 31, 2015 - Bosch washing machine Will not start, won't start, Will not open - this is usually due to the machine still having water in it or a door interlock ...
My Bosch Washer Won't Start ' eHow
www.ehow.com > Home
If your Bosch washer does not start, there are a few troubleshooting steps to take before calling for ... Problems with Bosch washing machines that won't spin.
Bosch washer WFMC6400UC won't start - Appliantology.org
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 07, 2016 | Bosch Washing Machines
Smart drive 508 kelvinator washing machine The start button doesn't work. Machine turns on and all the lights and other buttons work but when you press start it doesn't start or start filling up.
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
Apr 13, 2015 | Washing Machines
I have an Indesit washing machine. After it's been switched off and you Press power button, all light continuously flash won't even start any wash cycle
Apr 12, 2015 | Indesit Washing Machines
The washing machine does not start
Apr 08, 2015 | Washing Machines
Wash Cycle doesn't start
Unplug the machine for about fifteen minutes. When your fuse blown it caught in the middle of the cycle. By unpluging it will reset the machine.
Dec 07, 2009 | Washing Machines
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
