Question about Luggage & Travel
Rovics cubes pattern
Pattern in rovics cubes
Getting shaved ice instead of cubes
Several possibilities, but check first for cubes that are too small (means too little water is coming in during ice maker fill) and those cubes fracture into smaller bits when they are dispensed.
Another possibility is the cube/crushed plate inside the dispenser is stuck. This is a curved plastic piece that lies next to the crusher blades inside the dispenser head of the ice storage bin. For cubes this place must be retracted (swing away from) the crushed fingers to allow the cubes to pass without being broken up.
Oct 30, 2016 | Refrigerators
Ice maker leaves 2 to three cubes on most dumps. then it stops dumping until they are removed
Check the the part called the cube rake. Its usually a white plastic piece with fingers that point to each cube mold. Its suppose to push the cubes out during the cube dump cycle. It sounds like a few of the fingers may be broken and not turning properly on the shaft to extract the cubes out of the icemaker. The rake should push the cubes out during the cycle.
May 15, 2015 | Refrigerators
Where is the fuse box on a jeep patriot.
fuses are located in the engine compartment. next to the Engine Air Filter Housing behind the battery, in front of the suspension strut tower. for a picture/diagram try going to this website, it maybe helpful; www.jeeppatriot.com
Mar 22, 2015 | Jeep Patriot Cars & Trucks
What are flavored ice cubes?
Flavored ice cubes are a great way of jazzing up a drink and cooling it down without watering down the flavor in the way that regular ice cubes would. You can make fruit cubes or vanilla cubes and really add another dimension to your drinks.
Feb 18, 2013 | Home
2x minus x cube plus 5x minus 2
Your question is interpreted in following way as it is not clear as cube of what & minus of what?
2x minus x cube plus 5 x minus 2
Solution 1:
= 2 x -1 x cube plus 5 x minus 2
= -2x cube plus 5 x minus 2
= cube of -2 plus 5 x minus 2
= (-8 +5) x -2
= -3 x -2
= 6
Solution2:
=2x-1x cube of +5 x -2
= -2 x 125 x -2
= 500
I think logically the solution 2 must be right. How you interpret the question is important.
sonsunny
Jul 04, 2011 | Acer Computers & Internet
How do I cube root a number on my ti89 titanium calculator?
To find the cubed root of say...8, then you would type this into the calculator:
root(8,3)
Nov 02, 2009 | Texas Instruments TI-86 Calculator
Cant push back cylinder on rear brake caliper on vw golf 1.4s
You will need to check to see if your VW has anti-lock brakes installed on it. The pistons that push in usually look like an inverted cup, hollow end facing the brake pads. The pistons with antilock brakes are usually solid across the top facing the brake pads and will need to be rotated in order for them to collapse back inwards. Some rotate easily, others are a bit more difficult. The pistons on my VW Beetle have two (2) angular grooves opposite one another. If your look like this you may be able to use the blunt end of some needle-nose pliars, or you can head over to your local auto parts retailer for a "magic box", a square cube with as many as five (5) different patterns for the buttons that insert into the angular grooves on different vehcles. Find the pattern that best fits your grooves and attache the magic box to a 3/8 rachet with an extension. Rotate the piston slowley in one direction, then the other to loosen it up. To collapse the piston I believe you will need to rotate counter clockwise. Good luck, this style piston is only on the rear wheels.
Jun 08, 2009 | 2000 Volkswagen Beetle
Jenn Air JRSD209T
This is just anecdotal here, but one repair guy who came out and thawed a frozen line into the icemaker told us the fridge required near-full line pressure 90- or 70- or whatever that is, in order for the ice maker to work. This was a licensed repair guy. We were feeding it with an RO, which only pumped it in at 17 or 20 psi (or whatever the unit is) which he informed us was inadequate. However, after he thawed things out and we changed out the inline carbon filter in the fridge, everything was hunky dory for a couple of years. About a year back, the icemaking stopped, and changing out the carbon filters in the fridge AND in the RO system did the trick.
Now we have a different problem. Things aren't getting or staying cold, especially the fridge. I opened the housing in the back of the fridge, defrosted the extensive ice accumulated around the refridgerant coils, and everything ran great for a couple of days. Now we're back in the global warming pattern: steadily rising temperatures and thawing. I'm not feeling too happy about Jenn-Air these days.
Jun 17, 2008 | Jenn-Air JCD2389G Side by Side...
Luggage & Travel Logo
57 people viewed this question
Top Luggage & Travel Experts
Dave braun
Dave braun
Tom Chichester
ray gallant
Are you a Luggage and Travel Expert? Answer questions, earn points and help others
