Question about Star 35SSA Hot Dog Steamer 170 Dog 120V 800 Watt
Need manual for 8300 nemco hot dog steamer
DOES NOT WORK NEED MANUAL
How do I make the octopus turkey dogs
These are fairly easy, but you must have a very sharp knife with a thin blade.
Leaving about 2 inches or so on one end of the dog whole, slice it in half lengthwise. Roll it over 90 degrees and repeat so that you have 4 tentacles. Now, here is where you need that sharp, thin-bladed knife; each of your 4 tentacles need to be sliced in half lengthwise. They can be a little difficult, so do this carefully and slowly.
Lay the dog out flat on a microwave safe plate (if you stand it up,heating could cause it to split) and zap it for 30-40 seconds. This can also be done in a steamer until it is heated through. This step will cause the head to plump and the tentacles to curl.
Your octopus is now done, but you need to plate it up in a fun and interesting way. Some ideas are: ramen noodles or thin spaghetti that has been dyed with food coloring (green for seaweed, blue for the ocean), chili or hot dog sauce can be a rocky beach, plop him down on some mac & cheese or baked beans. Little dots of mustard can be eyes. I know these cephalopods have a beak where their tentacles meet, but for a kid's party, a smiley face is just fine.
Hope this helps! Enjoy and have fun!
Jan 14, 2015 | Lego Food Turkey Apple Cherries Hot Dog...
Hot water steamer does not work properly
Any coffee maker, espresso machine related sales-support issues you can always get in touch with www.De-Brewerz.com
Dec 15, 2013 | Saeco Odea Giro Plus Coffee Maker
HOW DO I WIRE POWER SWITCH
If it is only two wires just get a regular toggle switch.
Dec 03, 2013 | Nemco Hot Dog Roller Grill Narrow Electric...
Bissell carpet steamer not working
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rtsdf
Feb 21, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Lost the manual. Need carpet/solution water
Below is a link to dirt devil. just put in your model# for the manual.
However most cleaners you buy give you the cleaner to water ratio on the bottle. Also you do not need to use Dirt Devil cleaner. All carpet cleaning solution are pretty much the same aside from the fragrance. The best ratio that I have found is approximately 5oz of cleaner for every gallon of water. Make sure you use hot water. Using cold water or waiting to long to use the mixture can reduce the efficiency of the cleaner.
Hope this helps.
http://www.dirtdevil.com/CustomerService/Manuals/default.aspx?id=32173
Sep 04, 2009 | Dirt Devil Featherlite Easy Steamer Vacuum
How do I stop my hot dogs from looking bag coming from my steamer
not really discolor, does it looks like came out of water?
if so, that is because the steamer works. Steamer is cooking the food via water vapor and heat. For the dogs to looks like dog, you need to "dry out" the skin. pan fry, BBQ, grill, or any other metod you can to dry out the skin, then it should start to look like a dog.
Jun 03, 2009 | APW Hot Dog Steamer/Bun Warmer
Star 35SSA Hot Dog Steamer 170 Dog 120V 800 Watt Logo
43 people viewed this question
Top Star Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Bill Boyd
Dale Morten
Level 1 Expert
Are you a Star Kitchen Appliances - Other Expert? Answer questions, earn points and help others
