Question about Neo-Tec XJ-202 Air Purifier
Neo-tec xj-202 air purifier light works but no movement of air
Purifier not working
Why does the blue light flash off and on continuosly"?"
Wayne,
I have attached a copy of the owner's manual. Page 6 in Safety section discusses why the light blinks. I hope it solves your blinking blue light issue.
PEACE http://www.sylvane.com/media/documents/products/airfree-onix-3000-air-purifier-owners-manual.pdf
May 24, 2014 | AirFree Onix 3000 Air Purifier
I was told when i purchased my living air classic that as long as the green and amber lights in the cabinet were on the unit was working properly. i have two units and one has one light ( green ) working...
Hi.
The RCI Cell must probably be replaced, this must be done about every three years.
The part costs about $90, parts available here.
Replacement is explain at page 15 in manual available here.
There is also a debate on health concerns related to ionized air purifiers. Here Ecoquest answer, stating the product is safe.
On the other hand:
The Dangers of Ionic Air Purifiers
Ionic Air Cleaners
Please read also this article.
Before replacing any part I suggest to read the articles. Ozone related concerns have caused the recall of other similar devices.
Regards.
Ginko.
Sep 13, 2010 | Ecoquest Living Air Classic Air Purifier
WHAT ARE THE GREEN AND BLUE LIGHTS FOR
To let you know when the ionic breeze is working properly (Green Light) and when it needs to be cleaned (Blue light). Hope this helps.
Apr 19, 2010 | Sharper Image Professional Plus Ionic...
Blue light is blinking and purfier does not work model s1871 mak3800.com
Hi mak,here is your solution...
What is happening is this: the main electrical component is overheating and forcing the machine to turn off. When it cools, the machine turns back on. Yes, that is actually what is causing the blinking.
There is no solution for this as the main electrical component (a high voltage capacitor in this case) has failed due to stress. In my case, the machine worked for 2 months before failing. The only real solution is to have the unit serviced. However, as there is no service centers, we are all out of luck.
I believe this could be a class action law suit against sharper image for selling units built with components it knew would fail after a short period of time. They had hundreds of reports with this same failure and they knew the cause. Pressing the "boost" button too much causes extreme stress on the capacitor and shortens its life drastically. This capacitor is what provides the power to the ionizing wires.
Thanks for using FixYa.
Good Luck!!!
neo
Feb 28, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Blinking blue light
Good Luck!!!
neo
Aug 17, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Air purifier can't work.
The best solution is to dump sharper image. I found a few site that had good solid reviews for a better air purifier decision - http://www.airpurifierhelp.com and http://www.air-purifiers-america.com
Alice
Jun 24, 2008 | Sharper Image Professional Plus Ionic...
XJ 3000
Yes there is a fuse inside - its a T1.6AL250V that is hard wired in at both ends, and thus not designed for replacement. On my machine it was totally toast, and the board was blown out from a prolonged over voltage event (along with a bunch of other applicances in my home). Replacement is the only solution.
Oct 30, 2007 | Surround Air Multi-Tech XJ-3000C Air...
Metal grid cleaning
You must press both the timer and reset buttons together had same prob Ezio
Feb 26, 2007 | Surround Air XJ-3800 Air Purifier
Air Purifiers Logo
55 people viewed this question
Top Neo-Tec Air Purifiers Experts
Are you a Neo-Tec Air Purifier Expert? Answer questions, earn points and help others
