Question about Vacuums
Dyson vacuum repair in melbourne
Just need to have a service on my Dyson Vacuum which I have had for 6 years without having it looked at. No particular problems just would like a servce.
Just put a new switch on it the one that is currently on it probably went out quit working
Posted on Mar 21, 2014
SOURCE: How do I remove the washable filter to clean it on my Dyson bagless vacuum?
As you are looking down at the base of the machine (viewing from the front) you will notice a yellow button on the right side just inside of the the wheel area. push up the button to release the casing that holds the hepa filter and the spongy filter. You can see a diagram on your machine which shows this process. After you take the casing from the machine, the round housing which houses the 2 filters will come out of this casing as you pull it off. You can grab the spongy filter and pull it our of the casing. Rinse both filters as shown in diagrams on the side of the casing. Do not use soapy water, just warm water and squeeze out the spongy filter after each new soaking. Let the filters dry for 12 hours and then replace in your unit and enjoy the refurbished air movement. It does suggest that you clean these filters every 6 months.
Posted on Aug 09, 2008
ukvacfan
  • 328 Answers
SOURCE: Dyson vacuum cleaner-brush bar is frozen
Hi If your Dyson has a brush protection design - i.e. roller bar on the top of the hood on the left hand side then the DYson can't be repaired by you- serviceman or professional care can replace it.
However if the Dyson doesn't have the roller bar on top of the hood, flip the machine over so that the beater brush is facing upwards, locate three/four screw heads that can be undone with a coin and remove the sole plate assembly. This should give you a clean view of the brush bar, drive belt and dirt channel. Ensure everything is clean espcially if the brush bar has lots of hair or threads tightly corded around. Then locate the drive belt and check to see if it has snapped. Grasp the beater bar gently upwards and the belt and brush can then be removed. Fit a new belt on carefully and check the tension as it will be tight.
Posted on Apr 05, 2009
  • 389 Answers
SOURCE: Dyson DC16 Handheld Vacuum Cleaner Manual
Yes! Go to www.dyson.com/support. Click on "using your dyson", then (next window) on "select your model", then (next window) on "select your model" again, then (next window) on "DC user guide". And there you are, you've got a copy of the user manual.
Please remember to rate this response. Thanks!
Posted on May 17, 2009
  • 37 Answers
SOURCE: dyson users manual
You didn't say which model you have but here is a link for user guides covering nearly all Dyson models:
http://www.dyson.co.uk/support/help.asp?article=1624
Hope this helps.
Posted on Sep 23, 2009
  • 10 Answers
SOURCE: I have a Dyson vacuum. The vacuum won't stay
My vacuum had this exact same problem, but was out of warranty because it was remanufactured. Thankfully, it's a very quick, five-minute fix.
  1. UNPLUG The Vacuum!
  2. Remove the cannister.
  3. Extend the handle and remove it.
  4. Remove the two torx (T-15) screws behind the power button, where the handle normally stows.
  5. There are four tabs holding the front plate containing the power button on; use your screwdriver to release them.
  6. Gently pull the front plate off.
  7. The switch on the right is the power button. Remove it, try clicking it a few times; if it sticks, great! Replace it and reassemble, otherwise you'll need to replace it.
Posted on Jul 28, 2010
Place to send dyson portable head for service in california
1. Dyson Service Center - Santa Fe Springs Vacuum Cleaner Repair Shop Santa Fe Springs, CA (562) 945-1122
2. Dyson Service Center - Union City Vacuum Cleaner Repair Shop Union City, CA (510) 441-2426
3. Dyson Service Center - North Hollywood Vacuum Cleaner Store North Hollywood, CA (818) 392-7526
Jan 09, 2017 | Dyson Vacuums
Dc dyson 24 free repair maule
About 1,100 results (0.84 seconds) Search Results
    Dyson DC24 - Resetting the brush bar (Official Dyson video ...
    ? 1:55
    https://www.youtube.com/watch?v=akGLQ7UbctY
    Sep 29, 2011 - Uploaded by AskDyson
    DC24's brush bar is engineered to shut off for protection if something jams i. ... How to clear and reset the brush bar of yourDyson DC24 upright vacuum cleaner ... Dyson DC24: How toRepair a Loose and Clunky Ball. ... Dyson Ball DC 25 not locking beater bar brush in place while upright - Duration: 17:09 ...
    How to fix your Dyson Vacuum Cleaner when it loses ...
    ? 7:45
    https://www.youtube.com/watch?v=0vd3ldLXgI4
    Apr 16, 2013 - Uploaded by Chuck Fresh
    How to clean the two filters in your Dyson Ball or Animal Vacuum... troubleshooting computer problems, pc helpline, free pc repair... How to take apart Dyson DC 17 to Clean and Service - Duration: 14:33. n4ktz 178,332 views ... Dyson DC24 - Resetting the brush bar (Official Dyson video) - Duration: 1:55.
    [PDF]Dyson DC24 Manualhttps://www.dyson.co.uk/.../Dyson/.../Manuals/DC24_Manual.pdfDysonNote your serial number for future reference. After registering for your 5 year guarantee, your Dyson vacuum cleaner will be covered for parts and labour for.Dyson DC24 Manual - ManualOwl.comhttps://www.manualowl.com/p/Dyson/DC24/Manual/112339Manuals and user guide free PDF downloads for Dyson DC24. ... I Have A Dyson Dc17, Is There A Fuse Or Reset Button On The Vacuum Motor ... Complete Dyson customer service phone numbers and contact information at ContactHelp.com.Dyson DC24 Multi Floor Instruction pack - Part 914529-01 ...https://www.dyson.com/parts/u/user.../dc24userguide.aspx?...DC2...DysonDyson DC24 Multi Floor: Instruction pack - 914529-01.Buy genuine parts and accessories direct from Dyson.DYSON DC24 USER MANUAL Pdf Download. - ManualsLibwww.manualslib.com > ... > Vacuum Cleaner > Ball DC24Page 2: General Safety Precautions. Do not use with damaged cable or plug. If the supply cable is damaged, it must be replaced by Dyson Ltd, our service agent ...
Jan 28, 2016 | Dyson Vacuums
Ball shell broken on duct side
Hi Deborah, it's Jack at Dyson.
I'm sorry to hear you've had an issue with the ball shell on your Dyson vacuum. When you have a moment I would encourage you to contact our experts directly to determine if we need to arrange a repair for your vacuum. If a repair is needed we can also confirm if this will be covered under your vacuum's 5-year guarantee.
Please give us a call on us 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). We'll look forward to speaking with you.
Apr 20, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
Motor does not switch to carpet
You need the clutch replaced. All Dyson DC-7 and DC-14 machines need to be serviced annually and have the clutch replaced if you want it to perform properly. Take it to your local vacuum repair shop to have it serviced. The good news for you is, most of the newer Dysons only last a couple of years and are disposable. Yours is repairable.
Oct 11, 2013 | Dyson DC14 Animal Bagless Upright Cyclonic...
I Need A dyson hand held battModel DC16 12097 model 282-US-A35458 21.6 1080 MAH All I can find is the 1500 Mah
I didn't understand what you need exactly, but anyway, you can find both of them on amazon (the entire vacum, or just a battery 1500Mah). take a look on following links:
1. entire vacum: Dyson DC16 Root 6 Handheld Vacuum Cleaner
2. just battery: Pwr 1500mAh Extended Capacity Battery for Dyson Dc16 Root 6 Vacuum Cleaner...
Dec 09, 2010 | Dyson DC16 Root 6 Bagless Handheld...
I need to replace the brushbaron my DC17 Animal model Dyson. It's almost four years old. I can't find the correct part number on the Dyson Website and I can't seem to find a Dyson repair center in...
The original Dyson part number for the brush bar (often called brush roll) is: 911961-01
If you type the above part number into Google Products (click link below) you will get a list of suppliers at varying prices. A genuine Dyson part will cost about $20-25. There are some cheaper replacements available but you may need a different belt to use these, so I suggest you buy an original. Make sure the supplier states the part is Original / Genuine Dyson or OEM.
http://www.google.com/products
http://www.google.com/products?hl=en&q=911961-01&scoring=p
I can't help you locate a Dyson service centre in Albuquerque, but you should be able to fit the new brush bar yourself. If you do need a local service centre, you can call Dyson on the following number - they will provide details of your nearest authorised service centre:
Dyson Helpline (USA): 1-866-MY-DYSON / 1-866-693-9766
8am - 8pm (CST) Monday to Friday
9am - 3pm (CST) on Saturday
10am - 2pm (CST) on Sunday
If you need any further assistance, please post back.
Please rate this solution if you find it helpful. Thanks!
Nov 01, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
My Dyson vacuum brush does not rotate even though the
Hi its Darran at Dyson.
Please contact our Helpline on 1866MYDYSON as it sounds as though we may need to arrange for the machine to be repaired. One of our advisors will be able to run through some checks over the phone with you so please ensure you have your machine with you when calling.
We look forward to hearing from you.
Kind regards
Darran
Dyson Customer Service
Mar 08, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Brushes not going round
The brushes on my dyson have stopped going round. I have checked it and they move freely by hand. The belt is intact. What could the problem be? The Hoover is about 10 to 12 years old.
My dyson is a dc04
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
One of the main problems with vacuums are that the flat belts on the vacuums stretch and should be changed every 4 to 6 months or 3 or 4 times a year – you can tell by taking off the belt or belts on the vacuums and compare them to the old belts on the vacuum the new belts will fix inside of the old belts and you will be able to see the difference on how much they have stretched – if the belt is a geared belt – they stretch as well but should be changed about one a year – the cost is not that expensive and you cleaning will improve almost double – this also applies for the Dyson DC04 and the Hoover vacuum as well – some of the Hoover vacuums have two (2) belts and they both should be changed @ the same time.
Apr 15, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
47 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
