Question about Epson WorkForce WF-2540 All-in-One Inkjet Printer
Epson printer partially printing
I cannot a get full print from printer, no black shows on page. There are only traces of print, barely showing on paper after it goes thru and sounds like it is printing.
    Problem Solver:
  • 14 Answers
Sounds as though you have blocked nozzles - perhaps through leaving printer, especially in a dry atmosphere? Try going into the Printer's Properties dialogue box and then the Advanced tab to then use the Nozzle Clean routine. Ensure you always do a Nozzle Check after every cleaning cycle. That will improve the ink flow - should you have any still even slightly clogged - obtain some Ammonia - 5% solution is fine (some window cleaners have this - Windex with Ammonia in many countries - Ammonia of course will be a bit cheaper. To make a 5% solution (approx.) put a teaspoon into a cup of water. Make a pad of some linen say 4 layers (like a handkerchief as example) of about 6" x2". Set the printer into its Cartridge Changing mode - it will move the printhead. Then disconnect the power lead (NOT turn off or head will re-park). You can then freely move head so put soaked pad in well and move head until across pad so nozzles can soak up. Leave for a couple of hours. Slide head off and remove (now ink stained) pad. Just plug power back in and switch on (some Epsons will auto restart when power replaced - you may have to switch yours on). It will re-park head after doing a clean. Then do a nozzle check and should be fine.
Posted on May 06, 2014
J PENGUIN
  • 12 Answers
SOURCE: Epson cx5000 Ink Cartridge shows ink is running out after 2 8 x 10 prints.
IT IS POSSABLE THAT THE PRINT HEAD ARE DIRTY THEY HAHVE MATCHING BOARDS TO THE TONER CARTRIDGE BOARDS UNPLUG THE MACHINE AND CLEAN THE PRINT HEAD WITH ALCOHOL IF IT DOESN'T WORK THE BOARDS HAVE FAILED
JP
Posted on Dec 31, 2007
Rain041304
  • 63 Answers
SOURCE: epson c66 will not print black
Do print head cleaning. Contorl panel>right click on c66 and go to printing preferences>maintenance tab>print head cleaning>do it 3 times and then try to print
Posted on Feb 14, 2008
  • 79 Answers
SOURCE: Epson C82 & C84 Printers will not laydown any ink!
Sorry but It uses Durabrite ink which tends to turn into hard gel if not printed at least once a week. Its less painful and expensive to just throw the printer out and buy a new one. I recommend the canon PIXMA ip3500. It lets you remove the printhead for cleaning unlike the Epson. If you want to try your luck at unclogging the printer heres a link to a unclogging kit but be warned that results are not guaranteed!
http://www.fixyourownprinter.com/kits/Epson/K89
The C82 in addition to clogging also has a problem where the waste ink hose which is supposed to remove excess ink (so the printer dosent get clogged) gets disconnected and so the printer clogs even more. The C84 had this glitch fixed but alot of good that did!
Thanks for reading!
Posted on May 01, 2008
SOURCE: Printer will not print in Black at all
Actually guys, I figured out that because I had been using the same ink cartridge for so many years that the print heads were terribly dried out. I bought from SuperMediaStore.com (its a site run by Yahoo!) $3/$4 ink cartridges, both black and color (they charge too much for shipping though), and I have absolutely no problem printing right now.
Look around online, and buy cheaper, maybe up to $10, cartridges, but do NOT buy these stupid OEM cartridges!! Most cartridges sold on the internet are up to OEM standards.
That worked for me, hope you guys have good luck!
Posted on Sep 24, 2008
SOURCE: EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
Posted on Nov 24, 2008
WF3540 cleaning
If your printer stop function even when you head cleaning...
you need to reset your printer because the ink counter is full..
all printers has thier own printing counter up to 7000 pages or more but other printers even in 5000 pages print it's stop and shows ink counter is full so you need to reset it to back on zer.. All you need is download the Epson Adjustment Program to reset your printer
Sep 11, 2015 | Epson Stylus Multifunction Inkjet Printer/...
Test page shows there is ink, but when I attempt to print a document it is barely the ink is not dark at all
It sounds like the print head nozzles are clogged. Check your online user's manual (if it is not on the install disk that came with your printer) for the cleaning procedures. Here's a link if you can't find it: http://files.support.epson.com/pdf/xp400_/xp400_qr.pdf
go to the section, "Checking the print head nozzles"
Nov 23, 2013 | Epson Stylus C86 InkJet Printer
Black ink will not show up on paper
It seems print head clogged,this issue not related with cartridge, perform clean print heads 3-4 times & chk, if no result replace the print head (CN642A).. I won't suggest for manual cleaning for this print head unit.. Thanks for listening me..
Jun 20, 2013 | HP Photosmart Premium C309A All-In-One...
I have enough black ink to print a few pages in black, but the printer won't print. What do I do?
I had a Epson printer that would not print or even allow me to use the scanner because the colored ink was out. Even though I had full black ink, it still would not let me print until i replaced the colored ink.
Sep 25, 2012 | Lexmark 90T6005 Prospect Pro205 All-in-One...
Epson Stylus Photo 870 only prints black and white
WHen your p;;rinter name comes up, check the printing p;references. You have "P:rint colors as black & white" checked. Un check it. It is in the printer dialog box, not PSP.
Sep 15, 2009 | Epson Stylus Photo 870 InkJet Printer
Gradually stopped printing, first colors, then black. New cartridges no help.
check all the catridge installed ok after finding the gatridge ok if the problem not solved , then uninstall the printer driver and restart after restarting the machine then again reinstall the printer driver properly
May 27, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Epson Stylus CX 4800 no printing help a lady please
does the control panel of the printer have a menu buttton. Press it and read the choices. Find the one that says maintance and the find the head cleaning and run it
Oct 16, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Prints fist lines onlyTrying to print a list
Clean the head - first in control panel, doubleclick on 'printers and faxes' then right click on your printer and click on printing preferences then when the window opens up on your left at the top - click on maintenance to clean the head.
May 27, 2006 | Epson Stylus C66 Inkjet Printer
Epson WorkForce WF-2540 All-in-One Inkjet Printer Logo
98 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
