Question about Kenwood Excelon KDC-X996
No lights Unit went off
Dashboard lights went out on my 2003 acura dmx checked the driver side fuses. What do I ned to check next?
light control unit. it has a board inside for the lighting control, dash and lights. also auto light control if its on this model. it the hole switch unit.
Feb 12, 2018 | Acura Cars & Trucks
Oil light comes on and bike shuts down
Hi Anonymous, you could have an oil pressure sending unit going south on you or a broken or loose connection at said unit. They relatively inexpensive try replacing it. Good luck
Dec 27, 2013 | 2009 Harley Davidson FLHTCU Ultra Classic...
What's your problem?I have a 1999 Oldsmobile Intrigue 3.8 that I just changed the oil sending unit and still have the oil light on, any help
possibly the light is coming on due to low oil pressure if you have high miles on the engine usually over 200xxx. try disconnecting the battery for about 15 minutes then reconnect that sometimes will reset warning lights. good luck
Dec 28, 2012 | 1999 Oldsmobile Intrigue
Unit powered off. I unplugged for 10 secs, replugged in. Unit powered on numerous lights flashed in sequence and went out. Power light was last light on. It flashed several times then went out.
It's trying to tell you something. Look up the series of flashes in your manual and see what it's trying to tell you. If you don't have a manual, go to the manufacturer's web site and see if you can download one.
May 06, 2011 | Office Equipment & Supplies
I have an 2001 Honda Accord, SRS went off a few
That is usually the case. That is to inform you of a malfunction with that particular part of your vehicle.
Oct 06, 2009 | 2001 Honda Accord
Dah climate control unit went dead - no lights and no temp readout.
The battery. Get another one from a salvage yard.
Apr 27, 2009 | 1991 Buick LeSabre
Fan and light does not turn on .
FAN AND LIGHT DOES NOT WORK
my zephyr typhoon stopped working. Neither light not the fan come up. I am sure there is power going into the unit. I turned on the light one day , the light cam on and suddenly went away. From then even the fan stopped working. any information on what happened is appreciated. Thanks
Jan 22, 2009 | Zephyr Typhoon AK2100 Kitchen Hood
Comtrend ct507 no power
- try to use a known working power adapter with the same specs, it might be the power adapter is not supplying enough power, or
- try to press the reset button (if it has one) for like 30 secs, then turn the device off for another 30 secs. (Note: this might delete all the settings on the device)
- most probably the device is dead if same thing happens after pressing the reset button.
hope this'll help you
Jun 08, 2008 | Comtrend CT-507 Router
TOMTOM GO 710
Could be a loose contact at the connection between the wire and at the gps unit.
Think the green light must be on at the charger port and also on the gps unit.
This green light can be found near the power button on the gps unit.
Nov 22, 2007 | Tomtom GO 700 GPS Receiver
Kenwood Excelon KDC-X996 Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
