Question about Konica Minolta bizhub Office Equipment & Supplies
How to solve background magent
While printing from bizhub c353 the background print is magenta how to solve it
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
Replace magenta drum unit.
Posted on Nov 14, 2014
  • 12 Answers
SOURCE: Bizhub C450
sounds like the wrong image unit. Oce and ollivetti have the same machine and take the same image unit but with a different chip. Make sure it is a genuine konica minolta image unit. If need be try putting the chip from the old unit on the new one and see if lays down the colour
Posted on Aug 01, 2008
EPIJAB
  • 89 Answers
SOURCE: magenta backgrounding
If the magenta is low the waste bin may be full and that may be causing the problem. If this is the case you need to change the toner. You can try calibrating the printer. You may have to do this 3 times in a row for it to make a difference.
Press Select-check mark button
Use arrows to go to Print Quality
Use arrows to go to Calibrate Color
Use arrows to go to Calibrate Now
Press Select to Confirm Calibrate Now
Posted on Aug 02, 2008
  • 4 Answers
SOURCE: will not print in red
hi, i have seen the same problem before in other models but not this one, but i think the solution i have will help you.
try cleaning the scanner unit using a dry cloth, clean all the small glasses carefully avoiding scratches. dont use a blower.
Posted on Apr 03, 2009
Kevin Hayes
  • 167 Answers
SOURCE: Printers with full bleed capability?
NO!
Just like on a printing press that toner is being imaged somewhere when it runs out of the sheet. The toner is going on the imaging belt/fuser. Over time it will build up and ruin the device. On a press they can stop and wash the imaging blankets. Full bleed is achieved by running on oversized stock and trimming off excess afterwards. That is how the "Pros" do it.
Posted on Apr 27, 2009
taminol
  • 62 Answers
SOURCE: Minolta Bizhub C353 fails scan to emails
Hi mmarsh1212,
When you say the bizhub fails Authorization, do you menat it fails Athentication?
If so, and I pressume your technician knows what he's doing, you have an issue with a password. I suggest you create an address for the bizhub on your email server and then re-setup the scanning to email credentials via the web browser direct to the machine.
Let me know if you need help with doing this.
Regards
Taminol
Posted on May 26, 2009
How do I correct error c4152?
Magenta Print head (print head has the LASER inside of it that writes the image on the drum) in this case it is the magenta LASER. Open and close the front door to reset. If it comes back replace the print head. Normal done as a set of all four. (Black, Magenta, Yellow, and Cyan). Worse case is the relay board is bad or the Image control Board$$$$$$$$$$$$$$$$.
Try this site as a start:
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jun 04, 2015 | Konica Minolta Konica Bizhub C353 Drum...
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
May 03, 2014 | Konica Minolta bizhub C250 All-In-One...
C-4152 error c353 bizhub
magenta LASER located under the Magenta (red) image unit
Dec 23, 2013 | Konica Minolta Minolta Bizhub C353 Copier
Magental background on all prints looking like a pink papr instead of white
That sounds like a white balance issue to me. Do you use manual white balance setting or auto white balance?
Nov 05, 2013 | Konica Minolta Bizhub C550
I have konica minolta bizhub c353 i have problem
Most likely it is your magenta cartridge or magenta developer unit.
did you recently change cartridge?
Are you using original cartridge?
Nov 13, 2010 | Konica Minolta bizhub Office Equipment &...
Multiple copy error
Turn OFF sorting and/or grouping in the finishing tab.
Sep 24, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub C451
It could be a couple of things with the toner, magenta drum might not be taking the toner off, or the transfer belt. The best thing to do is get a hold of the Konica/Minolta Rep in your area.
Jun 27, 2008 | Office Equipment & Supplies
101 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
