Question about Dryers
Why wont my lg dryer model #dle2532w start when I puah the start button?
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
It the belt is broke it wont start, could be door switch , or control , thermal fuse
Posted on Mar 24, 2014
  • 92 Answers
SOURCE: LG DLE2532W Electric Dryer doesn't allow adjustment of drying options
it may be possible the contol is bad can you change the settings at all
Posted on Feb 10, 2008
  • 489 Answers
SOURCE: My LG DLE2532W will not
You may have a broken door switch.  Have it replaced and it should work fine.
Posted on Apr 28, 2008
MNTECH
  • 1543 Answers
SOURCE: LG DRYER DLE2532W DISASSEMBLY INSTRUCTIONS
DLE2532W is an electric heat model. (a gas model would be a DLG......) To get a rear control LG dryer apart: Open door and remove two phillips head screws at the 5 and 7 o'clock positions. Use a putty knife to release the clips holding the top panel to the dryer front by pushing the clips in at the seam of the dryer top and front, a couple inches in from each side. Swing top back. Remove two phillips head screws at the top, allowing front panel to pull forward. Unplug drum light and door switch and drum sensor plugs, allowing front panel to be completely removed and set aside. Now, look at the burner area at the lower right. Behind the gas valve you will find a small (about dime sized) high limit thermostat on the left side of the burner cone. It has two wires attached and has a small pin in the center of it. (Only on gas models) Push the pin in.
Now, if that get's you ignition again, CORRECT VENTING ! Get rid of flexible vent material. (use only rigid aluminum vent pipe and elbows) Clean out vent pipes and outside vent hood. Outside vent hood should be the kind with a four inch flap for the opening, not a two inch flap. Tripping of the high limit thermo is almost always caused by inadequate air flow.
Posted on Dec 28, 2008
  • 10865 Answers
SOURCE: I have an LG DLE2532W dryer and it takes hours to
the vent pipe is probably full of lint. pull the dryer away from the wall, disconnect the vent pipe and look inside the rear of the dryer and thru the vent pipe. remove any lint u find as it is a fire hazard.
Posted on Apr 21, 2009
This gives you what you need.
http://136.166.4.200/contents/Laundry/DLE2532/DLE2532_Service_Manual.pdf
Posted on Nov 11, 2009
My LG DRYER DLE2532W squeels when it runs
you might have something caught between the drum and bulkhead like button, key , money etc
Nov 24, 2013 | LG DLE2532W Electric Dryer
DLE2532W LG dryer, dryer won't start
new controls
not plugged in
not switched on
Aug 09, 2013 | LG DLE2532W Electric Dryer
DLE 5977B ELECTRIC DRYER wont start
On the exhaust is a limit that trips with bad air flow. I think that puppy is resettable:
LG service manuals
Aug 15, 2012 | LG DLE2532W Electric Dryer
Dryer tumbels but no heat. model dle2532w
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 02, 2010 | LG DLE2532W Electric Dryer
Where do i locate the heating element on my lg dryer
no fuse unless an electronic fuse on control board, check your element continuity, then the hi-limit switch then any cycling switches for proper continuity and operation
Aug 24, 2009 | LG DLE2532W Electric Dryer
Feb 07, 2008 | LG DLE2532W Electric Dryer
Dryers Logo
Top Dryers Experts
