Question about Philips DVP3040 DVD Player
DVP 3040 DVD PLAYER display "loadind" then "no disk" for all dvd
1 year old
Philips DVP 3040 DVD PLAYER display "loadind" then "no disk" for all dvd
I open it and see the lens wich move correctly (up down), the electrical engine turn correctly. i test lot of different dvd and CD, allway the same error message. I clean the lens, same problème. what can i do instaed of buy another dvd player ?
  • 3230 Answers
SOURCE: philips dvp 3040 area codes
Please you can try the following procedure -
1. turn unit on
2. open the loading tray
3. press "setup" button on the remote
4. navigate to preferences using right arrow key (three clicks)
5. Enter "138931" on the remote
6. The current region is displayed (mine was "1")
7. Use the up arrow on the remote to change the region to "0"
8. Press the "setup" button on the remote
9. Press "OK" on the remote
Good Luck!!
Thanks
Posted on Aug 07, 2009
SOURCE: PET702 Portable DVD player 'No Disk'
try this:
Press setup on the remote
Use the arrows to navigate to Prefreneces (pref)
type 9 6 5 3
Select Region code (press down arrow to set to 0, open for all codes)
Press setup again to exit
is working :D
Posted on Mar 28, 2008
ANDREIONELUV
  • 29 Answers
SOURCE: philips dvp 5992 Disk drive wont open
HELLO MY NAME IS ANDREI
I THINK YOU MIGHT OF LOCK THE DISC. BY DOING THIS YOU BLOCK THE PLAYBACK OF THE CURRENT DISC. SUBSEQUENT ACESS TO A LOCKED DISC REQUIRES A SIX DIGIT PASSWORD THE DEFAULT PASSWORD IS 136900. THIS WILL UNLOCK THE DISC LOCK FEATURE. MAKE SURE YOU GO YO SETUP AND CHOOSE UNLOCK DISC LOCK PERMANENTLY OR IT WILL KEEP DOING IT EVERYTIME YOU PLAY THE SAME DISC. HOPE THIS MIGHT OF SOLVED YOUR PROBLEM.
Posted on Jan 15, 2009
  • 814 Answers
SOURCE: Philips DVP 5992 DVD player disk tray opens without a disk
You can call Phillips customer support at this telephone number 1-888-744-5477. Tell them while using the disc player the unit failed to eject the disc and ask the for a way to solve the problem. It is best to talk to them in this case as the solution will involve a opening of the unit to figure out what has malfunctioned to cause this problem. I hope this information helps you with your problem.
Posted on Jun 02, 2009
  • 630 Answers
SOURCE: Unknown disk error on philips dvp 3020
I would guess that it's an incompatible disk format. If your burning software allows you to pick different types check the Philips manual for a compatible format
Posted on Mar 06, 2010
Hello Sir, Iam having philips 3005 dvp dvd player,last week i bought 29 inches samsung ultraslim flat TV and when i connected my dvd to the samsung tv.I got the following...
I would take it back and exchange it ,,if you purchased it new,,But if you bought it used,,and cant take it back,,I would take the top off ,,You can acces the dvd to retrieve disk and maybe see what the prob is,,thanks and goodluck
Nov 20, 2010 | Philips DVP-3005 DVD Player
Mar 06, 2010 | Philips DVP3020 DVD Player
Sony DVD player DVP-NS700H unable to play DVDs.
the dvd player lens damaged. -please change it with good technician
Sep 21, 2009 | Sony DVP-NS700H DVD Player
Philips dvp 3040 area codes
1. turn unit on
Good Luck!!
Thanks
Aug 07, 2009 | Philips Televison & Video
it think you should open the unit up.get the cd.then try to play it again.
May 18, 2009 | Philips DVP5990 DVD Player
Not able to read last files
This sounds like your player is on the way out.
If it,s 2 years or more older, i,d consider getting a new player, they,re cheap now £20-£30 ish Plus.
The remote will be new-Batterys. The DVD Player laser is probably on the way out. The mechanical sounds are possibly the laser head moving up and down, struggling to read The Data on The Disk.
Heres all you can do before Binning it.
1:- try a laser head disk cleaning Kit.
2:- put new batterys In The remote.
3:- ensure the underside of the CD/DVD are clean of fingerprints And scratches.
Hope this Helps Mike @ Compurepair.
Feb 22, 2008 | Philips DVP-3005 DVD Player
Wrong Region message
DVD player must be made region free by unlocking it.. after that you can play all the discs you want.. for ubnlocking it you can try google//
Jan 19, 2008 | Philips DVP-3005 DVD Player
Region codes
Philips DVP 3015K / DVP 3020 / DVP 3040 / DVP 3040K / DVP 5140 / DVP 5960
  1. Method 1:
  2. Open the disc tray
  3. Press SETUP
  4. Navigate to the preferences page
  5. Enter 138931
  6. Select the region using UP/DOWN
  7. Press PLAY
  1. Method 2:
  2. Open tray
  3. Press 9, 9, 9, 9, 0
Dec 19, 2007 | Televison & Video
My sony dvd is powering off about one minute after I turn it on.
1. Press Display.
2. Go down and select Setup.
3. Move to the Right and Down to select Custom, Press ENTER.
4. Move down to the center box.
5. Move Right to select Auto Power Off, Press ENTER.
6. Change it to Off, Press ENTER
7. Press Display and you should be done.
Aug 11, 2006 | Sony DVP-CX985V Multi-disc DVD Player
Philips DVP3040 DVD Player Logo
288 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
