Question about ASUS Q200e Touchscreen Notebook
Want to turn off my touchscreen
My screen is broken and want to disable my touchscreen
HOw do I turn off touch screen on a Sony VAIO Tap 20 Touchscreen All-in-One Desktop Computer, Intel Dual-Core i5-2430M 2.4GHz, 8GB RAM, 750GB 5400 RPM HDD, Windows 7 Home Premium 64-bit
1.Press the Windows logo key + X.
2.Select Device Manager from the list.
3.Click the little arrow next to Human Interface Devices to expand the list.
4.Click the touch screen driver (in my case, NextWindow Voltron Touch Screen).
5.Right-click, and select Disable from the list.
6.Click Yes on the dialog box that asks if you are sure you want to disable the touch screen driver.
7.Restart your computer
When you want your touch screen to work again, follow the process above, EXCEPT when right-clicking the touch screen driver, select Enable
See the website
Turn off VAIO all in one touchscreen function disable annoying system...
Mar 07, 2015 | Sony VAIO VPCL23CFX/B All-In-One PC - 2nd...
How do i turn off a my sony all in one touch screen, i do not touch the screen for options, and its driving me crazy
  1. Press the Windows logo key + X.
  2. Select Device Manager from the list.
  3. Click the little arrow next to Human Interface Devices to expand the list.
  4. Click the touch screen driver (in my case, NextWindow Voltron Touch Screen).
  5. Right-click, and select Disable from the list.
  6. Click Yes on the dialog box that asks if you are sure you want to disable the touch screen driver.
  7. Restart your computer
When you want your touch screen to work again, follow the process above, EXCEPT when right-clicking the touch screen driver, select Enable See the website
S
SeS Turn off VAIO all in one touchscreen function disable annoying system...
Mar 07, 2015 | Sony VAIO Tap 20" Touchscreen All-in-One...
How do I turn off the touch screen?
If you are using Windows 7, you can follow these steps to disable your touchscreen:
1.Click "Start" and go to "Control Panel"
2.Click "Hardware and Sound" and then click "Pen and Touch"
3.Click on "Touch" tab
4.Uncheck "Use your finger as an input device" checkbox
5.Click "Ok"
As the option "Use your finger as an input device" is not available in Windows 8/ 8.1, you can refer to the following link to know how to disable touchscreen in Windows 8/ 8.1:
http://community.sony.com/t5/Windows-8/Unable-to-disable-touchscreen/td-p/150629
Hope this will resolve your issue.
GuruAid.com
Aug 23, 2014 | Sony VAIO Computers & Internet
TOUCH SCREEN DOES NOT WORK
There are three (3) possible Answers:
First: Your unit does not have TouchScreen.
If the part number has CF30xTxxxxx then the "T"=TouchScreen.
If your unit has touchscreen then,
Second: The TouchScreen may be disabled in the BIOS.
Check the BIOS and see if TouchScreen is "ENABLED".
If it is DISABLED, then ENABLE it usually by pressing
the spacebar key while it is highlighted and then
SAVE and EXIT the BIOS.
Third: You do not have the Touchscreen Drivers loaded.
Locate these drivers at the Panasonic Website:
http://pc-dl.panasonic.co.jp/dl/
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989.
Mar 17, 2014 | Panasonic Toughbook CF-30 Notebook
Disable screen touch
open device manager and under input devices disable the touchscreen
Feb 18, 2014 | Acer Computers & Internet
How to turn the touchscreen off on an asus s200e vivobook touchscreen
Go to you device manager (right click bottom left corner --> taskmanager)
Locate the touch device (probably under Human Interface Devices)
Disable the device (right click the device --> disable)
Just out of my curiosity, why do you want this?
Sep 26, 2013 | ASUS VivoBook S200E-RHI3T73 Laptop...
How do i turn the "touchscreen" off on an Asus S200E vivobook touchscreen laptop? please i need help urgent!
Sep 26, 2013 | ASUSTeK COMPUTER Asus VivoBook...
I have an hp tx1000 and my touch screen is not responding at all
Hmmm... touchscreens can be complicated in ruling out what is excatly causing the root of the malfunction. First check to see if you turned the touchscreen option off. There could be a FN button that disable the touch screen and maybe you accidently disable it. I used to have a tx1000 too, but sold it because of the common heating promblem of these machines that cause future malfuctions, only if I sitll have it, I'd be more clear about it. However if that doesn't work, then it could be a driver promblem. Did you change the operation system?, deleted programs associate to the touchscreen? or updated a newer version of the drivers? If this is it, then common promblem could be associated with the drivers of the touchscreen, you will have to reload the driver agian, and can be found in the Hp drivers support section. Other then that, if promblem has not been fixed, then a cablewiring in the laptop somewhere that connected with your screen has become discconnected and loose, because surely those hp tx does do so twisting and turnings which your going to have to take the laptop apart.
Dec 08, 2010 | HP Pavilion tx1000z Notebook
Pal m centro touchscreen disables after receiving
Hello 150pilot,
To manage an active call when the touchscreen is disabled, use the hardware buttons on your Centro (on left side of the Centro).
- OR -
The keyguard feature might be accidentally enabled. To turn off Keyguard, do the following:
• When the screen is off, press the red power button to wake up the screen.
• Press the center (Palm) button to turn off Keyguard.
You can change how quickly Keyguard turns on, or you can disable this feature altogether. To change the Keyguard settings, do the following:
• Press the Home button
• Select System from the category drop-list at the top of the screen
• Select Prefs
• Select Keyguard.
• Select the Auto-Keyguard pick list, and then do one of the following:
-Select how quickly you want Keyguard to turn on: When power is turned off, 5 seconds after power off, or 30 seconds after power off.
-Select Disable to completely disable the Keyguard feature until you turn it on again by pressing Option + Power/End when the screen is on.
4 Select Done.
More information about the keyguard feature canbe found in the Palm Centro User's Guide:
http://www.palm.com/us/support/handbooks/centro/centrosprint_ug.pdf
Have a great day,
martyshaw152
Jan 16, 2010 | Sprint Palm Centro Smartphone
ASUS Q200e Touchscreen Notebook Logo
22 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
