Question about Craftsman Gas Mini - Tiller/Edger
I can't get the head off of my ryobi weed wacker, the screw just keeps spinning, any secret to doing this?
  • dbtheblinds Jul 19, 2009
    thanks for your response.. i found someone in the neighborhood to fix it for me..
  • 1,041 Answers
Either the bolt has stripped out the plastic piece that holds the spool on, in which case you will need to buy a new plastic piece.
Or, the bolt is stripped where it threads into the metal insert.
Pull outward and unscrew counter clockwise.
Jim
Posted on Jun 21, 2009
  • Jim Parker
    Jim Parker Jun 24, 2009
    Did this solution solve the problem?
    Jim
Why is there no high low Idle screws?!?!?!?!?
Hi: My name is Tony from Staten island, NY. I am submitting a diagram for the Ryobi 775R Weed Wacker.
Apr 22, 2012 | Garden
I need to replace the head on this 32cc weed wacker and the bolt shaft keeps spinning keeping me from putting on the new head. Am I missing something?
There is normally a large alloy nut that goes on first, it sits ont the two short flats on the output shaft so as to be able to hold the shaft to fit/ or remove the trimmer head.
Jul 30, 2011 | Garden
I need a replacement head for my 25cc crafstman weedwacker gas line trimmer. I need the whole piece that screws into the bottom of the weed wacker. It is the whole part that spins when the wacker is...
You can find a complete trimmer head replacement at Hyperparts.com. Go into the Lookup By Application section and select the make and model of your trimmer to see a list of the heads they offer.
Jun 28, 2010 | Craftsman 25cc Gas Line Trimmer
Have a Ryobi weed wacker 725r 31cc click link Trimmer Plus. No more line-can't figure out how to remove bottom to replace the line or what kind of line to replace with. Deceased husband lost directions...
i also have a ryobi weed wacker. if it is the same. you don"t have to remove the button. line up the 2 arrows one on wheel with bumpy edges and one by the button. you should see 2 holes feed a 2-3 foot piece of line into the hole the line comes out of for cutting and it should come out of a curved holw on the bottom by the button .tuck the end into a small round hole . pull line tight (tug on the section that you cut with). wind the string by turn the ring around the button. til desired length. if this doesn't work. google you model # and look for a manual (manual for ryobi weed wacker model # ------------.)
Jun 09, 2010 | Garden
Ryobi weed eater head won't spin
Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
Apr 27, 2010 | Ryobi Garden
The string head does not spin as fast as the
it sounds like the centrifugal clutch is slipping. take it to several shops and get some quotes. Most times you'll find that fixing a Ryobi is more expensive than buying a bnew one.
Sep 02, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Replace pull cord on ryobi model cs30 weed wacker
Good fix, mrfixit-jerr! Also, if you remove the rear cover (4 screws) you can stabilize the crankshaft by inserting a screwdriver between the lobe of the shaft and the counterweight.
Apr 03, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do you put the weed wacker "string" in mine keeps flying out when I rev it up to weed wack
You need to give close attenttion to the string wrap" arrows" or guides and see if there are holes the size of the string your using is correct size to fit into these "grip holes inside the casing.
Please rate
tk u
JJ
Mar 17, 2009 | Ryobi Garden
Ryobi electic weed wacker
Call Ryboi at 1-800-525-2579. Their part # is Ut41002A-36
Jul 26, 2008 | Electrical Supplies
Craftsman Gas Mini - Tiller/Edger Logo
563 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
